Huawei B529 vs B315: Comparing Routers for Best Performance & Features
KamilOwczarek 5955 15
  • #1 17310111
    KamilOwczarek
    Hello, as in the topic I wanted to know which router will be better Huawei b529 or b315?
  • #2 17310122
    makosuu
    Help: 369
    Rate: 369
    Why these two and not the B525?
  • #3 17310145
    matek451
    Help: 4314
    Rate: 5708
    But what is the point of comparing the LTE Category 4 router, i.e. B315 to B529 with LTE Category 6, i.e. aggregation of 2 LTE bands? Where is it to be used and at what operator?
  • #4 17310197
    KamilOwczarek
    BTS Kępa Tarchomińska 19A, Journal No. 14 - I live 1km from the transmitter, operator Orange. If b525 is better than b529 then I can take b525, I don't know much :P
  • #5 17310227
    matek451
    Help: 4314
    Rate: 5708
    For such a BTS, it and B525 are too weak, on BTS it is after the divorce in NetWorks, i.e. Orange has its LTE2600 (15MHz), LTE2100 (10MHz), LTE1800 (10MHz) and LTE800 (10MHz) on it and aggregation of these bands. Anyway, there are two more such BTS NetWorks in the area where T-Mobile and Orange have so many bands. And why exactly Orange? WT-Mobile has a much better offer with equipment and the B525 is in the subscription price of PLN 49/65. The B525 has 4XLAN and SMA antenna connectors.
  • #6 17310271
    KamilOwczarek
    "For such a BTS is this and the B525 too weak?" which modem to choose then? The problem is that I already have a contract with Orange and I got a B315 router for it, I also have a Dual LTE / 4G 15dBi MIMO antenna for the 1800-2100 band from cyber techa, but I'm still not entirely satisfied, so I thought about replacing the router. What router in this case would be the best considering the medium and high price?
  • #7 17310301
    matek451
    Help: 4314
    Rate: 5708
    And why did you take the offer in Orange in addition to 315 / It is poor, expensive and B315 does not meet the requirements for your Orange infrastructure. As I wrote, BTS NetWorks are there after modernization, 4 LTE bands work with their aggregation. Do LTE2600, LTE2100, LTE1800 and LTE800 tests on this B315, force them on it with LTEWatchH http://www.lte-anbieter.info/ltewatch/count_huawei.php?Datei=ltewatch_h BTS-CID data will be shown and signal parameters, plus speedtest on each. You will see how each of them works for you. Cybertech's antenna works on LTE1800, LTE2100 but also on LTE2600 at this distance from the BTS. After the tests, we will see which bands are best to use and which router to buy. B525 aggregates two LTE bands, you can force them with HManager. The three bands are aggregated by B715, i.e. LTE2600 + LTE1800 + LTE800, does not aggregate LTE260 + 2100 + 1800. The cost is about PLN 500, come from Play.
  • #9 17310357
    matek451
    Help: 4314
    Rate: 5708
    Antenna set to the BTS in Kępa? Unfortunately, LTEWatchH with this FW on B315 does not show CID. As for 1 km from BTS, the signal on LTE1800 is weak, as well as on LTE2100, which results in a weak UL. Overall, a good DL signal for such a signal, especially on LTE2100. On LTE800, the parameters are similar, but the antenna in this band only transfers the signal from the outside, as on LTE2600, where the signal is very weak. In general, with these signal parameters it is very good, there is potential. BTS after the modernization and you can see that the Orange network has accelerated. It remains to choose a router and possibly change the antenna.
  • #10 17310381
    KamilOwczarek
    Yes, the antenna is set to BTS in Kepa, it is even a little closer to the BTS. The problem is also that the antenna is in the house and not outside because currently, unfortunately, I cannot put it through the balcony or roof, but it is on the first floor. aimed at BTS so that the best results are possible in LTEwatch, I tested the best place for a long time :D in that case, which router and anetne for these results is best to choose?
  • #11 17310435
    matek451
    Help: 4314
    Rate: 5708
    And everything is clear, the antenna inside the house does not change much when it comes to signal parameters. see how the internet works and what are the signal parameters on these bands after disconnecting it. The damping of the walls and shafts is high. See also what the ECI, eNB, signal parameters and DL / UL are like when you transfer the card to an Android phone and the Network Cell Info application. Show the DATA tab. Make a test with the phone at home and outside. We'll see which BTS you connect to. Minimum to B525, E5186 with aggregation of 2 LTE bands. On it you will use LTE2600 + 1800 or LTE2600 = 800, LTE1800 + 800, LTE2100 + 800. the more expensive option is B715 aggregating 3 LTE bands and you will force LTE2600 + 1800 + 800 on it (aggregation of the upper 3 LTE2600 + 2100 + 1800 bands does not work on it). The antenna for all bands is ATK-504, wideband 800-2600MHz. Two in x-cross position, for LTE1800, LTE2100 and LTE2600 Cybertech 17dBi n antenna at 1800-2600MHz. But exposed outside.
  • #12 17310749
    KamilOwczarek
    Without Antenna, Speedtests worse results on the 1800, 2100 and 2600 bands:
    I managed to make the antenna outside, you know speed tests a little better:
  • #13 17310834
    matek451
    Help: 4314
    Rate: 5708
    On LTE800 and LTE2600, the signal parameters are better without an antenna, similar on LTE2100, comparable on LTE1800, but the lack of CID in LTEWatchH makes it impossible to determine whether the connection with the antenna and without it with the same BTS. And speed tests in the evening are usually worse because the load increases. Outside, the signal increase by 8-9dBi is the effect of omitting the signal attenuation by the walls. But overall it's very good, what is the street where you live? BTSs with a set of 4 LTE Orange bands are also available at Jabłonna-Buchnik Las and Aluzyjna 25F and a few others. If they are in different directions, the directional antenna can be forced to connect to the one that gives the highest speeds.
  • #14 17311209
    KamilOwczarek
    I live at ul. Kępa tarchomińska 6m router, antenna directed towards BTSa Kępa Tarchomińska 19A, Dz. No. 14 I doubt that it will ever catch another BTS because this one is much closer than the others. So I understand that in this case it is best to buy a Huawei B525, B529 or B715 router, but on B715 I will have the best possibilities, since I have similar DL on all 4 bands, then three will complement each other and if I am still dissatisfied, I will buy a multi-band antenna with what did you send?
  • #15 17311256
    makosuu
    Help: 369
    Rate: 369
    KamilOwczarek wrote:
    how will I be still dissatisfied to buy a multi-band antenna from what you have sent?
    I would hang the current Cybertech panel outside in the direction of the BTS and it is possible that it will amplify the signal sufficiently just by moving its collection point outside, high.
  • #16 17311414
    matek451
    Help: 4314
    Rate: 5708
    BTS Aluzyjna is at a similar distance, but that's good because you have two BTSs nearby with 4 LTE bands. For now, test both on this antenna as well as your friend advises and check on the phone with Network cell Info eNB, ECI BTS. You will see which of them gives coverage at home and which outside.
✨ The discussion centers around comparing the Huawei B529 and B315 routers, with users questioning the performance differences due to their LTE categories. The B315 is an LTE Category 4 router, while the B529 supports LTE Category 6, allowing for better band aggregation. Users living near a BTS (Base Transceiver Station) operated by Orange express concerns about the adequacy of their current B315 router, especially given the modernized infrastructure with multiple LTE bands. Recommendations include considering the Huawei B525 or B715 for improved performance, as they support better band aggregation and have more features. Users also discuss the impact of external antennas on signal strength and performance, emphasizing the importance of testing different setups to optimize connectivity.
TL;DR: On Orange 4‑band sites, use CA routers: B715 enables 3‑band aggregation; "B525 aggregates two LTE bands." This FAQ helps Orange/T‑Mobile users near BTS choose routers, bands, and antennas for lower ping and stable speeds. [Elektroda, matek451, post #17310301]
Why it matters: It guides home users comparing Huawei B529 vs B315 to pick hardware and settings that unlock Orange’s multi‑band LTE.
Which is better for Orange near Kępa Tarchomińska: Huawei B529 or B315?
B529 is better. B315 is Cat 4 without carrier aggregation. B529 is Cat 6 with two‑band aggregation. On a four‑band Orange site, aggregation boosts throughput and stability. As the expert put it, “aggregation of 2 LTE bands.” Use CA when the BTS supports it. [Elektroda, matek451, post #17310145]
Is B525 or B715 a better upgrade than B529?
Yes. B525 and E5186 provide two‑band aggregation as a minimum. B715 adds three‑band aggregation for higher capacity. It cannot do 2600+2100+1800 together. “The more expensive option is B715 aggregating 3 LTE bands.” Use 3CA when your BTS exposes four bands. [Elektroda, matek451, post #17310435]
What band combos should I try first on B525/B715 for Orange?
Test LTE2600+1800 first. Also try 2600+800, 1800+800, and 2100+800. These match Orange deployments. Lock each combo and compare results. Use HManager on B525. On B715, force 2600+1800+800 where available. Pick the combo with the best speed and stability. [Elektroda, matek451, post #17310435]
What bands and bandwidths does the Orange BTS broadcast here?
This site carries four LTE bands with aggregation. LTE2600 uses 15 MHz. LTE2100, LTE1800, and LTE800 each use 10 MHz. Two additional nearby NetWorks sites offer similar multi‑band capability. CA routers will exploit this capacity better than Cat 4 units. [Elektroda, matek451, post #17310227]
Will putting my antenna outdoors improve signal and speeds?
Yes. Mounting the panel outside can increase received signal by about 8–9 dBi. Walls attenuate heavily indoors. Evening tests often look worse due to higher network load. Aim precisely at the BTS and elevate the antenna for best stability and rates. [Elektroda, matek451, post #17310834]
Which external antenna should I choose for all bands?
Use two ATK‑504 wideband antennas (800–2600 MHz) in X‑cross for full‑band coverage. For higher mid/high‑band gain, a Cybertech 17 dBi panel targets 1800–2600 MHz. Install antennas outdoors to see meaningful improvements. [Elektroda, matek451, post #17310435]
How do I test and lock LTE bands on Huawei routers?
Follow this quick method: 1) On B315, use LTEWatchH to lock LTE2600, 2100, 1800, and 800, then note signal and speed. 2) Run speed tests on each locked band to compare. 3) On B525, use HManager to force two‑band aggregation and retest. Pick the best performer. [Elektroda, matek451, post #17310301]
How do I confirm which BTS I’m on?
Put the SIM in an Android phone. Open Network Cell Info and use the DATA tab. Record eNB and ECI to identify the site. Compare readings indoors and outdoors. This shows which BTS covers your home and guides antenna aiming. [Elektroda, matek451, post #17310435]
Does the B525 have external antenna ports and multiple LAN?
Yes. The Huawei B525 offers four LAN ports and external SMA antenna connectors. That simplifies wired networking and MIMO antenna hookup for better reception. [Elektroda, matek451, post #17310227]
Which operator plan is better here: Orange or T‑Mobile?
One contributor recommends T‑Mobile’s value with equipment. They cite a plan including the B525 at PLN 49/65. Compare local performance and pricing, then choose the stronger bundle for your needs. [Elektroda, matek451, post #17310227]
I’m 1 km from the BTS—do I still need an external antenna?
Possibly. At about 1 km, high bands can be weak indoors with limited upload. Download may still look strong, so there’s potential. “It remains to choose a router and possibly change the antenna.” An outdoor mount helps stabilize links and latency. [Elektroda, matek451, post #17310357]
Will my Cybertech 15 dBi panel work on 2600 MHz too?
Yes. That Cybertech panel targets 1800–2100 MHz, and at this distance it also works on LTE2600. Mount it outside and test each band while aimed at your BTS. [Elektroda, matek451, post #17310357]
Can the B715 aggregate 2600+2100+1800?
No. B715 supports 3CA but not the upper trio 2600+2100+1800. Use 2600+1800+800 instead. “The three bands are aggregated by B715,” with this limitation noted. [Elektroda, matek451, post #17310301]
Are B529 and B525 too weak for a four‑band Orange site?
For peak capacity, yes. On this BTS, both B529 and B525 are described as too weak. A 3CA router better uses the available spectrum. Consider B715 if you need maximum throughput. [Elektroda, matek451, post #17310227]
Why does ping or speed vary at different times?
Network load changes during the day. Evening hours usually show more congestion and lower speeds. Your results vary with load, band choice, and signal strength. Use band locking, CA, and an outdoor antenna to stabilize performance. [Elektroda, matek451, post #17310834]
Are there alternative BTS options near Kępa Tarchomińska to aim at?
Yes. Orange also runs four‑band LTE at Jabłonna‑Buchnik Las and Aluzyjna 25F. If they’re in different directions, a directional antenna can favor the faster site. Test each and select the best performer for your address. [Elektroda, matek451, post #17310834]
