Computer Won't Start, Blue Screen - Win 7 Pro, GeForce GTS 250, ASUS P5QPL, Intel Core 2 Duo
Dziulekk 10374 8
  • #1 16840579
    Dziulekk
    Welcome.
    Again I am struggling with the problem of pcta firing, but now it is a different case as recently.
    Now when I start pcta, a blue screen appears to me and nothing else happens. The computer seems to attach, but neither welcome Windows sounds nor any "control" (?) From the motherboard.
    At first I thought that the graphics card could have been burned, but would not it be the sound from the motherboard (two signals or something like that?)
    I hope that this is not the fault of the motherboard or graphics card, because it is not a small expense ...
    Win 7 professional 32b
    GeForce GTS 250 graphics card
    ASUS p5qpl motherboard
    Proce intel core 2 duo e440 (2.44GHz) (something like that)
    MODECOM FEEL III-400ATX power supply
  • #2 16840645
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    You write in the Hardware Hardware section - you do not specify the hardware specifications - fill in.
    Is there a bluescreen with Windows subtitles or a uniformly blue screen without subtitles? POST is performing? Can you enter the BIOS settings?
  • #3 16840650
    Kasek21
    Help: 4981
    Rate: 3547
    Control Panel-> System-> Advanced-> Recovery and Run-> Unhide Automatically restart.
    When starting the system, press the F8 key - after the selection option appears, select:
    Disable automatic restart of the computer after a system failure.
    Full computer configuration, including the make and model of the power supply ?!
  • #4 16840685
    Talibanczyk
    Conditionally unlocked
    Help: 115
    Rate: 75
    1. You changed the screen / monitor ??
    2. Have you checked on another cable ??
    3. The motherboard has an integrated graphics - if so, did you connect without an additional graphics card ??
    4 Do you have Beeper ?? you may not have it on the motherboard and you do not have any sound for it.
    5. The blue screen itself ... weird ... with some words - upload a photo
    So far, no data to help in diagnosis
  • #5 16840779
    Dziulekk
    I can not enter any settings. After starting the pct, the screen looks like a 'backlight' (black is getting dark blue). The control lamp on the orange monitor changes to blue, which means that the monitor works.
    "lights" on the reset shine naturally, as always when firing a pct. - a moment both (green and red, then red disappears and stays alone green)
    I always had Beeper.
    I did not change the monitor or anything at the PC.
    I do not know if the motherboard has an integrated graphics card.
  • #6 16840940
    Kasek21
    Help: 4981
    Rate: 3547
    Yes.
  • #7 16841021
    Dziulekk
    So how do I run pcta with this integrated card?
  • #8 16841026
    Kasek21
    Help: 4981
    Rate: 3547
    Remove your graphics card and connect the monitor to the D-Sub connector on the back of the computer.
  • Suspect GTX 1050 Ti as the fault source
    #9 19394555
    kosarro
    Rate: 17
    buddy, I have a question: have you found out what the problem is. I have similarly with my gtx 1050 ti, i.e. after turning on the computer, the screen backlight changes from black to blue, but there is no image. In addition, the monitor reports an active signal on the input, but there is no image of any kind, even a post, and at the same time no whore signal with an error. my computer works normally when I insert another graphics card.
The user is experiencing a blue screen issue when starting their computer, which features Windows 7 Professional, a GeForce GTS 250 graphics card, an ASUS P5QPL motherboard, and an Intel Core 2 Duo processor. Initial troubleshooting suggests checking for POST completion and BIOS access, as well as verifying the monitor and cable connections. The user cannot access settings and reports a blue screen without any error messages. Suggestions include removing the graphics card and using the motherboard's integrated graphics, if available. Another user shares a similar experience with a GTX 1050 Ti, indicating potential graphics card failure as a common issue.
