Ford s-max - parking sensors do not work, module is not detected.
thieri1 13362 6
  • #1 17262784
    thieri1
    Rate: 8
    Good morning,
    I have a problem with the Ford S-MAX, parking sensors do not work.
    After connecting the computer, if he wants to check if there is any error, it does not detect the sensor module, and the button in the car, which could be used to turn on or off the parking sensors, does not light up.
    What could be the reason ?
    best regards
  • #2 17262799
    leonov
    Help: 1039
    Rate: 2248
    Check if the module has power. Factory sensors?
  • #3 17262818
    thieri1
    Rate: 8
    yes factory sensors titanium version, sensors front rear.
    After work, I will check the power supply, where is this module?
  • #4 17262822
    leonov
    Help: 1039
    Rate: 2248
    Start with fuses (manual).
  • #5 17262842
    thieri1
    Rate: 8
    fuses approx
  • #6 17262878
    leonov
    Help: 1039
    Rate: 2248
    Well, from the sensors, checking the cables and connections to the control panel.
  • #7 17262928
    thieri1
    Rate: 8
    I have the same s-max, I would have parts for a replacement. What to start with translating the module?
The discussion revolves around a malfunctioning parking sensor system in a Ford S-MAX, where the sensor module is not detected by diagnostic tools, and the activation button does not illuminate. Suggestions for troubleshooting include checking the power supply to the module, inspecting fuses, and examining the wiring and connections to the control panel. The user confirms that the vehicle has factory-installed sensors in the titanium version, both front and rear. There is also mention of potential replacement parts for the module.
