Huawei HG8245Q Netia: DDNS Setup, Port Forwarding & Safe Remote Desktop Access
detonator 5793 3
  • #1 17273136
    detonator
    Rate: 18
    Welcome,
    At the moment, there is no fixed IP and there is a server in the network that needs to be accessed via the remote desktop. How to combine DDNS service with port forwarding (?) So that it is relatively safe? Anyone working on this topic?
  • #2 17273262
    Epic
    Level 30  
    Help: 147
    Rate: 108
    Listing RDP directly to the Internet is generally a bad idea. This service should not be available to everyone.
    Yes, use DDNS, but to solve the problem with changing IP for VPN. As far as I know, it is not possible to configure the VPN service on the Huawei HG8245Q, so you need to configure such a server on a machine inside the network. On the router, redirect the ports depending on the service selected, and make RDP only available to computers connected to the VPN.
  • #3 17273441
    detonator
    Rate: 18
    You have some tutorial, maybe there is a server on the network on win server 2012, this is what I would like to manage via RDP, he could host a VPN.
  • #4 17274357
    makosuu
    Help: 369
    Rate: 370
    Set DDNS from NO-IP on this Huawei, and you can redirect the port, it will probably be the easiest. Just make the exterior some tall, unusual. Alternatively a VPN, as far as I know, Windows can be a PPTP VPN server itself. Then forward the port from the VPN.
