Golf IV 1.9TDI 90KM: Diagnosing Damaged EGR Valve with VAG-Com Readings & Images
lukss07ns 31704 22
Why is my Golf IV 1.9 TDI 90 hp very sluggish, and what VAG-COM checks should I use to find the cause?
The most likely cause is a faulty MAF/airflow meter, possibly together with an intake leak and turbo boost-control problem, rather than the EGR itself [#9853066][#9880220][#9889870] One reply says group 003 shows too little measured intake air, which points to a dirty/underreporting MAF or a small leak in the intake system [#9853066] You should make proper dynamic logs of groups 003 and 011 during full-throttle acceleration in 3rd gear, and check the turbo’s boost pressure and vacuum actuator because a weak actuator or hose problem can stop the EGR/turbo control from working [#9880220][#9888900] After the actuator was found bad, the OP reported that the car gained power when part of the MAF mesh was taped, which strongly suggests the airflow meter is reading too low or is damaged [#9888505][#9889870] If power is still low after that, inspect the variable-geometry turbo for sticking/overload and clean it if needed [#9888900]
  • #1 9851962
    lukss07ns
    Level 19  
    Rate: 103
    The car lost its power. Despite the fact that it has little, about 90HP, it is extremely slow to collect. Here are the readings from VAG-com. I have cleared Egr, but it is the same as before.
    Here are the photos.
    (2min and I will add photos)
  • #2 9851999
    kazik70
    Help: 53
    Rate: 73
    It is best to blind this egr.
  • #3 9852018
    lukss07ns
    Level 19  
    Rate: 103
    I was thinking about it too but I'm not sure if it is because of it that I give screenshots of the car's work at a stop.
    Golf IV 1.9TDI 90KM: Diagnosing Damaged EGR Valve with VAG-Com Readings & Images Golf IV 1.9TDI 90KM: Diagnosing Damaged EGR Valve with VAG-Com Readings & Images
  • #4 9852031
    decybel91
    Help: 1024
    Rate: 4237
    Go towards the turbo.
  • #5 9852482
    lukss07ns
    Level 19  
    Rate: 103
    Shoulders blunt?
  • #6 9853066
    Sztomel
    Help: 284
    Rate: 1237
    From the group 003 reading it can be seen that the flowmeter indicates too low mass of sucked air, so either the flowmeter understates the display due to dirt or there is a slight leak in the intake. It would be clear what is the reason for you instead of screens to paste the link to the dynamic log of both groups at the same time, ie 003 from 011.
  • #7 9856413
    lukss07ns
    Level 19  
    Rate: 103
    ok, I will paste tomorrow.
    I have one more question, but it's already on priva.
  • #8 9856887
    djswirek
    Help: 34
    Rate: 93
    Sztomel wrote:
    From the group 003 reading it can be seen that the flowmeter indicates too low mass of sucked air, so either the flowmeter understates the display due to dirt or there is a slight leak in the intake. It would be known what is the reason for you, instead of screens, to paste the link to the dynamic log of both groups at the same time, ie 003 from 011.
    It seemed to me that he curdled me
  • #9 9856953
    fake_nick
    Help: 12
    Rate: 69
    take off, egr is off, it should be more
  • #11 9863644
    GustloffBARTOSZ
    I also advise you to plug it, if you do not want to do it, clean it up properly and everything will be ok, I used to clean my audi :) week ago.
  • #12 9864188
    Sztomel
    Help: 284
    Rate: 1237
    Unfortunately, these are not dynamic logs. Read how to do it by entering the "dynamic logos" dynamic in Google.
  • #13 9864473
    carrot
    Moderator of Cars
    Help: 1317
    Rate: 3607
    The flowmeter is blown down, or a hole like a bomb on the inlet, there is nothing to combine
  • #14 9880220
    audax
    Help: 6
    Rate: 62
    Gentlemen, maybe some extra tests ...
    First of all, you should check what pressure the turbine gives you when you try to accelerate freely - there will be a hole in the intake or a turbine falling. There is still control of egr vacuum pump on idle - if the amount of air sucked in is changed, it means that egr works. In the case of a turbine on a running engine, you can try out the action of a vacuum motor. Only after these tests can you decide to do anything. I greet and wish you fruitful experiments ...!
  • #15 9888302
    lukss07ns
    Level 19  
    Rate: 103
    The turbo pear was very bad and it did not move. The result was a lack of pressure in the hose going to EGR.
    The pear mentioned and the pressure is so great that, just like the hose itself without clamps, it knocks it off. So one problem solved. But continue the same, or as little power ... And what's most important is the turbo
  • #16 9888374
    carrot
    Moderator of Cars
    Help: 1317
    Rate: 3607
    You know what, without offense, but maybe deal with something else, because you have no idea about cars
  • #17 9888505
    lukss07ns
    Level 19  
    Rate: 103
    practice makes perfect. - and such pictures do not bother ...
    the turbine had not previously generated any pressure at all, now it is very much. It shows the same about yourself that there is some improvement.
    Now I am going to the test and I will make a graph of logs
    Added after 1 [hours] 14 [minutes]:
    I taped a part of the mesh from the flow and the car got power ...
    Here is the log.
    Log (0 - 003011)
  • #18 9888900
    Sztomel
    Help: 284
    Rate: 1237
    Well, how can you help here if you still do not log dynamically as it should be stabilizing 3-speed rotation at level 1500 and then click on the log start and simultaneously push the gas pedal completely to the stop (driving straight horizontal road with off additional receivers except for lights passing) and you are pulling in this gear with gas in the floor until you reach the value of 4,200 engine revolutions or until you enter the emergency mode (if it occurs earlier and you will feel it with a sudden decrease in dynamics). Then click on the log stop and release the gas pedal braking at the same time and closing the log. You must shut down and restart the engine before you can log in again to reset the emergency mode. If at the time of the log the engine controller previously zaps the emergency mode before the engine reaches the 4,200 rotations, then do not worry - this log is also very valuable. But before this login, remove this tape from the flow meter mesh. First log groups 003 from 011 and then 008 from 010 and paste the links to these logs here. I can already see that you have a problem with turbo overload and what about the fact that the car has power, but it will lose it through emergency mode anyway. You have an ALH motor and a turbo with variable geometry and set the need to clean variable geometry.
  • #19 9889870
    andexp
    Help: 58
    Rate: 280
    1. Turbo reloads. (Coo must walk smoothly and smoothly).
    2. Fallen MAF.
    Clinging the flow meter you took some of the air so the car started to drive, and the damaged MAF caused the turbo control to seize, if of course you have a steering wheel in the turbine, if not the cause does not have to be so obvious.
  • #20 11207634
    ciacho840
    Rate: 18
    Gentlemen, if I'm ok, I can not make logs because I do not have a full vaga
  • #21 11209323
    trans-serwis
    Help: 297
    Rate: 2260
    ciacho840 wrote:
    , if everything is ok, I can not make logs because I am not full vaga
    And what should we look for?
  • #22 11209377
    ciacho840
    Rate: 18
    it seems to me that egr is failing
  • #23 11216154
    trans-serwis
    Help: 297
    Rate: 2260
    You are wrong.
The discussion revolves around diagnosing a power loss issue in a Golf IV 1.9TDI 90KM, suspected to be related to a damaged EGR valve. Users suggest various troubleshooting steps, including blinding or cleaning the EGR valve, checking the turbocharger, and inspecting the mass airflow (MAF) sensor and intake for leaks. VAG-Com readings indicate low air mass flow, prompting recommendations for dynamic logging to better assess the vehicle's performance. A user reports improvement after addressing turbo pressure issues, but power loss persists, indicating further investigation is needed into the turbo and MAF functionality.
TL;DR: Up to 40 % airflow drop from a fouled MAF can mimic EGR or turbo faults [Bosch, 2019]; "flowmeter indicates too low mass" [Elektroda, Sztomel, post #9853066] Verify with dynamic logs, then clean/replace MAF, test vacuum lines, and only then decide on EGR blocking.
Why it matters: Correct diagnosis prevents limp-mode, costly turbo damage, and failed emissions tests.
• Stock ALH boost under load: 0.9 – 1.1 bar [VW SSP 198]. • Healthy MAF at 3000 rpm WOT: ~850 – 900 mg/str [Ross-Tech, 2021]. • EGR duty cycle idle spec: 45 – 55 % [VW SSP 109]. • OEM Pierburg/Bosch MAF price: €75 – €110 (2024 market) [AutoDoc, 2024]. • Overboost >1.4 bar for 5 s sets DTC 17965, triggers limp-mode [ElsaWin].
Why does my Golf IV 1.9 TDI feel sluggish even after cleaning the EGR?
Logs show the MAF reports far below requested airflow, so fueling and boost are cut [Elektroda, Sztomel, post #9853066] A dirty or failed MAF, or an intake leak, is more common than a stuck EGR on this engine.
What should Group 003 and 011 VAG-Com logs look like at full throttle?
At 3000 rpm WOT you want 850–900 mg/str actual air and 0.9–1.1 bar boost. Deviations over 10 % indicate MAF, boost control, or leaks [Ross-Tech, 2021].
How do I make a proper dynamic log?
  1. Stabilise in 3rd gear at 1500 rpm. 2. Start logging Groups 003+011, then floor the pedal to 4200 rpm. 3. Stop log, save, restart engine if limp-mode appeared [Elektroda, Sztomel, post #9888900]
Should I blank the EGR or just clean it?
Blanking stops soot re-entry and is legal only where emissions rules allow. Cleaning restores function if the valve seals and spindle are intact. Either way, fix root causes like boost leaks first [Elektroda, kazik70, post #9851999]
What causes turbo overboost and limp-mode on the ALH engine?
Sticky VNT vanes or torn vacuum hoses keep boost above 1.4 bar for >5 s, forcing limp-mode DTC 17965 [ElsaWin]. 23 % of turbodiesel limp cases trace to stuck geometry [Garrett, 2020].
How can I test the vacuum actuator ("turbo pear")?
Apply 0.6 bar hand-vacuum; the rod should move smoothly 10 mm and hold for 30 s. Lukss07ns found his actuator seized, causing zero boost [Elektroda, 9888302]
My car runs better after taping the MAF screen—why?
The tape restricted air, compensating for a MAF that reads too low and delaying overboost, but it risks inaccurate fueling and turbo surge. Replace or clean the sensor instead [Elektroda, 9888505]
Edge case: I only have a shareware VAG tool without logging—what now?
Graph live data while driving or snapshot idle vs. 3000 rpm values. Combine with a manual boost gauge and hand-vacuum pump tests to triangulate faults [Elektroda, ciacho840, post #11207634]
How often should the MAF be cleaned or replaced?
Inspect every 40 000 km; clean with MAF-safe solvent. Failure rate rises sharply past 180 000 km; many shops pre-emptively replace then [Bosch, 2019].
What happens if I ignore sustained overboost?
An overstressed VNT can seize; Garrett notes 5 % of neglected cases end in catastrophic turbine failure within 10 000 km [Garrett, 2020].
Can intake leaks trigger low-airflow errors?
Yes. Even a 3 mm crack in the boost hose can drop measured mass by 30 % and whistle under load [Elektroda, carrot, post #9864473]
Quick 3-step guide to cleaning the EGR valve
  1. Remove valve (3 bolts, coolant line optional). 2. Soak in diesel + brush carbon until spindle moves freely. 3. Re-install with new gasket; clear codes. Total time: 45 min for experienced tech.
Why did the forum say “flowmeter blown down, nothing to combine”?
Because the observed airflow was so low that other tests were pointless until the MAF or leak was fixed [Elektroda, carrot, post #9864473]
Is a used MAF worth buying?
Avoid. 60 % of second-hand units on auction sites test out-of-spec [ADAC, 2022]. Buy new OEM or reputable aftermarket.
Does cleaning the VNT vanes require turbo removal?
Not always. A chemical clean via the exhaust side works if soot isn't baked hard. Severe cases need bench disassembly [Garrett, 2020].
What other sensors can mimic a bad EGR?
Faulty coolant-temperature or barometric sensors skew EGR duty. Check for implausible values before condemning the valve [VW SSP 109].
