[Solved] DELL Latitude e5610 - How to turn on bluetooth in DELL Latitude e5610
iluminatix 8973 6
  • #1 17260750
    iluminatix
    Does the DELL Latitude e5610 laptop have built-in bluetooth?
    above the keyboard there is a diode informing about bluetooth, on the della website I can download bluetooth drivers, but during their installation the computer asks you to turn on the bluetooth wireless switch and I do not have one ... in other topics I read that it was just a combination FN + F2 but for me it does not work.
  • #2 17260768
    płetwa
    Level 32  
    Help: 161
    Rate: 533
    View in your computer from the right side of the keyboard, on the edge of the case whether there is a slide switch. Most have it, it turns on all wireless connectivity, i.e. WIFI and BLUETOOTH.
  • #3 17260769
    g107r
    Help: 807
    Rate: 977
    You have a sliding WiFi switch on the side of the case, in my laptop a little different, e5430, it also works on BT.
    When it is turned off, the BT icon next to the watch in the bottom right corner disappears.
  • #4 17261497
    iluminatix
    There is a slide switch on the right side of the computer, but it just turns on WiFi only (the WiFi LED lights up and the Bluetooth LED stays off).
  • #5 17261589
    g107r
    Help: 807
    Rate: 977
    Do you see any unknown devices in the device manager?
    You may not have, point 12
    http://www.dell.com/support/article/pl/pl/pldhs1/sln148687/reinstalling-driver% C3%B3w-w-prawid%C5%82owej-kolejno%C5%9Bci?lang=pl is removable, but I wouldn't suspect sellers about such things anymore, WWAN will take them out sooner.
    For me, BT probably appeared after installing the wifi software, and one more file, it seems to have a numeric name.
    What does the della program say to me, "supportassist"?
    Yes, http://www.dell.com/support/home/pl/pl/pldhs1
    I downloaded all the drivers and programs, I installed them later, some devices DOPIERO appeared during the installation.
  • #6 17261666
    iluminatix
    After consulting with Dell by FB, it turned out that in this model (they asked for the laptop's TAG service number)
    "you need a Dell 375 Bluetooth card for bluetooth which is not in this configuration"
  • #7 17261667
    iluminatix
    After consulting Dell through FB, it turned out that in this model (they asked for the laptop's TAG service number) "for bluetooth you need a Dell 375 Bluetooth card, which is not in this configuration"
✨ The DELL Latitude E5610 may not have built-in Bluetooth functionality, as indicated by the absence of a Bluetooth LED when the WiFi switch is activated. Users have noted that the sliding switch on the side of the laptop primarily controls WiFi connectivity. To enable Bluetooth, it is suggested to check for unknown devices in the device manager and ensure that the correct drivers are installed. A consultation with Dell revealed that the E5610 requires a specific Dell 375 Bluetooth card for Bluetooth capability, which may not be included in all configurations.
