Excel VBA: Update Dynamic Data Range in PivotTable After Removing Duplicates & Columns
lili02103 5877 11
How can I keep a PivotTable's data source range stable after a macro removes duplicates and deletes unused columns from the source sheet?
The best fix is to stop using the PivotTable’s cached source sheet after deleting columns and instead copy the needed data to a separate worksheet, then build or refresh the PivotTable from that sheet [#16220782] Deleting columns in the sheet already used by the PivotTable can change the source range structure, so the PivotTable no longer keeps the original A:Q layout [#16220782] By keeping a dedicated data sheet for the PivotTable and re-copying only the required columns there, the source range stays consistent [#16220782]
  • #1 16220363
    lili02103
    At work, I extract a report in Excel with 35 columns (A-AI) and a variable number of rows. I created an Excel file to analyze this data, so one tab contains the pasted data and several other tables and pivot charts based on them. As not all columns from the report are needed by me, I created a macro that:
    - removes duplicates
    - removes unnecessary columns
    - Updates all pivot tables
    Finally, it obtains a table with 17 columns (A to Q) as the basis for the pivot tables. And here I have a problem.
    When I create a PivotTable, I have a data range: 'Data to analyze'! $ A $ 1: $ Q $ 229.
    Unfortunately, after uploading new data to the tab and running the macro, the scope changes to "Data for analysis"! $ A $ 1: $ G $ 697.
    Why does the table data range change (omit HQ columns)?
    The macro looks like this:
    Code: VBScript
  • #2 16220782
    JRV
    VBA, Excel specialist
    Help: 805
    Rate: 455
    Better to make a separate worksheet for PivotTable data and re-copy the data you want instead of deleting the columns that the PivotTable is already cached
  • #3 16235451
    lili02103
    Thank you very much. I did it and it works. I have one more question. I would like to sort data with a macro, but unfortunately I get an error. I have a table always structured in the same way, but the sheet in which it is located has different names. I tried to remove Worksheets ("reporting 01/27"), changed ActiveWorkbook.Worksheets ("reporting 01/27") to ThisWorkbook did nothing. How do I fix a macro to sorot data in the sheet it was included in, even if the name changes (reporting 27.01, reporting 28.01)?
    ActiveWorkbook.Worksheets ("reporting 01/27"). Sort.SortFields.Clear
    ActiveWorkbook.Worksheets ("reporting 27.01"). Sort.SortFields.Add Key: = Range (_
    "C2: C469"), SortOn: = xlSortOnValues, Order: = xlAscending, DataOption: = _
    xlSortNormal
    With ActiveWorkbook.Worksheets ("reporting 01/27"). Sort
    .SetRange Range ("A1: AI469")
    .Header = xlYes
    .MatchCase = False
    .Orientation = xlTopToBottom
    .SortMethod = xlPinYin
    .Apply
    JRV
    Help: 805
    Rate: 455
    instead of ActiveWorkbook.Worksheets ("reporting 27.01")
    simply ActiveSheet
    ps ThisWorkbook is the entire workbook in which the macro
  • #5 16258058
    lili02103
    Cool thanks. That's one more question. I would like to remove all spaces from column AE. But I have a bug with the command cell = Trim (cell) How can I fix it?
    Code: text
  • #6 16258101
    JRV
    Help: 805
    Rate: 455
    cell.text=trim(cell.text)
  • #7 16258169
    clubs
    Help: 629
    Rate: 406
    Or
    Code: VB.net
  • #8 16259240
    lili02103
    @JRV
    Mam błąd dotyczący linii cell.Text = Trim(cell.Text)
    Run time error „1004” Unable to set the text property of range class
    @clubs
    Mam błąd dotyczący linii .Value = Application.Trim(.Value)
    Run timer error “13” Type mismatch
  • #9 16259305
    JRV
    Help: 805
    Rate: 455
    zmien
    For Each cell In Columns("AE")
    na
    For Each cell In Columns("AE").cells
    clubs
    Help: 629
    Rate: 406
    Or
    Code: VB.net
  • #11 16260091
    lili02103
    clubs wrote:
    Or
    Code: VB.net
    Thank you both, but only the macro above works.
  • #12 16261859
    clubs
    Help: 629
    Rate: 406
    It will also work, but in this form
    Code: VB.net
    I just don't know why you refer to the entire AE column, where in Excel 2010 there are 1048576 rows and the macro has to "grind" the whole range, it is better to set a specific range or the range used, then the macro will work much faster
The discussion revolves around an Excel VBA macro designed to process a report with 35 columns by removing duplicates and unnecessary columns, ultimately creating a PivotTable with a reduced data range. The user encounters an issue where the data range for the PivotTable changes unexpectedly after running the macro. Suggestions include creating a separate worksheet for PivotTable data to avoid caching issues and using `ActiveSheet` instead of specific worksheet names to handle variable sheet names. Additional queries involve sorting data and removing spaces from a specific column, with various solutions provided for handling errors in the macro code.
