[Solved] - The computer cannot see the NVIDIA GeForce GT 630 graphics card
Arkadiusz op 9381 7
  • #1 17289055
    Arkadiusz op
    Well, the matter is painted like this ... The graphics card has been bad for me for some time. After 15 minutes of using the computer, the screen began to go crazy, then for 1 second blackscreen appeared and everything was back to normal and in the corner I was notified that the graphics card drivers had stopped working and regained efficiency. And so non-stop.
    Until one day I turned on the computer, loading Windows then this inscription Welcome! And bluescreen. And so every time. Finally I started the computer but it was the same as before.
    I disconnected the graphics card and decided to use the integrated one. The computer was working but so I plugged the card back. I connected the VGA cable to the card. The computer turned on normally but when I look at what graphics card I have, nothing is displayed. I can't start any games because I don't think I have DirectX on my computer. I was restoring the BIOS to factory settings and nothing. The fan on the card is working. I forgot to mention that when I turn on the computer with the graphics card, at the very beginning I get the inscription: NVIDIA corporation GeForce GT 630 VGA. I tried to upload the drivers but they can't find the card.
    Thank you in advance for your help!
  • #2 17289067
    meaverick
    Help: 112
    Rate: 245
    Disable the integrated graphics card in the bios, run in safe mode F8 at startup, restore or uninstall drivers. The graphics card will automatically find the standard windows and then install the original from the board. I do not know what the motherboard is, but there is one more set in booting devices in the bios order set to PCI expres port I do not know what you have there.
  • #3 17289072
    Arkadiusz op
    Unfortunately I don't have a tile
  • #5 17289080
    Arkadiusz op
    I downloaded and it's only a game driver
  • #6 17289084
    meaverick
    Help: 112
    Rate: 245
    What system are you on?
    310artur
    Help: 980
    Rate: 671
    After symptoms, the card is dead - now it works only as a standard card compatible with VGA. To be sure, you could check it on another PC. What does the GPU-Z program show anyway?
  • #8 17314952
    Arkadiusz op
    Thank you for your help. I checked on another computer and the card responds the same. Verdict: the card is burned. Thank you again. I consider the topic closed.
The user experienced persistent issues with their NVIDIA GeForce GT 630 graphics card, including driver failures and blue screens. After switching to the integrated graphics, they found that the computer functioned normally, but the dedicated card was not recognized. Suggestions included disabling the integrated graphics in BIOS, running in safe mode, and reinstalling drivers. Ultimately, the user tested the card in another PC, confirming it was non-functional and likely burned out.
