HDMI + DisplayPort - The monitor connected to the laptop does not see the signal
julia7777 16878 8
  • #1 17960543
    julia7777
    hey, I bought a lenovo legion laptop, I wanted to connect a DELL monitor to it and it shows information on the ENTERING POWER SAVE MODE monitor.
    Lenovo windows 10 laptop (HDMI output) + DELL Monitor (DispalyPort output)
    DELL P1913S monitor - on the monitor I set the output to read from dispalyport
    I guess something in the configuration,
    when I enter the screen settings, I cannot see the screen, I click detect, there is information that it has not been detected.
    please give me some tips :) )
  • #2 17960619
    nomudrek
    Level 36  
    Help: 406
    Rate: 471
    What is a connected laptop and monitor? If it is the cable itself, it works only in one direction, i.e. it has an input from the Display port and the output is HDMI, it will work properly if we connect the HDMI output with a Display Port converter like the one in the link.
    https://www.x-kom.pl/p/415371-przejsciowka-gembird-adapter-hdmi-do-display-port-bialy.html
  • #3 17960643
    julia7777
    the laptop with the monitor is connected with the dispalyport hdmi cable, as I wrote, there is hdmi in the laptop and display port in the monitor, and this is the cable I have and it is connected anyway,
    Added after 9 [minutes]:
  • #4 17960670
    nomudrek
    Level 36  
    Help: 406
    Rate: 471
    This cable, as I wrote, only works the other way round, it is the Display port to HDMI cable. Please buy the adapter as provided in the link, otherwise it will not work. In the photo, it clearly says that it works as I wrote from Display port to HDMI.
    https://www.morele.net/adapter-av-gembird-ada...ayport-usb-a-hdmi-czarny-dsc-hdmi-dp-1795254/
  • #5 17960692
    julia7777
    I understand that for this adapter I will need a dispaly port -> display port cable?
    Added after 8 [minutes]:
    because from the adapter I will put the hdmi end to the laptop, and to the adapter on the other side I will insert the dispaly port and the same cable to the display port, I understand?
  • #6 17960880
    nomudrek
    Level 36  
    Help: 406
    Rate: 471
    Yes, you will need a Display port cable and the adapter has a USB plug, which you also need to connect to provide 5 V DC to 1 A.
  • #7 17960931
    julia7777
    Thank you very much for your help :)
    and I have a question because I heard that some laptops (graphics cards) cannot be connected to the monitor
    or to mine. lenovo legion y530 nvadia graphics card, are you sure you can?
  • #8 17961084
    nomudrek
    Level 36  
    Help: 406
    Rate: 471
    Due to the fact that only in the last post the laptop model was given according to its specification, it appears that there is one more possibility of connecting it to the monitor with a mini Display Port / Display Port cable.
    https://www.komputronik.pl/category/16709/kable-displayport-mini-displayport.html
    You can connect an additional monitor otherwise there would be no HDMI and Display Port sockets.
  • #9 17961801
    julia7777
    Ok super :) Thank you for the info, then I will look for this cable in the city today, there are actually other inputs but I did not know what they are for ;) )
    Added after 3 [hours] 18 [minutes]:
    thanks for your help, everything works :) greetings
The discussion revolves around a Lenovo Legion laptop not detecting a Dell P1913S monitor when connected via HDMI to DisplayPort. The user initially connected the devices using a cable that only works in one direction (DisplayPort to HDMI), leading to the monitor entering power save mode. Solutions suggested include using a proper HDMI to DisplayPort adapter and a DisplayPort cable to ensure compatibility. The user confirmed the need for a DisplayPort cable and adapter, and later reported successful connection after acquiring the necessary components.
