Antenna polarization on BTSs - vertical / horizontal or slant?
xntxnt 11700 12
How can I tell whether a BTS uses vertical/horizontal or ±45° slant polarization, and can LTE-to-3G fallback break the connection because of it?
The thread suggests that many modern BTS antennas are cross-polarized at ±45°, but vertical-polarized models also exist, so the answer depends on the actual site and antenna type rather than on LTE vs 3G alone [#17274729] One user found Kathrein catalogs showing oblique polarization already in 2002, with vertical versions also sold and no horizontal versions mentioned, and guessed that most current antennas are probably X-cross because of MIMO [#17274729] The operators’ help lines did not provide usable technical confirmation, and the thread says you will not get this knowledge from them [#17263315] For practical setup, the advice is to orient the antenna based on measured signal strength and actual results rather than on the operator’s declaration [#17263074][#17263106] A final reply says the polarization difference is not important enough to make the internet drop just because the router falls back from LTE to 3G [#17267191]
  • #1 17262742
    xntxnt
    Rate: 82
    Friends,
    How is it with antenna polarization on BTS?
    There is information that for LTE you need an antenna with slant polarization, that is + 45 ° and -45 °. They differ from H / V polarization antennas only by the mount rotated by 45 °. Such antennas are commercially available, but the ones with the vertical / horizontal polarization mount still do not disappear.
    Do you know of any official (or not) sources confirming that they actually use skew? If so, whether the use of a slant depends on:
    1.frequency - in the sense that the polarity is different at 800 and at 900, 1800, 2100, 2600MHz?
    2nd technology - different for 3G and different for LTE? *
    3. the launch date of a given BTS - in the sense that they introduced the slant recently?
    4. operator?
    *) which would cause the signal to drop when the modem switches from LTE to 3G
    The only source I have found so far is a copy of the btsy.eu website which no longer exists:
    https://web.archive.org/web/20140214150206/http://www.btsy.eu/anteny.html
    ... but it is nowhere said that every operator uses a skew, nor is there any detail on either band or technology.
    [added:]
    I called the operators' hotline - the result is known:
    Plus - they don't know, there were some guesses
    Play - they don't know, they advised to experiment, but ordered to send an email
    Orange - I don't know the chat on the website, I still have to call, but from a different phone than I have, because from Orange you have to pay for the call to Orange Customer Service
    T-Mobile - they do not know and send technical assistance to the paid number 708-477-242 (2.10 PLN / min + VAT)
    It would be good to ask a technician or a masters mountaineer, or an engineer, as long as they are not prohibited from speaking, but I don't know anyone.
    Thanks in advance for any information.
  • Cross-polarization used by some BTS transmitters
    #3 17263053
    m.jastrzebski
    Help: 679
    Rate: 865
    Szyszkownik Kilkujadek wrote:
    Why bother? Isn't it better to use a ready-made antenna? http://www.dipol.com.pl/oferta-telefonia-komorkowa-anteny-gsm-3g-lte-lte,4953.htm
    You did not understand the question. The author wants to use a ready antenna and ask how to fix it.
    Each 2-pole antenna will be so constructed that it receives a signal from 2 polarities oriented at 90 degrees to each other. But the question is whether the transmitter polarization planes are vertical and horizontal to the ground or at an angle of 45 degrees to the ground (x or +).
    Ready antenna will receive the signal incorrectly, but it will be weaker.
    Some transmitters / operators have used, do they use? oblique polarization (cross). And as you can see, the operators themselves do not see it, at least the helplines are designed to catch sheep and claim payments.
  • #4 17263074
    Level 37  
    Help: 211
    Rate: 1014
    Well, yes, but you set the antenna based on the actual results (signal strength measurements) and not the operator's declaration?
  • Questioning when BTS antennas use H/V or 45° slant
    #5 17263106
    xntxnt
    Rate: 82
    That's exactly what I mean! :)
    Ok, but not everyone has a locksmith and welding workshop - it happens that the antenna can be turned by 90 ° and effectively attached, but you can not turn it 45 ° using the factory holder (I have seen only single models with articulated ball mounting, not with a bolt to the pipe). So it would be nice to buy the right one right away. And to know what the correct one is, it is worth knowing the theory of when is H / V and when is 45 ° slant. Plus cases when someone changes the operator or moves and looks for another BTS - can it turn out that the existing antenna will do nothing without modifications?
    Or such a case:
    A router that has a GSM gateway in it (not to be confused with a VoIP gateway!). An ordinary fax / telephone is attached to it and it is on the number with the SIM. I buy a polarization antenna like the LTE transmitter has (let's assume that I get to it experimentally) and the internet is spinning. The phone starts ringing, so the router goes from LTE to 3G to be able to establish a voice connection (because it does not support VoLTE - Voice over LTE). So it switches to a completely different BTS antenna. And this other antenna may have, for example, H / V polarization, and not "slant", so the internet breaks me off. - This is a theoretical case, and I would like to know how real it is. Maybe someone has already done it and share their experience.
  • BTS antenna direction can be set by eye
    #6 17263126
    m.jastrzebski
    Help: 679
    Rate: 865
    I haven't seen antennas that have some nice spinning mechanism at 45 degrees each side. For measurement, you can hold the search for se in your hand, but then you usually have to screw it up somehow.
    It's not a satellite dish, where you need to align it with an accuracy of degrees. Knowing the polarity and the direction of the BTS can be set by eye and it will be fine. Nothing needs to be measured and the signal strength analyzed. That is, you can compare whether this or that BTS gives a stronger signal and that's it.
  • #7 17263238
    Level 37  
    Help: 211
    Rate: 1014
    There are holders for pitched roofs:
    This is how it looks on the building:
    You can also easily adjust it.
  • BTS antennas are usually slanted, not vertical
    #8 17263268
    xntxnt
    Rate: 82
    I just saw it, but it is a minority, and they have other disadvantages. For example, some of these antennas are:
    - way
    - crap (spending PLN 200 to have a muffled signal after a year is money down the drain)
    - for one band (e.g. only 800MHz - you change the operator and buy a new one)
    - not available with cables of appropriate length and plugs (you need connector = dB loss, or you need to have something to tighten)
    - with an N socket - convenience, but most N plugs are crimped on the cable (crimp), not clamped, so the water goes into the cable anyway, even though the connector itself has a seal. So at the start you have to change the plugs to your own.
    - when there is no N connector, only a permanent cable, then when turned by 45 °, water may flow into the antenna or it may not have any way out.
    Regulation, but modest. Mast curve compensation rather than full 45 °: Lipa - this is only from tilt adjustment. I got a bad look.
    Great regulation (if it's not rivets, just screws), but if the antenna is great, I don't know. When I see white cables, I have an association: PVC, not PE, so after a year there is water in the cable:
    Even better, because smooth tilt adjustment, but with 14 screws on the back of the housing, will it not take on water and after turning it will not be able to release it near the cable?
    There is also a choice there.
    Some of these drawbacks are a bit of a force. Because in general, I do not mean to buy a perfectly universal antenna and spin it, but to know what the polarization of BTSs is (at individual operators, on specific bands and technologies), to buy it immediately proper antenna, even and unregulated (rigidly polarized).
  • #9 17263285
    Level 37  
    Help: 211
    Rate: 1014
    I would just carry a 45 ° adapter with me and mount it if there was a problem.
  • Request for operator knowledge on BTS antenna polarization
    #10 17263312
    xntxnt
    Rate: 82
    Apart from that I do not know if something like this exists ... I do not mean the available hardware solutions to mount the antenna in any way, but knowledge on the polarities used by operators.
    Well, maybe someone else will add something else.
    Well, I will not get from the operators. That's why I'm asking here. There is Elektroda, there is bez-kabli.pl, there is jdtech.pl, there are people associated with BTSearch, and the operators' technical staff themselves. Someone might answer.
  • #11 17263315
    Level 37  
    Help: 211
    Rate: 1014
    But you won't get this knowledge from operators. Although, maybe I'm wrong. Good luck.
  • #12 17267191
    makosuu
    Help: 369
    Rate: 370
    It doesn't matter that much, it certainly won't cut your internet off because of it
  • #13 17274729
    xntxnt
    Rate: 82
    I asked on the Telepolis forum and someone gave me the catalogs of the Kathrein company, which produces BTS antennas:
    https://cosconor.fr/GSM/Divers/Equipment/Kathrein/ " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > https://cosconor.fr/GSM/Divers/Equipment/Kathrein/
    It turns out that in 2002 they were doing oblique polarization. They also produce with vertical, they did not do with horizontal. It's hard to say how much V is left, but looking at the date and the fact that the world goes in MIMO, probably most of the antennas are X-cross. It is also strange that they are still selling H / V, and the operators do not inform about anything. Unless on the H / V housing, and a slanted one in the middle. I can't see the polarization there by the appearance of the microstrip antenna.
    Anyway - the topic seems to be solved :) . But I'm not closing - maybe someone else will add something.
    Thanks for the discussion.
The discussion revolves around antenna polarization for Base Transceiver Stations (BTS), specifically the use of vertical, horizontal, and slant (±45°) polarization antennas for LTE and 3G technologies. Users express concerns about the compatibility of existing antennas with different polarization types and the impact on signal strength. There is a consensus that while slant polarization is increasingly used, many operators still utilize vertical/horizontal antennas. The conversation highlights the need for accurate information regarding polarization practices across different frequencies (800, 900, 1800, 2100, 2600 MHz), technologies (3G vs. LTE), and operators. Users share experiences and suggest that practical measurements of signal strength should guide antenna installation rather than relying solely on operator specifications. The discussion also touches on the availability of adjustable mounting solutions and the challenges of finding antennas that meet specific polarization requirements.
TL;DR: LTE macro panels commonly use b145 cross‑polarization; typical XPD is 18–20 dB. "b145 cross‑polarized antennas are standard." If unsure, use an adjustable mount and align by signal; V/H costs ~3 dB. [CommScope, 2017]
Why it matters: This helps home installers, RF hobbyists, and field techs choose and mount antennas that match BTS polarization so links stay fast and stable.
  • LTE macro BTS antennas are typically dual b145; typical XPD 918 dB supports MIMO separation and capacity. [CommScope, 2017]
  • Vendor catalogues include both b145 and vertical models across 700–2600 MHz; horizontal is uncommon. [Kathrein, 2012]
  • A 45° mismatch costs ~3 dB; a 90° mismatch can exceed 20 dB isolation in practice. [ARRL, 2011]
  • Most 2x2 CPE panels (e.g., XPOL series) use b145 elements with wideband coverage. [Poynting, 2020]
  • Roll‑adjustable brackets let you set b145 during install when operator data is unknown. [Elektroda, Szyszkownik Kilkujadek, post #17263238]
Which polarization do BTS antennas use today—vertical/horizontal or slant b145?
Most LTE and 5G NR macro sectors use dual b145 cross‑polarized panels to enable MIMO. Vertical‑only panels still exist for legacy or special cases. Horizontal is rare in cellular macro deployments. New NR antennas continue the b145 approach in sub‑6 GHz. [CommScope, 2019]
Does polarization change with frequency (800/900/1800/2100/2600 MHz)?
Polarization is an architectural choice, not band‑specific. Multi‑band base‑station panels provide b145 cross‑pol across 700–2600 MHz. Vendors also ship vertical‑polarized variants in some frequency ranges. Check the specific antenna datasheet for details. [Kathrein, 2012]
Is polarization different for 3G (UMTS) versus LTE?
UMTS commonly used vertical plus receive diversity on many sites. Modern panels support dual polarization, including b145, to improve diversity and aid refarming. LTE widely standardized on b145 cross‑pol for 2x2 MIMO, and NR follows similar practice. [CommScope, 2017]
Will using slant polarization break my connection when my router drops to 3G for voice?
No. Both systems are linearly polarized, so a mismatch affects level, not basic connectivity. A 45° misalignment costs about 3 dB. An orthogonal 90° mismatch can exceed 20 dB isolation. Expect possible speed reduction, not a hard disconnect. [ARRL, 2011]
Did operators switch to slant only recently?
Cross‑polarized b145 panels have been available since the early 2000s, alongside vertical options. Networks shifted toward cross‑pol with MIMO and modernization. Some legacy vertical sectors can still be found. [Elektroda, xntxnt, post #17274729]
Does polarization differ by operator?
It can vary by operator, vendor, and site age. Call centers often lack this detail, so do not rely on them. Confirm locally by measurement or visual inspection where safe. [Elektroda, xntxnt, post #17262742]
How should I mount my CPE antenna if I don’t know the site’s polarization?
Use a bracket that allows roll adjustment so you can try vertical and b145. Align by live metrics like RSRP and SINR. Lock in the best orientation once measured. Adjustable pitched‑roof/roll mounts make this straightforward. [Elektroda, Szyszkownik Kilkujadek, post #17263238]
How much performance do I lose using V/H against a b145 site?
Expect about 3 dB power loss with a 45° mismatch. At 90° mismatch, isolation can exceed 20 dB. MIMO decorrelation may also reduce throughput beyond the raw dB loss. Rotate to b145 to recover performance. [ARRL, 2011]
Are horizontally polarized BTS antennas used?
Horizontal polarization is uncommon in cellular macro networks. Major vendor portfolios emphasize vertical and b145 cross‑polarized models across common mobile bands. Specialty deployments are the exception. [Kathrein, 2012]
What antenna should I pair with a 2x2 MIMO router (Huawei, ZTE, Mikrotik)?
Use a dual‑polarized panel with b145 elements and two cables. Connect both modem ports to preserve MIMO gains. This improves signal quality and capacity over single‑pol antennas. Follow the router’s antenna port labeling. [CommScope, 2017]
If I change operator or band, will my existing antenna still work?
A wideband dual‑pol b145 panel usually spans operators and bands. A V/H panel will work with roughly a 3 dB penalty versus slant. Single‑band antennas may need replacement after a band change. Verify the antenna’s frequency range. [Kathrein, 2012]
How can I tell a site’s polarization without vendor info?
Rotate your CPE and watch RSRP/SINR or CQI, then lock the best angle. "You set the antenna based on the actual results." This practical method is widely used by installers. [Elektroda, Szyszkownik Kilkujadek, post #17263074]
Any mounting or weatherproofing gotchas when rolling to b145?
Yes. Keep cable entries facing down to drain water. Weatherproof N‑connectors and pigtails. Prefer outdoor‑rated PE jackets over white PVC. Be cautious: many‑screw enclosures can trap water when rolled. [Elektroda, xntxnt, post #17263268]
Do I need special hardware to achieve b145 at install?
Not necessarily. Roll‑adjustable or pitched‑roof brackets let you set slant on standard panels. Carry a simple 45° adapter if your stock mount is rigid. This avoids buying a new antenna just for slant. [Elektroda, Szyszkownik Kilkujadek, post #17263238]
