samsung galaxy J7 - Unable to turn on after fall, strange reactions
artek 04 4980 6
  • #1 17301753
    artek 04
    Rate: 27
    Hello, dear group.
    I have a problem with the samung galaxy J7 2017
    Well, after the fall, the display is broken, but you cannot turn it on, you can feel vibrations every now and then, and the loudspeaker speaks (but not a signal, for example, only a hum for a moment) and vibration again and then hum, and so on, alternately until the battery is discharged.
    What can be wrong with him, except of course the display?
    Best regards.
  • #2 17301877
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    You won't know without changing the display. How do you connect to a computer, it detects it?
  • #3 17301910
    artek 04
    Rate: 27
    Unfortunately, the computer does not see it.
  • #4 17301924
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    So after the fall, the motherboard could also be damaged (cracks or cold February), at the beginning a new LCD to try to fix something.
  • #5 17301952
    artek 04
    Rate: 27
    Well, I just don't know if it's worth buying a new lcd in case the motherboard is damaged because I don't know if it will be profitable.
  • #6 17302062
    nutergsm
    Help: 1034
    Rate: 1665
    Then go to some local service, maybe they will have the LCD to be replaced and check if something else is damaged.
  • #7 17302109
    artek 04
    Rate: 27
    Ok, thank you, I guess I will.
The user reports issues with their Samsung Galaxy J7 (2017) after a fall, including a broken display and inability to power on, although vibrations and sounds are intermittently present. Responses suggest that the display likely needs replacement, but there is concern about potential motherboard damage. The user is advised to visit a local service center for diagnostics and possible LCD replacement to determine if other components are affected.
