[Solved] Selection of 20m application-controlled RGBW LED strip - differences in power supplies
cysiek114 1476 6
  • Small controller may not power 20 m strip
    #1 20759352
    cysiek114
    Hello everyone
    I'm looking for a RGBW LED strip for a room with a length of ~20 m. I would like it to be possible to change the color from the app + if it would be possible to connect it to the smart home from Google.
    I intend to connect the set in series.
    I found on aledrogo such:
    https://allegro.pl/oferta/zestaw-20m-tasma-led-5050-rgb-bialy-p-dotykowy-9255598473
    I have such a set privately in another room for 2 years. It works fine but it cannot be remotely switched on from the app + the remote control is a bit vague.
    Here I have an offer which has the possibility of control from the app:
    https://allegro.pl/oferta/tasma-led-rgb5050-20m-aplikacja-wifi-pilot-zestaw-13743961768
    But I have a small concern:
    In the first ad, the power supply is large and only from the power supply goes a cable to the controller
    and in this second offer, the controller is tiny and is at the same time (probably) both the power supply and the controller.
    Given the fact that I need about 20 m of LED tape, is such a power supply has a raison d'être.
    I'm afraid that after purchasing such a small power supply cannot handle 20 m of tape and it will look "sticky". It seems to me that maybe at a distance of up to 5m it works, but for longer tape lengths if you do not need to give a large power supply it would not be in the first offer (can someone explain this?) I do not know about electricity and I'm completely green.
    I would like to ask you here. Thanks in advance. If you have some cool LED strips with the possibility of connection to applications and Wi-Fi worthy of recommendation it would be great.
    Greetings :).
    Power rating and RGB white claims are implausible
    #2 20759755
  • 20 m strip needs power injection and 144 W supply
    #3 20759844
    cysiek114
    Thanks for the answer
    I caught the power of the power supply only in the description at the top of the auction (I do not know if this allegro itself does not fill this). It is given there 48W which is a power of absurdly small for such a length of the tape.
    The tapes given in the auction should have a power of 7.2w / m (this is how many such tapes have 150 RGB LEDs typical) so it comes out 144W.
    -No, it also seems to me something seems too small on simple "peasant reasoning" Set from the first link has a power supply with just 144W.
    Additionally, in order for such a long section to be able to work well it is not possible to plug in 20m of tape only at the beginning and run it "in bursts"
    - Well I wanted to run the LED strip around the ceiling and on two sides (the beginning of the tape and its end) connect to the power supply. I have read that with a length of more than 5 m there are dips and the tape illuminates unevenly and you need to either connect the cables every 5 m or do it in series, so as it is written - the beginning and end of the LED strip and to the driver
    The controller working with TUYA can be paired with what you want, but I do not know how its durability for such a long stretch of LED tape.
    - Are you saying that the longer the LED strip the worse for such a driver?
    I have one of these just from TUYA and cool thing in general only they just do not have a power supply , but there I have maybe only 3m tape
    I'm leaving aside the question of price because 20m of such tape with driver and power supply costs about 500zl. I'm talking about a good set.
    In summary, this set does not inspire confidence, although you can always return on allegro without losing money
    - Thanks for your opinion! I will take it into consideration.
    What about returns from Allegro is true, but I prefer to ask around on the electrode than buy blind. I also do not want to glue the LED tape and then take it off after a month because something will be wrong. So, for a 20 M LED strip to work properly, you need a power supply of at least 144W, yes?
    Measure voltage drop along the 20m LED strip
    #4 20759973
  • #5 20760506
    cysiek114
    Thanks!
    And do you know how the selection of power supply for the LED strip RGB+CCT compared to a regular RGBW?
    Because maybe I do not understand something, but RGB + CCT and RGB +W is the same.??
    Because there are more LEDs, the power supply must also be more powerful
  • RGBW and RGB+CCT strip power differences explained
    #6 20760741
  • #7 20787393
    cysiek114
    I bought a ready-made kit from allegro
    Thank you for all your helpful advice
    Greetings
The discussion revolves around selecting a 20m RGBW LED strip that can be controlled via an app and integrated with Google smart home systems. The user compares two products from Allegro, noting that the first set has a sufficient power supply (144W) for the length of the strip, while the second set's power supply (48W) is deemed inadequate. Concerns are raised about the controller's size and functionality, particularly regarding power distribution over long distances to avoid voltage drops. The conversation also touches on the differences between RGBW and RGB+CCT LED strips, highlighting their varying power requirements and capabilities in producing white light. Ultimately, the user decides to purchase a ready-made kit from Allegro after considering the advice received.
