Quad 125 smokes heavily on a cold engine - Quad 125 burns heavily on a cold engi
Tom2602 22575 10
Why does my Chinese 125 quad start only when warm and refuse to start on a cold engine even though the carburettor, valve clearances and spark plug have already been checked?
Your cold-start problem is most likely caused by too low compression, probably from worn piston rings and/or valve leakage; an intake air leak at the carburettor connection should also be checked [#17040204][#17040370][#17040978][#17040981] Compression measured at 5.5 bar is below the point where starting problems begin, and the advice was to inspect the valves and rings because anything under 6 bar can cause firing issues [#17040978][#17040981] After the top end was removed, the first ring was found damaged, which fits the low-compression diagnosis [#17041478] The valves were then checked with kerosene and did not leak, so the ring/piston wear was the likely main fault [#17044536]
  • #1 17040135
    Tom2602
    Rate: 36
    I have a problem with the Chinese quad 125 namely I do not want to start on a cold engine. The starter spins normally.
    Valves adjusted, carburettor cleaned, new NGK spark plug, spark is not wanted to smoke. Once you can start it, it is normally at idle.
    After extinguishing, I want to start immediately, it fires normally and you just have to wait a minute and it doesn't start again.
    What can be?
  • #2 17040204
    E8600
    Help: 529
    Rate: 2518
    Left air probably leaking at the carburettor intake / connection.
  • #3 17040370
    1133
    Help: 12
    Rate: 29
    check the compression may be a leak on the valves.
  • #4 17040817
    Tom2602
    Rate: 36
    Carburettor rather well complex because on new O-rings.
    I measured the pressure and showed 5.5 bar.
  • #5 17040978
    1133
    Help: 12
    Rate: 29
    Below 6 bar firing problems start. I don't know what compressor is good and how much is the limit on your engine. I'll tell you by the example of Japan. Japan always has around 12-14 bar limit 9-10 bar. Due to the fact that you do not have compression, check the valves to see if they release or no rings.
  • #6 17040981
    E8600
    Help: 529
    Rate: 2518
    When it comes to 5.5 bar compression it's very low so you probably have a guilty one.
  • #7 17041214
    Tom2602
    Rate: 36
    In the evening I dismantle the top of the engine and let me know the condition of the piston and rings.
  • #8 17041311
    Staszek49
    Help: 228
    Rate: 1140
    Compression very important, but what about suction, you have it working.
  • #9 17041478
    Tom2602
    Rate: 36
    It is efficient because when it starts and goes at low speed, after switching on the suction, it starts working unevenly and after adding gas, it chokes.
    Added after 8 [hours] 1 [minutes]:
    Mountain dismantled. The first ring like a razor blade ...
    Tomorrow I'm going for a new piston with rings and folding.
    I will let you know if the firing problem will go away.
  • #10 17042985
    1133
    Help: 12
    Rate: 29
    check the tightness of the valves before putting the heads together, and it's best to reach the valves to make sure not to disassemble them twice
  • #11 17044536
    Tom2602
    Rate: 36
    Sealed valves. Flooded with kerosene, they don't even get damp.
    The new piston will only be on Wednesday.
    I will let you know how the deposit will be ok.
✨ The discussion revolves around a Chinese Quad 125 that experiences heavy smoking and difficulty starting when cold. The starter operates normally, and the user has already adjusted the valves, cleaned the carburettor, and replaced the spark plug with an NGK model. Despite these efforts, the quad only starts after prolonged attempts and exhibits issues with idling and choking when gas is added. Responses suggest potential causes including air leaks at the carburettor, low compression (measured at 5.5 bar), and possible valve leaks. The user plans to inspect the piston and rings after disassembling the engine, indicating that the first ring is in poor condition. Recommendations include checking valve tightness and ensuring proper suction.
