Controlling Intensity on Target Electrodes in DIY Spot Welder Using Microwave Transformers
mlody_tokarz 8175 4
  • Request for electrode current control in a transformer spot welder
    #1 16202302
    mlody_tokarz
    Hello everyone, at the outset I would like to point out that my knowledge in the subject of electronics is small, so please be understanding.
    I am going to build a sheet metal spot welder using 2 microwave transformers, rather simple without welding time control, my question is how to control the intensity on the target electrodes? If you cannot do without some control boards, could someone make such a PCB for me?
  • Microwave transformers have unsuitable high-voltage secondary windings
    #2 16202499
    scotch
    Help: 78
    Rate: 148
    Buddy, if you do not have knowledge in the field of electronics, do not take on such things. To build the welding machine, you need a transformer in which the secondary winding, at low voltage, can "give up" high short-circuit current. Conversely, a microwave has a very high output voltage of about 2,000 V and a small current. Generally, I advise against this idea if my colleague has a nice life. Below is a link to a self-made welding machine, just look for and read:
    https://www.elektroda.pl/rtvforum/topic2411457.html
  • #3 16202547
    mlody_tokarz
    When it comes to transformers, of course, you have to throw out the secondary windings and re-wind them, get 2-3 turns and connect the transformer in series with the secondary winding, I mean that I want to have some current regulation on the electrodes
  • #4 17927526
  • #5 17963413
    granderik
    Rate: 29
    I am sticking to the topic, I have a welding machine purchased, but there is no good programmer, i.e. the LCD display on which you can set the welding time from 1 ms to 100 something. . he did right. Will I buy such a display ready for alliexp ...? and it's easy to swap. do i have to program it?
