[Solved] Hotpoint-Ariston LFTA + H2141HX.R Dishwasher: Error 13, Suspected Washing Pump Control Damage
artechserwis 18741 8
  • #1 17163344
    artechserwis
    Rate: 23
    I have a problem with the Hotpoint-Ariston LFTA + H2141HX.R (36813940100) dishwasher.
    After starting the dishwasher drains water, the overdrive valve motor works. It collects water for a while (about 5 seconds) and displays error 13 when the drain pump is switched on. I suspect damage to the washing pump control. It seems to me that the washing pump should turn on for a while before the dishwasher starts to collect water, but it does not. The module also does not supply voltage to the washing pump.
    Has anyone encountered such a failure yet?
    I will mention that this is not a problem with the detergent dispenser.
    Regards
  • #2 17164868
  • #3 17165035
    artechserwis
    Rate: 23
    Thank you for the hint, but I checked the pump. In addition, at startup should get voltage from the module and at least a little "moan", and nothing happens.
  • #4 17165090
    bubu64
    Help: 57
    Rate: 283
    And how did you check this pump?
  • #5 17165253
    artechserwis
    Rate: 23
    I connected the washing pump to a second dishwasher. Indesit dishwasher, but the same connections.
  • #6 17165443
    bubu64
    Help: 57
    Rate: 283
    Then connect the pump with Indesita in Ariston and you will know if it is a pump or control :)
    zibi1971
    Home appliances specialist
    Help: 262
    Rate: 1120
    Gentlemen service technicians, this error is not related to the pump only according to the service center with a dispenser for tablets and rinse aid. The theory says so, and in practice you have a burnt relay foot on the module.
  • #8 17165731
  • #9 17212927
    artechserwis
    Rate: 23
    Welcome back.
    Recently, I had two dishwashers that were very similar to each other, and error 13 appeared in each.
    In the first subject, the replacement of the control module helped. All other ways have failed.
    In the second error 13 (after a while, during the program) meant a damaged washing pump. Pump blocked.
    In both the first and the second dishwasher, the error did not indicate a faulty dispenser.
    Problem solved.
    Subject to close.
    Thank you and best regards.
The Hotpoint-Ariston LFTA + H2141HX.R dishwasher is experiencing Error 13, which occurs after the initial water drainage and operation of the overdrive valve motor. The user suspects damage to the washing pump control, noting that the washing pump does not activate as expected. Responses indicate that the issue may not solely be with the pump, as a service technician suggests a burnt relay on the control module could be the cause. The user later reports that replacing the control module resolved the issue in one instance, while a blocked washing pump was the problem in another similar case. The error does not relate to the detergent dispenser.
