VW Golf 4 1.9tdi 110km - Understanding the Function and Testing of Electric Charge Sensor
rsv6 28893 7
  • #1 17245479
    rsv6
    Rate: 285
    I warmly welcome
    Can anyone tell me how to check the electric charge sensor? How does it work because there are 4 wires.
    KMal
    Help: 340
    Rate: 1434
    The boost sensor called the absolute pressure sensor, MAP sensor, the intake manifold sensor in this version is combined with an air temperature sensor, therefore it has 4 leads. These are two sensors in one.
    In 1 fig. Diagram of this sensor (pins 1,2,3,4), and 73,31,71,52 are pins to the ECU
    Fig. 2 order of the pin in the sensor.
    Attached, a detailed description of the operation, specification, diagnostics of this sensor for VW Golf 4 1.9tdi 110km
    VW Golf 4 1.9tdi 110km - Understanding the Function and Testing of Electric Charge Sensor VW Golf 4 1.9tdi 110km - Understanding the Function and Testing of Electric Charge Sensor
    • Czujnik2.pdf (340.52 KB) You must be logged in to download this attachment.
  • Clarifying sensor pinout and signal behavior
    #3 17246275
    rsv6
    Rate: 285
    The instructions show.
    1.2 pin compressed air temperature sensor.
    1. Pin output signal or mass (it is possible that 5v depending on the temperature will drop on pin 2) 3kohm - 20st, 300ohn - 90st relative to the second pin
    2. Pin + 5V from the computer should be relative to the weight from the battery
    3.4 Pin boost pressure sensor.
    3. Pin + 5V from the computer should be relative to the weight of the battery.
    4. Pin output signal.
    I still don't know how the pressure change sensor should behave.
    Is there any voltage divider because pin 1 sensor mass 3pin + 5v 4pin linear voltage 0-5V depending on pressure? Is there a digital signal from the sensor.
  • #4 17246289
    robokop
    Help: 1763
    Rate: 6372
    You fasten the usual mechanical pressure gauge and see if its indications coincide with those of the diagnostic system, based on the sensor readings. The signal is voltage. Assume that if the sensor correctly indicates the atmospheric pressure, with the engine off, it is in working order.
  • #5 17246300
    rsv6
    Rate: 285
    I agree with you 100%. However, if I wanted to increase the boost pressure through a sensor measurement error. I wonder if something would work out.
    There is one option given on the forum to increase the fuel dose in a similar way works 100%. However, as you know, increasing the dose of fuel without a dose of air in the diesel causes an increase in temperature and thus burning of the pistons.
  • #6 17246310
    robokop
    Help: 1763
    Rate: 6372
    Nonsense. However, I recommend reading a lot about the principle of operation of a diesel engine.
  • #7 17246358
    melas
    Help: 138
    Rate: 689
    The MAP sensor has no characteristics from 0 and cannot show 5v at maximum pressure.
  • Fuel dose increased by lowering pump temperature sensor resistance
    #8 17246390
    rsv6
    Rate: 285
    It is about increasing the dose by reducing the resistance of the injection pump temperature sensor. The engine then works as if the suction effect is very satisfactory. Preferably a 150ohm multi-turn potentiometer is installed in series with a 330ohm resistor and switch. The 330ohn resistor is designed to protect against a complete short circuit.
    The lower the resistor resistance, the better the motor is, but you have to set it so that it does not kick.
    The effect I was able to achieve is acceleration to 100km / h from 12.5s to 9.5s
    At lower resistance, the engine works even better, but then it starts to kick. If it is black, it doesn't burn everything.
    So I'll try to check the sensor with a voltmeter and oscilloscope. How it behaves when driving. Which voltage corresponds to the given boost pressure. And if you can influence them easily.
    Thank you so much for setting :) I thought this sensor was more complicated. Type two pins power supply and two more digital signal.
The discussion centers on the electric charge sensor, specifically the MAP (Manifold Absolute Pressure) sensor integrated with an air temperature sensor in the VW Golf 4 1.9 TDI 110km. Users inquire about the sensor's functionality and testing methods, noting its four-wire configuration. Key points include the sensor's output signals, voltage readings, and the importance of comparing sensor data with mechanical pressure gauges to ensure accuracy. Some participants discuss potential modifications to increase boost pressure by manipulating sensor readings, while others caution against such practices due to risks of engine damage. The conversation emphasizes the need for proper diagnostics using tools like voltmeters and oscilloscopes to understand sensor behavior under different conditions.
