Calculating LED Lighting Power for Aquarium: Mixing White, Royal Blue, Deep Red & Full Spectrum
oczko100 27669 10
How should I choose the ratio of white, Royal Blue, Deep Red, or full-spectrum LEDs for aquarium lighting, and do the colored LEDs count toward the 30 lm per liter rule?
There is no single fixed white-to-colored LED ratio; the mix depends on the aquarium’s needs and the LED spectrum, and one reply suggested treating colored LEDs as a spectrum extension, up to about half the total set, for example a 2:1 white-to-color ratio [#17278840][#17278876] For lumen-based sizing, first calculate the total light needed from tank volume, such as 100 L × 30 lm/L = 3000 lm, but remember LED efficiency varies a lot, so watts are often used as a rougher rule of thumb too, around 0.4 W/L [#17278876][#17278840][#17280447] In the example given, if a 1 W white LED produces about 100 lm, then 3000 lm would mean about 30 white LEDs, and with a 2:1 white-to-color mix that becomes 30 white and 15 colored LEDs [#17278876] Colored LEDs are treated as an extension of the spectrum, so the real choice should follow the aquarium’s organisms and the desired visual effect rather than a fixed count alone [#17278840][#17280379]
  • #1 17278724
    oczko100
    Hello, I am building a led beam on power ledów and I have a problem, for example, if I have 14 white diodes 7x8500k and 7x6500k for this I should still use the Royal Blue and Deep Red or full spectrum diode and my question how much should I use them, what is the ratio to whites? And the second question, let us assume that we accept the principle of 30 LM per liter of water, are these "colored diodes" also included in it?
  • #2 17278840
    matej1410
    Help: 115
    Rate: 219
    1. For LEDs, 0.4 W per 1 liter of water
    2. What do you mean by the ratio of color to white? Do you mean that you want to keep a steady stream of light for different colors?
    3. You have to specify the parameters of all types of LEDs that you want to use, then we will help to count something.
    4. in accordance with this: http://www.krewetkomaniak.pl/poradniki/technologia/oswietlenie-akwarium-ile-wat-ile-lumenow you need 0.4 W per 1 liter of water.
    5. There is no unit like LM if you meant the unit "lumen", the designation looks like this: "lm"
    6. Why would we have colored LEDs not included in the principle of 30 lm per liter?
  • #3 17278864
    oczko100
    The guest who builds the led beams told me that the amount of light needed from the same counts. And the "colored diodes" are just an extension of the spectrum of light and should be up to 1/2 of all that is how we have 20 white is the number of colored up to 10. I'm more concerned to find out how it is calculated as it should be.
  • #4 17278876
    matej1410
    Help: 115
    Rate: 219
    how many liters does the tank have?
    Example (thought abbreviations):
    If it has 100 liters of aquarium, in accordance with the principle of 30lm per liter we need 3000 lumens for the entire aquarium.
    Assuming that the 1W diode has about 100lm, we need 30 LEDs with 1W and 100lm (white).
    If the spec says that the principle is that the white to color ratio is 2, then in this case you need in the end:
    -30 white LEDs with 1W power and 100lm stream
    -15 LEDs with 1W power (let us discuss here the stream)
  • #5 17279527
  • #6 17280197
    oczko100
    odalladoalla wrote:
    http://spectra.1023world.net/
    Check the spectrum, power and lumens,
    a bit of work as you know the manufacturer of diode modules, but it gives you concrete results and graphical imaging what we have created.
    I will not offend you for helping - somehow users of this forum use this button, they think that "they deserve the answer", which they can not find themselves.
    You did not help me in anything, I asked something else
  • #7 17280379
    yogi009
    Help: 850
    Rate: 2657
    Maybe the main question first. This is about the requirements of organisms living in the aquarium, or just about the proper visual effect?
  • #8 17280447
    willyvmm
    Help: 164
    Rate: 365
    Decide ... Either yes or yes. The power (W) only the luminous flux (lm) is irrelevant for LEDs. Ledy have very different effectiveness. One gives 50lm / W other 100lm / W.
    I approached the subject a bit differently. I bought a long "fluorescent lamp" led, 30W, 4500lm, 4000k, 150cm. I made it into 2 shorter pieces, everything was inherited and now illuminates the 112L aquarium.
    Plants seem to be satisfied visually also look good more naturally than with artificially cold LED light.
  • #9 17280782
    oczko100
    It is supposed to grow well because I have several tanks and I want to do all the LED lighting. I mean the general principles of building such lighting
  • Asking how many LEDs and how to arrange them
    #10 19929398
    Piotrek1902
    Level 4  
    Hello. I have a question, I want to make a power LED beam for the aquarium 60 × 30 × 40 72l.
    I bought the heatsink 16cm × 56cm, the LEDs I would like to use are: white 8500, 6500, full spectrum, white full spectrum, royal blue, deep red and a pair of green 1w LEDs.
    Now my question is how many diodes and how to arrange them. Lighting for moderately demanding plants fish. Thanks in advance for your help.
  • Requesting LED count and layout for 72 l aquarium
    #11 19933040
    Piotrek1902
    Level 4  
    Hello everyone, I'm new here. I have a question, I want to make a power led beam for the aquarium 60 × 30 × 40 72l.
    I bought the heatsink 16cm × 56cm, the LEDs I would like to use are: white 8500, 6500, full spectrum, White full spectrum, Royal blue, Deep red and a pair of green 1w LEDs.
The discussion revolves around calculating the appropriate LED lighting power for an aquarium, specifically focusing on the use of white, royal blue, deep red, and full spectrum LEDs. Users seek guidance on the optimal ratio of colored diodes to white LEDs, with suggestions indicating that colored LEDs should comprise up to half of the total number of white LEDs. The principle of 30 lumens per liter of water is debated, with clarification that colored diodes should be included in this calculation. Various users provide examples of their setups, emphasizing the importance of luminous flux and the effectiveness of different LED types. The conversation also touches on the specific requirements for lighting based on the needs of aquatic plants and fish.
