[Solved] The siphon is dripping under the bathtub in the place marked in the photo
Helterskelter2 8577 2
  • #1 17247859
    Helterskelter2
    Hello, after unscrewing and installing the siphon, water flows again from the place marked in the photo. I probably touched this place when removing the siphon. I am asking for a hint if I can fix it myself or if a new siphon and plumber is necessary. Thank you.
  • #2 17247903
    nutergsm
    Help: 1034
    Rate: 1662
    You need to position the gasket well and tighten the siphon. Simple enough for someone who has done something like that before.
    For what purpose was the siphon removed?
  • #3 17247926
    Helterskelter2
    The water drained slowly. After analyzing it, I discovered that the "screw" in that grate in the bathtub had loosened and it was not holding the seal. I tightened and everything is fine :)
