No Signal on Display Port: Windows 10, HP Nvidia Quadro M4000, Asus Sabertooth x99 - Driver Issue?
mblazkie 4488 4
  • #1 17279401
    mblazkie
    I would like to ask if anyone has encountered such a problem before. After installing windows 10 on PC (clean system) everything is fine and the system boots normally. Unfortunately, when I try to install drivers for the HP Nvidia Quadro M4000 the screen goes black. After restarting, you can normally see the control screen at startup, while when windows starts loading, HDMI displays a message about the lack of signal. Any idea to solve the problem? Asus Sabertooth x99 motherboard.
  • #2 17281921
    iagre
    Help: 213
    Rate: 281
    mblazkie wrote:
    HDMI displays no signal message
    Switch to a different connector (for example, DVI or VGA).
  • #3 17282072
    mblazkie
    Unfortunately, this option is not available. There is no integrated card on the motherboard and Nvidia Quadro has only 4xDP.
    Added after 1 [hours] 30 [minutes]:
    So far I have found a half solution. Before installing the drivers, I installed TeamViewer. It is true that after installing the HDMI drivers, it indicates no signal, but I can work remotely and everything is ok. All that's left now is to restore the signal to HDMI.
  • #4 17284148
    MiroLord
    Help: 83
    Rate: 172
    There are some eggs with DP port. It is about pin No. 20 in this port, used to power devices through the DP port (voltage + 3.3V).
    To connect the graphics card to the monitor via DP, it is safer to look for a 19-pin cable or disconnect pin No. 20 in the plug.
    HERE interesting thread on this topic, especially post # 50.
  • #5 17284234
    mblazkie
    Thanks for the help. I did some research because it bothered me and it turned out that it was a problem with the HDMI connector on the Eizo CS240 monitor. After connecting to another DP -> HDMI monitor everything works fine. So the topic is closed.
