[Solved] Internet - Download Error - Cannot download anything from the Internet
Masakra93 34659 13
How can I re-enable the antivirus scan so downloads stop failing with "Failed - anti-virus scan failed" in Windows 10?
Yes — open regedit and change `HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Attachments\ScanWithAntiVirus` from `3` to `1`; that restored downloading in this thread [#17296854] The problem was affecting all browsers, not just one, and after the registry change the files downloaded normally again [#17297813]
  • #1 17295863
    Masakra93
    Rate: 74
    I have such a problem ... the point is that I can't download anything from the Internet ... the problem is probably windows defender which I have somehow turned off and now it cannot be turned on again. When downloading, no matter what file, the message "Failed - anti-virus scan failed" pops up. Is there any way to activate this antivirus through the registry or some other way? If I downloaded another antivirus, would it work and I would be able to download files?
  • #3 17295951
    Masakra93
    Rate: 74
    Windows 10
    I did a scan:
    Malwarebytes
    www.malwarebytes.com
    -Report Details-
    Scan date: 2018-06-25
    Scanning time: 14:56
    Report file: 1d5434e4-7877-11e8-9507-d8cb8a3af6e5.json
    Administrator: Yes
    -Software Information-
    Version: 3.5.1.2522
    Component version: 1.0.374
    Current package version: 1.0.5615
    License: Trial version
    -System Information-
    Operating System: Windows 10 (Build 17134.112)
    Processor: x64
    File System: NTFS
    User: MASAKRA \ artur
    -Scan results-
    Scan Type: Full Scan
    Scan initiated by: Manual
    Result: Completed
    Scanned objects: 282 491
    Detected threats: 15
    Quarantined threats: 15
    Elapsed time: 1 min, 26 sec
    -Scan options-
    Memory: Enabled
    Autostart: Enabled
    File System: Enabled
    Archives: Enabled
    Rootkits: Disabled
    Heuristics: Enabled
    PUP: Detection
    PUM: Detection
    -Scan Details-
    Process: 0
    (No threats detected)
    Module: 0
    Registry key: 1
    PUP.Optional.DriverPack, HKU \ S-1-5-21-1824133134-2437128005-3068380628-1001 \ SOFTWARE \ MICROSOFT \ WINDOWS \ CURRENTVERSION \ INTERNET SETTINGS \ ZONEMAP \ DOMAINS \ drp.su, Added to Quarantine, [886] , [472299], 1.0.5615
    Registry value: 0
    Registry data: 0
    Data stream: 0
    Folder: 0
    File: 14
    Adware.Linkury.Generic, C: \ USERS \ ARTUR \ APPDATA \ LOCAL \ SHAM.DB, Added to Quarantine, [3750], [516191], 1.0.5615
    Adware.Elex.ShrtCln, C: \ USERS \ ARTUR \ APPDATA \ LOCAL \ GOOGLE \ CHROME \ USER DATA \ Default \ Sync Data \ SyncData.sqlite3, Replaced, [246], [454721], 1.0.5615
    Adware.Elex.ShrtCln, C: \ USERS \ ARTUR \ APPDATA \ LOCAL \ GOOGLE \ CHROME \ USER DATA \ Default \ Secure Preferences, Replaced, [246], [454721], 1.0.5615
    Adware.Elex.ShrtCln, C: \ USERS \ ARTUR \ APPDATA \ LOCAL \ GOOGLE \ CHROME \ USER DATA \ Default \ Sync Data \ SyncData.sqlite3, Replaced, [246], [454693], 1.0.5615
    Adware.Elex.ShrtCln, C: \ USERS \ ARTUR \ APPDATA \ LOCAL \ GOOGLE \ CHROME \ USER DATA \ Default \ Secure Preferences, Replaced, [246], [454693], 1.0.5615
    Adware.MailRu.BatBitRst, C: \ USERS \ ARTUR \ APPDATA \ LOCAL \ GOOGLE \ CHROME \ USER DATA \ Default \ Sync Data \ SyncData.sqlite3, Replaced, [297], [481467], 1.0.5615
    Adware.MailRu.BatBitRst, C: \ USERS \ ARTUR \ APPDATA \ LOCAL \ GOOGLE \ CHROME \ USER DATA \ Default \ Secure Preferences, Replaced, [297], [481467], 1.0.5615
    PUP.Optional.DriverPack, C: \ USERS \ ARTUR \ DOWNLOADS \ DRIVERPACK-17-ONLINE_1996410657.1526502870.EXE, Added to Quarantine, [886], [354275], 1.0.5615
    Adware.Elex.ShrtCln, C: \ USERS \ ARTUR \ APPDATA \ LOCAL \ GOOGLE \ CHROME \ USER DATA \ Default \ Sync Data \ SyncData.sqlite3, Replaced, [246], [454717], 1.0.5615
    Adware.Elex.ShrtCln, C: \ USERS \ ARTUR \ APPDATA \ LOCAL \ GOOGLE \ CHROME \ USER DATA \ Default \ Secure Preferences, Replaced, [246], [454717], 1.0.5615
    Adware.Elex.ShrtCln, C: \ USERS \ ARTUR \ APPDATA \ LOCAL \ GOOGLE \ CHROME \ USER DATA \ Default \ Sync Data \ SyncData.sqlite3, Replaced, [246], [454752], 1.0.5615
    Adware.Elex.ShrtCln, C:\USERS\ARTUR\APPDATA\LOCAL\GOOGLE\CHROME\USER DATA\Default\Secure Preferences, Zastąpiono, [246], [454752],1.0.5615
    Sektor fizyczny: 0
    (Nie wykryto zagrożeń)
    WMI: 0
    (end)
    A tu z clenera
    # Malwarebytes AdwCleaner 7.2.0.0
    # Build: 06-05-2018
    # Database: 2018-06-25.3
    # Support: https://www.malwarebytes.com/support
    # Mode: Scan
    # Start: 06-25-2018
    # Duration: 00:00:07
    # OS: Windows 10 Pro
    # Scanned: 41265
    # Detected: 0
    ***** [ Services ] *****
    No malicious services found.
    ***** [ Folders ] *****
    No malicious folders found.
    ***** [ Files ] *****
    No malicious files found.
    ***** [ DLL ] *****
    No malicious DLLs found.
    ***** [ WMI ] *****
    No malicious WMI found.
    ***** [ Shortcuts ] *****
    No malicious shortcuts found.
    ***** [ Tasks ] *****
    No malicious tasks found.
    ***** [ Registry ] *****
    No malicious registry entries found.
    ***** [ Chromium (and derivatives) ] *****
    No malicious Chromium entries found.
    ***** [ Chromium URLs ] *****
    No malicious Chromium URLs found.
    ***** [ Firefox (and derivatives) ] *****
    No malicious Firefox entries found.
    ***** [ Firefox URLs ] *****
    No malicious Firefox URLs found.
    AdwCleaner[S00].txt - [4158 octets] - [25/06/2018 14:54:14]
    AdwCleaner[C00].txt - [3812 octets] - [25/06/2018 14:54:33]
    AdwCleaner[S01].txt - [1363 octets] - [25/06/2018 15:01:30]
    ########## EOF - C:\AdwCleaner\Logs\AdwCleaner[S02].txt ##########
    Zeskanowane, niestety problem jest dalej.
  • #5 17296054
    Masakra93
    Rate: 74
    Scan from this program
    • FRST.txt (100.28 KB) You must be logged in to download this attachment.
  • #6 17296087
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    One more addition!
  • #7 17296089
    Masakra93
    Rate: 74
    Addition please
    • Addition.txt (52.9 KB) You must be logged in to download this attachment.
  • #8 17296419
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Next to frst.exe, create a Fixlist.txt file with the contents:
    HKLM \ SOFTWARE \ Policies \ Microsoft \ Windows Defender: Restrictions
  • #9 17296448
    Masakra93
    Rate: 74
    I do not know if I did everything correctly, but I made the file, entered it all, the program repaired ... but unfortunately I still can't download anything because there is a failure at the very end (scanning ...)
    The result of repairing Farbar Recovery Scan Tool (x64) Version: 20/06/2018
    Started by artur (06/25/2018 19:53:23) Run: 2
    Run from F: \
    Uploaded profiles: artur (Available profiles: artur)
    Start Mode: Normal
    fixlist - content:
    HKLM \ SOFTWARE \ Policies \ Microsoft \ Windows Defender: Restrictions successfully removed
    C: \ AdwCleaner => successfully transferred
    C: \ ProgramData \ Arcabit => successfully transferred
    C: \ ProgramData \ mks_vir => successfully transferred
    C: \ Users \ artur \ AppData \ Local \ installer.dat => successfully transferred
    ==== End of Fixlog 19:53:23 ====
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    This message is displayed in all browsers IE, Firefox, Chrome? Or only Chrome?
    If only in Chrome, download the bookmarks, uninstall Chrome and delete the profile directory from C: \ Users \ artur \ AppData \ Local \ Google \ Chrome \ User Data \ Default, reinstall Chrome after it is done.
  • #11 17296833
    Masakra93
    Rate: 74
    Ie. this message was from this program, and unfortunately I have a problem with downloading on every browser.
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Run regedit, go to HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows \ CurrentVersion \ Policies \ Attachments and change "ScanWithAntiVirus" (REG_DWORD type) from 3 to 1
  • #13 17297813
    Masakra93
    Rate: 74
    Thanks, it finally works and I can download files.
  • #14 17297815
    Masakra93
    Rate: 74
    Added after 50 [seconds]:
    All methods are fast and at the end a change in the register, as my colleague suggested.
The user reported an issue with downloading files from the Internet, suspecting that Windows Defender was disabled and could not be reactivated. The error message "Failed - anti-virus scan failed" appeared during downloads. Various solutions were proposed, including scanning the system with Malwarebytes and using the Farbar Recovery Scan Tool (FRST) to generate logs for further analysis. A registry modification was suggested to change the "ScanWithAntiVirus" setting from 3 to 1, which ultimately resolved the issue, allowing the user to download files successfully.
TL;DR: 15 threats were quarantined, yet downloads still failed [Elektroda, Masakra93, post #17295951] The fix: "Change 'ScanWithAntiVirus' from 3 to 1" in the registry [Elektroda, Kolobos, post #17296854]; success confirmed [Elektroda, Masakra93, post #17297813] For Windows 10 users facing "antivirus scan failed" across browsers.
Why it matters: This resolves system-wide download failures caused by Attachment Manager policy conflicts without reinstalling Windows.
  • Registry fix: HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Attachments → ScanWithAntiVirus (REG_DWORD) = 1 [Elektroda, Kolobos, post #17296854]; see Windows Attachment Manager policy reference “Windows Attachment Manager”.
  • Malwarebytes scan example: 282,491 objects scanned, 15 threats quarantined, ~1m26s runtime on Windows 10 build 17134.112 [Elektroda, Masakra93, post #17295951]
  • Chrome-only fallback: remove profile at C:\Users\\AppData\Local\Google\Chrome\User Data\Default and reinstall Chrome [Elektroda, Kolobos, post #17296458]
  • Group Policy can reapply settings about every 90 minutes (+0–30 min offset) in domain environments “Group Policy refresh interval”.
  • Cleanup tools referenced: Malwarebytes (trial available) [Elektroda, Masakra93, #17295951; Malwarebytes]; AdwCleaner is free “Malwarebytes AdwCleaner”.
Why do I get "Failed  antivirus scan failed" for every download on Windows 10?
Windows uses Attachment Manager to notify antivirus when saving downloads. A mis-set ScanWithAntiVirus policy can break this handoff and block downloads in all browsers [Elektroda, Kolobos, #17296854; “Windows Attachment Manager”]. In the thread, changing ScanWithAntiVirus to 1 fixed the issue immediately [Elektroda, Masakra93, post #17297813]
How do I fix it fast via the registry?
Three steps: 1. Open regedit as admin. 2. Go to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Attachments. 3. Set ScanWithAntiVirus (REG_DWORD) to 1, then reboot [Elektroda, Kolobos, post #17296854] "Run regedit, and change 'ScanWithAntiVirus' from 3 to 1" [Elektroda, Kolobos, post #17296854] Back up the registry first “Back up the registry”.
Did this registry change actually work for the OP?
Yes. After setting ScanWithAntiVirus from 3 to 1, the OP confirmed downloads worked again: “Thanks, it finally works” [Elektroda, Masakra93, #17297813; #17297815].
How do I run Malwarebytes and AdwCleaner like in the thread?
Install Malwarebytes, run a full scan, and quarantine findings; example: 282,491 objects scanned, 15 threats quarantined [Elektroda, Masakra93, post #17295951] Then run AdwCleaner; it should report none if clean [Elektroda, Masakra93, post #17295951] Tools: Malwarebytes (trial), AdwCleaner (free) [Malwarebytes; “Malwarebytes AdwCleaner”].
What if the registry value keeps reverting to 3?
A Group Policy might enforce the setting. Check Local/Domain policy: Windows Components → Attachment Manager → Notify antivirus programs when opening attachments “Windows Attachment Manager”. Domain policies refresh about every 90 minutes plus a random offset “Group Policy refresh interval”. Edit the policy or ask IT.
Can leftover thirdparty antivirus cause this?
Yes. Remnants can set restrictive policies. The FRST fix removed Arcabit and mks_vir traces and cleared Defender policies, yet downloads still failed until ScanWithAntiVirus was corrected [Elektroda, Kolobos, #17296419; Masakra93, #17296448].
How do I try the FRST approach shown in the thread?
Download FRST, run scans (FRST.txt and Addition.txt), then use a tailored Fixlist from a trusted helper [Elektroda, Kolobos, post #17296005] In the thread, a fixlist cleared Defender policy keys and leftovers, but the final fix was the Attachments value [Elektroda, Kolobos, #17296419; Masakra93, #17296448].
Is there a Group Policy (GUI) way instead of editing the registry?
If available, open gpedit.msc. Go to User Configuration → Administrative Templates → Windows Components → Attachment Manager. Set “Notify antivirus programs when opening attachments” to Enabled “Windows Attachment Manager”. This corresponds to ScanWithAntiVirus = 1 [Elektroda, Kolobos, post #17296854]
Will installing another antivirus fix blocked downloads?
Not necessarily. If Attachment Manager cannot notify any AV due to policy, downloads fail regardless of product [Elektroda, Kolobos, #17296854; “Windows Attachment Manager”]. Correct the ScanWithAntiVirus value first [Elektroda, Masakra93, post #17297813]
Any precautions before editing the registry?
Create a restore point and export the key. Editing the registry incorrectly can cause system issues “Back up the registry”. Use an admin account and document changes [Elektroda, Kolobos, post #17296854] Edge case: corporate EDR or policy may block changes “Group Policy refresh interval”.
