Lichtenberg Figures: TAR-220att Microwave Transformer Connection & Advice for Wood Burning
rudykrzych 11844 2
  • #1 17319689
    rudykrzych
    I would like to burn Lichtenberg figures in wood.
    I got a transformer from the microwave with the designation TAR-220att, I would like to know which leads to connect to the board because when connecting the secondary windings nothing happened, the transformer is OK.
    It may be to connect a capacitor in series or in parallel to the HV windings or it is connected with 3 lead which has a resistance of about 220 Ohm to the base of the transformer.
    I am asking for some advice
    Do not negate the idea by posts like give it a rest because there is about 2kv if you do such things with your head with appropriate security measures, you can rather work with HV.
  • #2 17319812
    gold-game
    Help: 64
    Rate: 153
    I think your problem is that the board has too much resistance. You need to moisten the board with a suitable solution. Here's a video: http: //elektrykapradnietyka.com/18927/zrob-to-sam-figura-lichtenberga/
  • #3 17320466
    jarek_lnx
    Help: 4183
    Rate: 6068
    I moistened the wood with salty water, there was little water that evaporated in the process, even when the wood was dry, the salt remained and the process went on.
