[Solved] Polaroid TQL32R4PRO12 Inconsistent Start-Up & Stby, Blinking Red LED, CV9203H-Q42 Board Issue
nelu.brasoveanu 2286 2
  • #1 17244888
    nelu.brasoveanu
    Rate: 9
    This lcd does not start, the red led is blinking sometimes and after 5-10 min. it starts and the image is ok. In some cases it goes 15-20 min and then stops and the led blinks again by itself. I think that the processor sp9203 is a little warm but many Chinese TV boards have this kind of function. The tension is correct. Have resofting bin but no good news. What can it be? BOARD : CV9203H-Q42 DISPLAY: BOE HV320WXC-200 or CV315PW07S
    • polaroid.bin (4 MB) You must be logged in to download this attachment.
  • #2 17427575
    almou
    Rate: 55
    Thank very much for this
    Hi NELU, i have the same problem. But i solve mine. Just warm SMD components with rework iron station and everything is ok.
  • #3 17589138
    gulson
    System Administrator
    Help: 150
    Rate: 6082
    the trouble was solved changing the processor . it is not easy, must much
    attention and i think that is more better to change mother board if you not
    have reballing station or enought experience.
