[Solved] Windows 10: Permanently Disable Proxy & Avoid Browser Crashes - Network Settings & Registry
mikro1551 6792 4
  • #1 17296767
    mikro1551
    Level 4  
    Will anyone help me permanently disable proxy in windows 10? The problem is that after switching to the browser crashes with a proxy server (nothing was previously buried in the settings). I enter the network settings and uncheck the proxy server. Everything works as it should, but the problem lies in the fact that after restarting it is the same, you must turn off the proxy again. Anyone have an idea how to permanently turn it off. I tried by modifying the registry, but it is the same as if I turned off the proxy in the settings.
  • #3 17296940
    mikro1551
    Level 4  
    Scanning with AdwCleaner did not bring any results. In the attachment I am sending logs from FRST.
    • FRST.txt (108.91 KB) You must be logged in to download this attachment.
    • Addition.txt (46 KB) You must be logged in to download this attachment.
  • #4 17297000
    Kolobos
    IT specialist
    Help: 17167
    Rate: 10448
    I have not written anywhere that using adwords will change something.
    Uninstall Amazon 1Button App
    Next to frst.exe, create the Fixlist.txt file with the contents:
    Task: {4142DBD5-969B-4532-984D-3C7760BCEE10} - \ Microsoft \ Windows \ Setup \ GWXTriggers \ MachineUnlock-5d -> No file No file No file No file No file No file No file No file No file No file No file No file No file C: \ Program Files (x86) \ Amazon \ Amazon1ButtonApp \ AmazonExtIE64.dll [119616 2014-09-26] (Amazon Inc. )
    ProxyEnable: [.DEFAULT] => Proxy [function enabled]
    ProxyServer: [.DEFAULT] => 127.0.0.1:1080
    ProxyServer: [S-1-5-21-1325904171-3701100373-1396668553-1001] => 127.0.0.1:1080
    ManualProxies: 1127.0.0.1:1080
    RemoveProxy:
    HKLM \ Software \ Microsoft \ Internet Explorer \ Main, Start Page = about: blank
    HKU \ S-1-5-21-1325904171-3701100373-1396668553-1001 \ Software \ Microsoft \ Internet Explorer \ Main, Default_Page_URL = hxxp: //lenovo13.msn.com/? Pc = LCJB
    HKU \ S-1-5-21-1325904171-3701100373-1396668553-1001 \ Software \ Microsoft \ Internet Explorer \ Main, Secondary Start Pages = hxxp: //mystart.lenovo.com
    SearchScopes: HKU \ S-1-5-21-1325904171-3701100373-1396668553-1001 -> DefaultScope {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL = hxxp: //www.bing.com/search? PC = WCUG & FORM & WCUGDF = q = {} searchTerms
    SearchScopes: HKU \ S-1-5-21-1325904171-3701100373-1396668553-1001 -> {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL = hxxp: //www.bing.com/search? PC = WCUG & FORM = WCUGDF & searchTerms q = {}
    SearchScopes: HKU \ S-1-5-21-1325904171-3701100373-1396668553-1001 -> {A6A34092-C435-420A-B9B5-18353D2FEA0A} URL =
    CHR HKLM-x32 \ ... \ Chrome \ Extension: [nlnpeeaafijaebcdgkdeojkpnkfkjdnh] - hxxps: // clients2.google.com / service / Update2 / crx
    R2 A3F8C979; C: \ ProgramData \ A3F8C979 \ A3F8C964.dll [2745360 6/22/2018] () [No digital signature]
    2018-06-25 22:44 - 2018-06-25 22:46 - 000000000 ____D C: \ AdwCleaner
    2018-06-22 08:53 - 2018-06-25 22:48 - 000000000 ____D C: \ ProgramData \ A3F8C979
    In FRST, select Repair.
    Delete the C: \ FRST directory after execution and that's all.
  • #5 17297034
    mikro1551
    Level 4  
    Thank you for your help. Everything is working fine now.
