Suzuki Burgman AN400 K1 1999 Won't Start: Possible Carburetor Issue? Engine Cranks, Fuel Smell
marco74_2005 17454 11
Why does the Burgman AN400 crank, smell of fuel, and only start intermittently when the carburetor is moved?
In this thread, the starting problem was ultimately caused by a bad battery, and replacing it fixed the scooter [#17320923] With the new battery, charging stayed steady at about 14.4 V, while the old battery was unstable and the engine cranked more and more slowly, so the battery was the main culprit rather than the carburetor [#17320923] The charging system still deserves attention: the regulator connector cube was suggested for replacement, and a reading jumping to 17 V was considered worrying [#17312311] [#17322162] If starting issues remain, the advice was to clean the carburetor, set the fuel level correctly with a transparent hose, check the float/needle and choke, and look for left air, spark plug, or air filter problems [#17305891] [#17310518] [#17322162]
  • #1 17303387
    marco74_2005
    Rate: 13
    Hello!
    I am looking for information on what may be the reason why the Burgman AN400 engine, version K1, manufactured in 1999, does not start. The engine spins and does not start. Sometimes the fuel smells like fuel and it doesn't start anyway.
    Initially, I thought the problem was with the battery, but even after connecting the charger, it also did not start.
    If I shake the carburetor it will catch and fire sometimes.
    Is the problem on the carburetor's side, that something hangs in it and fires and fails?
    It's starting to annoy me and I'm afraid of it wherever I go.
    regards
    marco74_2005
  • #2 17305891
    Junior188
    Help: 6
    Rate: 22
    If I get caught after moving the carburetor, I would bet on a fuel float. You have to strip, clean, set the height, the task is rather difficult to act on your own, high precision and full tightness of the system are required. From home methods, you can pour some fuel on the pistons (candle hole) a few drops is enough when it starts with a sign that it is something wrong with the fuel mixture, but if you say that fuel stinks, it can flood it, so first it would be appropriate to cut off the fuel supply by e.g. taking out carburetor or shutting off the fuel tank and draining it from the carburetor. And when was the last time you serviced this carburetor?
  • #3 17307833
    marco74_2005
    Rate: 13
    Hello!
    I took the carburetor apart and simply put it back together, I didn't notice any specific flaws. The engine fired, but it does not revolve and the electrode in the candle made you black (and it was clean) is sooty. Too rich mixture? Though I didn't regulate any nozzles. Could it be that the needle with the diaphragm is hanging?
    Today, if I succeed, I will disassemble the carburetor one more time and look at it more closely, maybe I'll spot something. And I will come back in info.
    regards
    marco
  • #4 17308049
    Junior188
    Help: 6
    Rate: 22
    Disassembling the carburettor and reassembling it with the old gaskets while maintaining full tightness is a very rare case ;) Candles work well after driving 6-10 km, it just needs to burn out before it changes color.
  • #5 17308157
    marco74_2005
    Rate: 13
    Hello. You are absolutely right. but I have to bring him to such a state that he will travel a few km to the site. And since I didn't play with the nozzles, it must be something with a float or a spike.
    Although the float seemed to be tight to me, the problem must generally be with the needle.
    Maybe I can take a few photos and post it.
    regards
    marco
  • Check carb fuel level with clear hose test
    #6 17308806
    Junior188
    Help: 6
    Rate: 22
    If you are sure that you want to do it yourself, I will advise you as well as I can how to do it myself. However, remember that you do everything at your own risk. The issue of float leakage you would definitely notice, we are talking about a float chamber, of course, you would see it and feel it for sure. You need to find a service and check what the fuel level should be, it's easy, just put a transparent hose on the drain valve, unscrew the screw and use the right connected vessels to determine the fuel level and compare what is recommended with what you have.
    Below, more vividly.
  • Voltage rises with revs, suggesting charging issue
    #7 17309789
    marco74_2005
    Rate: 13
    Yesterday I turned the carburetor on again. All membranes are intact, i.e. not torn or broken. The float is tight, the spike is working. I put everything together: it fired, it idled nicely, but every now and then it went out by itself. (here I think I must set the idle speed of the engine very precisely).
    I changed for a test drive and the "meatball" - the engine does not turn on. After turning the handle, it goes out (probably a problem with the fuel, too much), but after a few attempts, it was possible to start and increase the speed. But the turnover was not even. The engine was interrupting, I had to hold the revolutions while driving to keep it from going out.
    Is it an electrical problem or fuel again?
    So maybe it's a voltage regulator? Maybe you know how to recognize the symptoms of a damaged regulator? Because when I connected the meter after starting the engine and added gas, the voltage increased, when I turned on the lights, the voltage dropped. Shouldn't he keep the tension evenly no matter what's on?
    The second thing is the battery, I have to buy a new one because it is already working poorly. What do you recommend, company or some replacement?
    I know anything can be the cause, but knowing life, it's probably a bullshit. Maybe a worn electrical harness is making a short circuit, or maybe something else.
    I'll try this hose and determine the fuel level.
    Regards.
    Marco
  • #8 17310518
    Junior188
    Help: 6
    Rate: 22
    First, buddy, we need to control the chaos ;) One by one, methodically, not blindly and little by little, because then you will need a surgeon, not a mechanic.
    1. Such symptoms can be caused by:
    a) bad regulation of the mixture composition - difficult to define at home
    b) left air - take a car star, place a different flammable spray and spray the carburetor on a fired engine and look if you spray somewhere, the revs do not change, usually they increase. If so, you have a so-called leak. left air.
    c) the timing was changed - but we will leave it for now
    d) bad clearance on the valves as above
    e) lack of proper compression - but I understand that you do not have a device to measure it?
    f) problem on the air flow line - clean the filter and replace it if it is more than two years old
    2. As for the electrics:
    a) check the condition of the candle and the quality of the spark - the candle has no defects and the gap is in accordance with the manufacturer's data (do you have a feeler gauge?)
    b) to check charging, it is best to start with the battery - connect the meter as it is 13.6 - 14.5 it is ok (the measurement should be carried out on a good battery) you wrote that yours is weak so it is possible that it will be a little less. If the above values are not caught, then from the regulator to the so-called There are 3 wires in one color, usually yellow, you set the measurement to 230 alternating current and measure all 3. when taking measurements because it can hurt ;) )
    c) the drop in charging voltage on running lights, i.e. under load, is a natural phenomenon and there is nothing to look for here ;)
    In conclusion, first you need to clean the carburetor, set the correct fuel level, adjust it carefully. If the problem persists, continue looking. Unfortunately, it is very rarely possible to immediately pinpoint the cause of a failure. Follow the thread to the ball and without jerky movements ;) , remember to measure the drill 5 times hehe.
  • #9 17311392
    marco74_2005
    Rate: 13
    Hello!
    After my stay in the garage yesterday:
    1.Regarding the engine not turning over: I fumbled on the net and it turned out that I incorrectly installed the firing pin under the black plastic lid. When I assembled ok and I managed to start it, the engine worked like a dream. - one case excluded.
    I changed and went for a test drive: I drove with 10 km, sometimes at full speed, everything looked ok and I turned off under the garage. Another attempt to fire was unsuccessful. and what a disguise again and a scooter. I connected the rectifier and started spinning and nothing, the fuel does not smell. I was moving the carburetor I started to spin it smelled fuel. - maybe something with a fuel pump? although when I remove the fuel hose and turn the ignition on, the fuel flies.
    There are two hoses to the carburetor:
    - such with a white tip and with a spring and with a needle. What is he for? trying to measure the resistance on the leads gave no result when moving the needle.
    - the second black tip - is attached to the throttle. is it from automatic choke?
    2. on electrics. when I checked the spark on the candle, I noticed that between the single flashes of the spark, from time to time there is a flash around the circumference of the entire electrode. I replaced it with another candle and it is the same.
    3. I generally decided to get a new battery today. because yesterday evening around 9 p.m. the voltage was 13.5V and this morning it was 12.5V, during firing this morning the voltage dropped to 10.2V. and spun slower and slower. as I connected the rectifier, the current to max. it fired the first time. maybe that's the root cause.
    4.As for the valves, I have never adjusted them, and I have had the scooter for three years. but it must be done by a professional. because I do not know how to set each valve (although there are probably 2 of them) in the adjustment position, i.e. "clearance"
    Summing up: when I connect a new battery, we will see how it will spin and whether it will fire.
    Marco
    Added after 9 [hours] 51 [minutes]:
    Regulator cube
    • Suzuki Burgman AN400 K1 1999 Won't Start: Possible Carburetor Issue? Engine Cranks, Fuel Smell IMG_20180704_173846.jpg (4 MB) You must be logged in to download this attachment.
  • #10 17312311
    Junior188
    Help: 6
    Rate: 22
    From the end, but at the beginning, this cube from the regulator asks for a replacement. The best for the flow of electricity would be to solder it, so you will not burn more the cube. No resistance is a good sign, and how many volts when fired as I wrote you? (If you are afraid of measuring, go ahead, there's no need to bother here)
    The battery, if you want, replace it, but I don't know what for? Are you 13.5 and 10.5 on the engine off or on?
    As for the black one, the other one, I can't imagine where it is ;) . You need to give some photos, maybe then I can tell you something.
    The first thing you do with this cube is very important. Three years is a service missed by two years. Timing and valves to be checked. For replacing air, fuel, oil and oil filters. Complete cleaning of the carburetor with regulation is offered by the purchase of the so-called repair kit and replacing it with new ones, the cost of a few zlotys and less problems. It is obligatory to replace the spark plug and the brake fluid.
    And now like this:
    Timing, valves, fuel and air filter, oil and filter changes, spark plug replacement are simple matters, you can do it.
    Carburetor and brake fluid are a bit of a higher driving school, the carburetor will quickly tell you that something hurts, but there is no room for errors in the brake fluid.
    I think that when he rode and after turning off the bryndza again, it turns out that something is either freezing in the carburetor or something is standing on the fuel flow line, although it is strange that once it is standing and not. What kind of fuel pump are you talking about? There should be a vacuum fuel supply from the carburetor, possibly by gravity. I do not know the construction of this particular model, so the advice is general ;)
    I drop websites:
    http://www.airgad.gr/Suzuki-Burgman-AN400-Service-Manual-Eng.pdf
  • #11 17320923
    marco74_2005
    Rate: 13
    I'm sorry I haven't spoken in the last few days. I replaced the battery and the problem was over. So the battery was crashed. When I connected a new one, was it idling or added gas, the charging current was always the same, probably 14.4V, and the old one went crazy from 13V to 17V
    Although now I have a choke problem when starting a cold engine. It kind of doesn't work, but I have to unscrew it and watch it.
    regards
    marco
  • #12 17322162
    Junior188
    Help: 6
    Rate: 22
    14.4 is exemplary but this jump to 17, unless it is a measurement error, is already disturbing. Check this charging on a very well warmed up engine, the regulator is already so hot when it ends it starts to go crazy. Replace this cube with the regulator anyway because it's a time bomb, so the question is not only when will it cause trouble ;) . Choke not working again is the most common cause of problems with carburetor adjustment, although I would recommend checking first if there is any trimming in it.
The discussion revolves around a 1999 Suzuki Burgman AN400 K1 that fails to start despite the engine cranking and a noticeable fuel smell. Initial suspicions pointed to the battery, but after replacement, the issue persisted. Users suggested potential carburetor problems, including a stuck needle or float issues, and recommended cleaning and adjusting the carburetor. After several attempts, the owner managed to start the engine, but it exhibited irregular idling and stalling. Further troubleshooting indicated possible electrical issues, including a faulty voltage regulator. Ultimately, replacing the battery resolved the starting issue, but a new problem with the choke mechanism arose, affecting cold starts.
TL;DR: For Burgman AN400 K1 no-starts, check battery and carb. 14.4 V is "exemplary", says an expert; unstable 17 V suggests regulator or connector. Most fixes: new battery, float‑level check, auto‑choke inspect. [Elektroda, Junior188, post #17322162]
Why it matters: This FAQ helps Burgman AN400 K1 owners fix cranking/no‑start and charging quirks fast using community‑verified steps.
Why does my Burgman AN400 K1 crank but not start and smell fuel?
A stuck float or needle can flood the carb, causing a fuel smell and no‑start. Shut off fuel, drain the carb bowl, and try starting again. If it fires only after adding a few fuel drops via the plug hole, the mixture delivery is suspect. Clean the carb thoroughly and set float height accurately. Recheck diaphragm and slide movement. These steps isolate flooding versus ignition issues. [Elektroda, Junior188, post #17305891]
How do I set or verify float fuel level with a clear‑hose test?
  1. Push a transparent hose onto the float‑bowl drain nipple and route it up the carb side.
  2. Open the bowl drain screw with fuel on; let fuel rise in the hose.
  3. Compare the hose level to the carb’s reference level; adjust float height if out of spec. [Elektroda, Junior188, post #17308806]
Could a weak battery cause cranking with no start on the AN400?
Yes. Replacing the weak battery resolved the no‑start and stabilized charging at about 14.4 V. The failing battery showed erratic charging swings between 13 and 17 V. Cranking speed and ignition energy improve markedly with a fresh, fully charged battery. If your readings mirror this behavior, start with battery replacement before deeper diagnostics. [Elektroda, marco74_2005, post #17320923]
What charging voltage should I see, and is a dip with lights normal?
Expect roughly 13.6–14.5 V across the battery at idle and revs on a good battery. A small voltage drop when switching on lights is normal load behavior. “13.6–14.5 is ok.” Measure on a known‑good, fully charged battery to judge the system correctly. If it fails to reach range, proceed to stator and regulator checks. [Elektroda, Junior188, post #17310518]
My voltage spikes to 17 V — is the regulator or connector failing?
Yes, that’s abnormal. “14.4 is exemplary but this jump to 17 is disturbing.” Check charging again when the engine is fully hot because failures often appear at temperature. Replace the corroded regulator connector (“cube”) as preventive maintenance. Overvoltage risks boiling the battery and damaging electrics. [Elektroda, Junior188, post #17322162]
My spark plug is black and sooty after cranking — what does it indicate?
That points to a rich condition or flooding. Close the fuel supply, drain the carb bowl, and retry. If the engine then starts cleanly, service the float needle and seat, and set float height. Confirm the choke/enricher isn’t stuck on. After correcting richness, install a fresh plug to avoid misfires. [Elektroda, Junior188, post #17305891]
How do I check for vacuum leaks around the carburetor?
Run the engine and spray a flammable aerosol around the carb base, boots, and joints. Listen for a change in RPM; an increase indicates false air entering. Identify the exact spot and reseal or replace the leaking component. This quick test helps confirm whether mixture problems stem from air leaks. [Elektroda, Junior188, post #17310518]
Engine dies when I open the throttle after carb work — what did I misassemble?
Recheck the slide diaphragm orientation and the pin under the black plastic cover. An incorrectly placed pin or diaphragm can cause stalling on throttle. After correcting that assembly, the engine ran “like a dream” and pulled well on road test. Ensure the throttle linkage and needle move freely. [Elektroda, marco74_2005, post #17311392]
Does the Burgman AN400 K1 use a fuel pump?
Community guidance points to vacuum‑actuated fuel delivery on this carbureted model, sometimes even gravity feed. Trace the vacuum line from the carb to confirm your setup. If delivery seems intermittent, inspect hoses and the vacuum valve/lines for blockage or leaks before suspecting the carb. [Elektroda, Junior188, post #17312311]
How should I check spark quality and plug gap?
Inspect the plug for damage and verify a strong, regular spark. Set the electrode gap to the manufacturer’s specification using a feeler gauge. Replace a questionable plug and retest. A correct gap and clean plug ensure reliable ignition, especially after flooding or extended cranking. [Elektroda, Junior188, post #17310518]
What maintenance should I prioritize after repeated starting issues?
Work methodically: check timing and valve clearances, replace air, fuel, and oil filters, and change oil. Clean and rebuild the carb with a kit to ensure sealing. Replace the spark plug and flush brake fluid. Many items are doable at home; brake fluid changes require more care. [Elektroda, Junior188, post #17312311]
How do I measure stator AC output safely?
Locate the three same‑color stator wires (often yellow) at the regulator. Set your multimeter to AC range and measure voltage between each pair while running. Use caution; exposed connectors and spinning parts can injure you. Compare readings across pairs for consistency. [Elektroda, Junior188, post #17310518]
Is reusing old carb gaskets a bad idea?
Yes. Achieving full sealing after disassembly with old gaskets is rare. Air leaks skew mixture and idle stability. Install a carb repair kit with new seals and gaskets. After restoring sealing, ride several kilometers to let the plug color stabilize under load. [Elektroda, Junior188, post #17308049]
