The Dell Latitude E6440- Laptop does not detect headphones, but only some.
siwaczysko 6117 9
Why does my Dell Latitude E6440 only detect some headphones, while other headphones that work on every other device are not recognized?
The thread suggests the E6440’s combo audio jack is either incompatible with some headset plug pinouts or physically damaged, so only certain plugs make proper contact or are recognized [#16567233][#16567275][#16582978] Some headphones were said to have an unusual 3-/4-pin pattern, and an adapter was recommended, but the adapter did not solve the problem [#16567233][#16567285][#16582914] Because the laptop is a business model and the adapter failed, the most likely explanation became a faulty headphone jack [#16582978] The later test that phone-bundle earbuds worked every time suggests those plugs happen to match the jack better than the others [#16584101]
  • #1 16567212
    siwaczysko
    this is my first post and I apologize in advance if this topic appears in the wrong section. I have a problem with headphones or with a laptop. I don't know that because:
    I had earphones (let's call them A). The most ordinary ones that I got on the phone. After a while one stopped working.
    So I dug some headphones from the closet (let's call B), the laptop didn't detect them at all. I could turn the jack on, pull out ... NOTHING.
    As these unearthed headphones were just any company, I decided to buy headphones (maybe not from the top shelf) Panasonic RP-HT 161.
    I connect to a laptop - the same, nothing. With the difference that turning the jack sometimes appears for a moment a window allowing you to select the sound source, but it takes less than a second. Sometimes when I press the plug properly, I can switch the sound on the headphones, but when I release it, everything returns to (un) normal.
    I didn't give up - I dug out an external Digitus DA-70800 sound card from the closet. I connect to the paw, to the card I connect headphones to the headphones slot - silence. I connect to the front (2.1) - there is sound.
    I will mention that it is a business laptop. My helpdesk elegantly blew my outlet with compressed air. They took some earphones - they work. Others - no.
    Questions here:
    - Why on those first earphones (A) in which only one earphone was working - can you hear sound normally?
    - Why can't I find the earbuds on my lap?
    - Why both B and Panasonic headphones work on all other equipment but not on the lap?
    Ultimately, I can't even locate the problem because the headphones are ok because they work on EVERY OTHER EQUIPMENT. I even went to great lengths and when buying headphones, I took my paw to the store and tested several headphones. The laptop didn't find any.
    On the other hand, there is no problem with the A headphones on the lap - except that one does not work but it's a matter of headphones, we know
    A huge request for help. If you still need some information - I will help
    Laptop model:
    Dell Latitude E6440
    I corrected the title by supplementing it with a laptop model. RADU23
  • #2 16567233
    E8600
    Help: 529
    Rate: 2520
    The 3 and 4 pin jack socket is for the dog. Some headphones have an unusual pin pattern in the plug. You would need an adapter to make every earphone work.
  • #3 16567243
    siwaczysko
    Well, headphones A and B look identical when it comes to the tip. Panasonic slightly different, but apparently because this one pin is responsible for the microphone but I do not need it
  • #4 16567275
    E8600
    Help: 529
    Rate: 2520
    In the laptop you have a separate microphone socket or you have 1 that supports 2 functions. It is possible that the laptop socket is damaged. Possibly something with headphones impedance.
  • #5 16567282
    siwaczysko
    One supporting two functions. Returning to the adapter. Do you mean it?
    Moderated By RADU23:
    I removed the shop / auction link, leaving the exact model / name / product specification.
    3.1.18. Do not send links that will stop working after some time. This will cause the discussion to lose any meaning.
  • #6 16567285
    E8600
    Help: 529
    Rate: 2520
    Exactly. Delete allegro link because they are prohibited in this forum. An adapter will do the trick.
  • #7 16567289
    siwaczysko
    Well, logical :) next time I will paste the photo itself.
    I will try with the adapter and let me know
  • #8 16582914
    siwaczysko
    Hello after the break
    I bought an adapter, the one I wrote about earlier - with no result
  • #9 16582978
    E8600
    Help: 529
    Rate: 2520
    Due to the fact that it is a business laptop, someone probably damaged the headphone jack.
  • #10 16584101
    siwaczysko
    I don't think so, because the others have the same laptops and everything goes fast.
    I also discovered a strange relationship - namely headphones that are, for example, from the set with the phone work every time. Today I also tried on other such earbuds and they worked without a squeak
The discussion revolves around a Dell Latitude E6440 laptop that fails to detect various headphones. The user initially experienced issues with two sets of headphones, one of which was damaged. They later purchased Panasonic RP-HT 161 headphones, which also did not work consistently. Responses suggest that the laptop's headphone jack may be damaged or that the headphones' pin configuration could be incompatible. An adapter was recommended to resolve the issue, but after trying it, the user reported no improvement. The user noted that some earbuds from a phone set worked without issues, indicating a potential compatibility problem with other headphones.
