Windows 10 Defender Not Working: Protection Managed by Your Organization Issue Fix
Showbiz32 6510 2
  • #1 17293125
    Showbiz32
    Rate: 81
    Hello. Windows installed freshly. The red inscription "protection against viruses and threats is managed by your organization" what to do about it?
    • Windows 10 Defender Not Working: Protection Managed by Your Organization Issue Fix 33.jpg (57.27 KB) You must be logged in to download this attachment.
    • Windows 10 Defender Not Working: Protection Managed by Your Organization Issue Fix 22.jpg (93.03 KB) You must be logged in to download this attachment.
    • Windows 10 Defender Not Working: Protection Managed by Your Organization Issue Fix 11.jpg (8.54 KB) You must be logged in to download this attachment.
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    Welcome. Under normal circumstances, please contact the administrator who manages the equipment. If this is private equipment - it is worth mentioning whether the software was not run on it, which, in the simplest way, describes the privacy of the user, eliminates telemetry or optimizes Windows in general. In such software, it is often possible to disable the defender, usually an entry in the policies, which results in such a message.
    You can do an FRST scan and upload logs, maybe you can create a fixlist that will unlock it.
  • #3 17293652
    Showbiz32
    Rate: 81
    dt1 wrote:
    eliminates telemetry or generally optimizes Windows. In such software, it is often possible to disable the defender, usually an entry in the policies, which results in such a message.
    I used an application to optimize Windows :) I have undone the changes and it is already working :) here is the link https://winclub.pl/topic/2449-windows-vista78...iedzy-i-telemetria-won-optymalizacja-windows/
