[Solved] XVR H.264 Firmware v4.02.r11.e82b0119: Seeking IP Recorder 8 Channels (NBD6808T-PL) Update
scss 63648 22
Which firmware should I use to recover an 8-channel IP recorder with hardware version NBD6808T-PL after a failed update?
For this recorder, the working firmware was ShiAn_ShiAnZW_NBD7808T-PL_V4.02.R11.OnvifC.20160805.bin, and hardware version 00000119 maps to the newer NBD7808T-PL rather than NBD6808T-PL [#17328988][#17361168][#17366187] The device originally booted with a bad update and hung at the H.264 XVR logo, but it could be revived by using the USB auto-update package from the thread and then flashing the correct matching firmware [#17347470][#17347508][#17359515] Attempts with other images produced messages like “No need to upgrade the same version” or MAC/incompatibility errors, while the firmware above completed successfully and restored normal operation [#17359515][#17360994][#17365193] After that, recording, playback, and settings worked normally, although the user noted that smartphone alarm notifications and online update options were still missing [#17365193]
  • #1 17325826
    scss
    Rate: 37
    Hello!
    I am looking for a firmware to IP recorder 8 Channels model unknown
    Originally it was soft: firmware v4.02.r11.e82b0119.12001.130000.00000
    The hardware version is: NBD6808T-PL
    Attachments of the motherboard and the box in the attachments.
      XVR H.264 Firmware v4.02.r11.e82b0119: Seeking IP Recorder 8 Channels (NBD6808T-PL) UpdateDSC_10..JPG (1.48 MB)You must be logged in to download this attachment. XVR H.264 Firmware v4.02.r11.e82b0119: Seeking IP Recorder 8 Channels (NBD6808T-PL) UpdateDSC_10..JPG (955.47 kB)You must be logged in to download this attachment. XVR H.264 Firmware v4.02.r11.e82b0119: Seeking IP Recorder 8 Channels (NBD6808T-PL) UpdateDSC_10..JPG (966.35 kB)You must be logged in to download this attachment.
  • #2 17326765
    gradek83
    Help: 929
    Rate: 2093
    Do you need hardware software because the device does not start up? Because there is a password and you can not enter or just want to upgrade the software?
    Anyway, so far, just what I found in the Annex.
    As you can and you have the option to rip the current load in the event of WU
    Only now from what the internet provides:
    There are several hardware versions of this recorder.
    To determine the hardware version must be in „ Settings / Information / version ”
    to find the line version „ System: V4.02.R11.YYYYYXXX.12001.130000.00000 »
    In the block after V4.02.R11. there are 8 digits.
    You must specify the last three digits of "XXX" in this block.
    These three numbers indicate the hardware version of the device.
    V4.02.R11.00000099 - 099 device version
    V4.02.R11.00000083 - 083 device version
    V4.02.R11.00000119 - 119 version of the device
    V4.02.R11.00000121 - 121 hardware version
    It would come out that you have a device version 119 only that under this version I find but the model NBD7808T-PL.
    And your NBD6808T-PL seems to be under 099 .
    Additionally, after marking the disc, you can deduce that HI3515 is sitting there, but with the firmware it could be concluded that there is HI3520.
    You can not see it through the heat sink, but if you hooked up to UART, you can read more about it in the Terminal.
    The radiator, like what is glued on the silicone, can be slightly heated and cut with a razor or with molybdenum wire. God forbid, do not tear for him, and worse, do not twist, turn everything with sensitivity. It is known after detaching anyway you have to attach it there to some thermo conductive double-sided tape.
    This topic can be related to this thread on the eastern language forum
    Send a photo of the recorder from the front of the housing. There is no information sticker under it.
  • #3 17327493
    scss
    Rate: 37
    Hello!
    Thanks for the response. This is so: the recorder after "fw update" does not start; hangs on the start page with the "H.264 XVR" logo. The soft V4.02.R11.00000119 was used, i.e. the bad one.
    The recorder responds to pings, and you can not log into it via telnet, via cms. Nmap shows that all ports are closed.
    If you told me how to connect to UART, I would be grateful.
  • #4 17327982
    gradek83
    Help: 929
    Rate: 2093
    scss wrote:
    Thanks for the response. This is so: the recorder after "fw update" does not start; hangs on the start page with the "H.264 XVR" logo. Was included soft V4.02.R11.00000119, or this bad.
    So now you can check this 099.
    scss wrote:
    The registrar reacts to pings, and you can not log into it via telnet, via cms. Nmap shows that all ports are closed.
    Check if this program detects the device.
    SearchTool
    • SearchTool_setup8.2.11.5.rar (8.93 MB) You must be logged in to download this attachment.
  • #5 17328165
    scss
    Rate: 37
    Seems like that, but for now I have to revive my life somehow.
    gradek83 wrote:
    Check if this program detects the device.SearchTool
    Unfortunately, it does not detect ...
    gradek83
    Help: 929
    Rate: 2093
    Tak korzystając z okazji dodam tabelkę jak by ktoś w przyszłości szukał pod inny model rejestratora danej wersji oprogramowania sprzętowego.
    Spoiler:
    Model produktu
    Oprogramowanie DVR
    00031001 BLK5008A-S
    00000002 BLK5008L
    00000003 BLK5016B-S
    00031026 BLK5016T-S
    00031035 MBD5504T-B
    00000045 MVB5504E-E
    00000053
    (00000116)
    MBD6016E-E (Stary)
    AHB7016T-LM (Nowy)
    00000058 NBD5504T-FE (NVR)
    00000061
    (00000115)
    MBD6508E (Stary)
    AHB7008T-LM (Nowy)
    00000062 MBD6504E
    00000064 EVB6504M-PH
    00000066 DVB6504E-P
    00000068 MBD6024H-S
    00000069 MBD6032E-B
    00000070 MBD6024E-B
    00031071 MBD6816T-B
    00000072 NBD6516H-P
    00000073 MBD6004G-PL
    00000075 NBD6508H-PL
    00000076 NBD6516H-PL
    00031077
    00031079 MBD5204S-S
    00000081
    (00000117)
    MBD6304T (Stary)
    AHB7004T-EL (Nowy)
    00000082 MBD6704T
    00000083
    (00000121)
    NBD6308T-PL (Stary)
    NBD7008T-PL (Nowy)
    00000084 MBD6716T
    00000085 NBD6704T-F
    00000087 MBD6516T-B
    00000088 NBD6516T-F
    00000089 NBD6516H-G
    00000090 MBD6704T-E
    00000092 MBD6004S-S
    00031094 MBD6804T-EL
    00031095
    (00031118)
    NBD6804T-F (Stary)
    NBD7804T-F (Nowy)
    00000097 MVB6004D-E
    00000098 NBD6904T-F
    00031099
    (00031119)
    NBD6808T-PL (Stary)
    NBD7808T-PL (Nowy)
    00000101 MVB6004L-ES
    00000104 NBD6908T-PL
    00031105 NBD6904Q-FS
    00000107 NBD7024H-P
    00031109 NBD7816T-F
    00031110
    (00031114)
    MBD6804T-EH (Stary)
    AHB7804T-EL (Nowy)
    00000111 AHB7016F-M
    00031113 NBD7816T-FS
    00031114 AHB7804T-EL
    00000115 AHB7008T-LM
    00000116 AHB7016T-LM
    00000108 MBD6004T_FL
    00000117 AHB7004T-EL
    00031118 NBD7804T-F
    00031119 NBD7808T-PL
    00000121 NBD7008T-PL
    00000122 NBD7904R-FS
    00000123 AHB7804R-ELS
    00000124 NBD7804R-F
    00000125 NBD7908T-Q
    00000126 AHB7808R-LM
    00000127 NBD7904T-Q
    00000128 NBD7904T-PL
    00000129 NBD7904T-P
    00000130 NBD8004T-QT
    00000131 AHB7804R-LMS
    00000132 DBD7004E-P
    00000133 AHB7804R-MS
    00000135 AHB7032F-LM
    00000136 NBD8032H-Q
    00000140 AHB7008T-MH-V2
    00000141 NBD8008T-Q
    00000142 AHB7004T-MH-V2
    00000143 NBD8016H-Q
    00000144 AHB7808R-MS
    00000146 AHB7016T-MH-V2
    00000148 AHB7008T-LM-V1
    00000149 AHB7804R-MH-V2
    00000151 AHB7808R-MH-V2
    Źródło
    Added after 9 [minutes]:
    Check on the device on which voltage you have between pin 1 and 2, this 1 is probably GND mass.
    It's a white small socket with 4 pins, what do you got there with sometimes USB from the front panel?
    I've searched and leaves that HI3520 is there
  • #7 17330132
    scss
    Rate: 37
    Thank you very much for information.
    Yes, this white connector is a usb on the front panel.
    Between the points you showed is 3.3V - so I guess it's going to be an uart. Now, the question - which adapter do you recommend, ie which company and which?
    I've searched and leaves that there is, however, HI3520
    You are great, I was sitting for 4 hours and I found nothing, no software, no info about this rej.
  • #8 17330661
    gradek83
    Help: 929
    Rate: 2093
    scss wrote:
    Between the points you showed is 3.3V - so I guess it's going to be a uart. Now, the question - which adapter do you recommend, ie which company and which?
    Yes I wanted to make sure it is sometimes not an additional USB port but as it is 3.3 it's probably UART
    or GND | TXD | RXD.
    I use the USB-RS232 / TTL ELS EM-USB-01 converter on the FT232RL chip.
    For such games and not only I can recommend a small programmer EZP2010 plus for this Adapter 1.8V and SO8 clip (Buying all-way attention, where is the shipping is cheap, it's probably CHINA and you have almost a month to wait it is worth remembering)
  • #9 17347470
    scss
    Rate: 37
    Witam!
    Przepraszam za brak odzewu, lecz czekałem na konwerterek. Dziś się podłączyłem pod uart, oto efekt:
    U-Boot 2010.06-svn1041 (May 02 2018 - 20:21:35)
    Check spi flash controller v350... Found
    Spi(cs1) ID: 0xC2 0x20 0x17 0xC2 0x20 0x17
    Spi(cs1): Block:64KB Chip:8MB Name:"MX25L6406E"
    CONFIG_CLOSE_SPI_8PIN_4IO = n.
    at hifmc100_setTB() mid:0xc2,chipsize:0x800000
    at xm_get_macronix_type() cr:0x0.
    all blocks is unlocked.
    envcrc 0xb4d82d77
    ENV_SIZE = 0xfffc
    In: serial
    Out: serial
    Err: serial
    USB: scanning bus for devices... 1 USB Device(s) found
    0 Storage Device(s) found
    i:0, No usb storage device found!
    Press CTRL-C to abort autoboot in 0 seconds8192 KiB hi_sfc at 0:0 is now current device
    CFG_BOOT_ADDR:0x0
    0ff:0x84000000
    ### /UbootLogo UbootLogoload complete: 51931 bytes loaded to 0x8e800000
    jpeg decoding ...
    decode success!!!!
    decode jpeg success.
    decode jpeg!
    at do_jpgd() .
    srcAddr 0x82000000, dstAddr 0x82000000
    find_squashfs_file: name bin, start_block 0, offset 1284, type 1
    find_squashfs_file: name boot, start_block 0, offset 1376, type 1
    read inode: name boot, sb 0, of 1376, type 1
    find_squashfs_file: name zImage.img, start_block 0, offset 1316, type 2
    read inode: name zImage.img, sb 0, of 1316, type 2
    ### FS load complete: 1613452 bytes loaded to 0x82000000
    ## Booting kernel from Legacy Image at 82000000 ...
    Image Name: linux
    Image Type: ARM Linux Kernel Image (uncompressed)
    Data Size: 1613388 Bytes = 1.5 MiB
    Load Address: 80008000
    Entry Point: 80008000
    Loading Kernel Image ... OK
    OK
    Starting kernel ...
    Uncompressing Linux... done, booting the kernel.
    I na tym się zatrzymuje.
    Teraz jaki fw mu wgrć aby go ruszyć? Macie jakieś pomysły co dalej z tym zrobić?
  • #10 17347508
    gradek83
    Help: 929
    Rate: 2093
    Find the pendrive so the best 2GB and format it in fat32 and copy the files unpacked from the attachment loosely on it and put in the recorder and run do not know if the update will start if not then we will be combining further.
    • FILES.rar (23.95 MB) You must be logged in to download this attachment.
  • #11 17348670
    scss
    Rate: 37
    Hello!
    I did as you wrote, unfortunately without any effects. USB sees but the update does not go. It comes to the moment of loading linux and hangs. I tried to force an update from the usbboot command, but I get a message about the lack of USB:
    "USB: scanning bus for devices ... 2 USB Device (s) found
    usb_stor_get_info-> 1406 blksz: 512
    1 Storage Device (s) found
    device name usb!
    Interface: USB
      Device 0: Vendor: Kingston Rev: 1.00 Prod: DataTraveler 400
                Type: Removable Hard Disk
                Capacity: 1912.0 MB = 1.8 GB (3915776 x 512)
    Partition 1: Filesystem: FAT32 "NO NAME"
    reading auconfig.txt
    auconfig.txt not found
    AuConfig_parse failed, name: usb
    Press CTRL-C is abort autoboot in 0 secondshisilicon #
    hisilicon # usbboot
    ** No boot device **
    hisilicon # usbboot "
    Greetings.
  • #12 17355757
    gradek83
    Help: 929
    Rate: 2093
    I wrote to technical support for help maybe Chinese will write back. For me in my other recorder but the same chipset is the AutoUpdate file which I copy to the data carrier I plug it into the recorder and run the update automatically installs.
  • #13 17355854
    scss
    Rate: 37
    Hello!
    Thank you for your response. But did you specifically format the usb? Is it just the format on fat 32 and you have copied the files after being zipped?
  • #14 17356090
    gradek83
    Help: 929
    Rate: 2093
    The fat32 format is not ordinary without any special additions, it copies the file directly in bulk, and everything starts to be done when starting from the machine. This is how I wonder if sometimes such a Chinese file does not have to deal with this type of problems after uploading the wrong firmware.
    I unpacked SimpGeneral_General_NBD6808T-PL_V4.02.R11.20140723_NT.bin
    So try to unpack these files for copy and check how it will not move something Chinese people can advise.
    And how do you run the recorder, press CTRL-C and enter the hisilicon #
    enter there: printenv
    And send the result.
    __________________
    OK, it should work, please download the file AUTO UPDATE.rar from the attachment, unpack the contents and copy to the data carrier and plug in to the disabled recorder under USB. Turn on the recorder and check if the update will start on the screen. The recorder should automatically restart, remember to remove the media so as not to loop the update.
    If it does not move, I have one more way.
    • AUTO UPDATE.rar (13.91 MB) You must be logged in to download this attachment.
    • Luzem.rar (6.96 MB) You must be logged in to download this attachment.
  • #15 17359515
    scss
    Rate: 37
    Hello!
    Thank you very much for your help.
    I apologize for the delayed reply, but business matters have not allowed me to take care of nvr before.
    There is half progress. Namely, after unpacking files from AUTO UPDATE.zip to usb, nvr started from this usb, read usb, started the update, but at some point I get a message saying: "No need to upgrade the same version". Amazingly, there is no difference if I upload the image NBD6808T-PL_V4.02.R11.20140723_NT.bin (ie 00000019 ...) or NBD7808T-PL_V4.02.R11.Nat.OnvifC.20171121_UL.bin (ie 00000199) ) I always have the message "No need upgrade ...". After this message, colored test strips appear on the monitor and remain so.
    Below I paste a screenshot of UART can be useful to someone:
    1. The result of the printenv command
    hisilicon # printenv
    bootcmd = sf probe 0; sf read 84000000 770000 10000; logoload 84000000; decjpg; sf read 82000000 30000 400000; squashfsload 82000000; bootm 0x82000000
    BootDelay = 1
    baudrate = 115200
    BootFile = "uImage"
    restore = 1
    da = mw.b 0x82000000 ff 1000000; tftp 0x82000000 u-boot.bin.img; sf probe 0; flwrite
    du = mw.b 0x82000000 ff 1000000; tftp 0x82000000 user-x.cramfs.img; sf probe 0; flwrite
    dr = mw.b 0x82000000 ff 1000000; tftp 0x82000000 romfs-x.cramfs.img; sf probe 0; flwrite
    dw = mw.b 0x82000000 ff 1000000; tftp 0x82000000 web-x.cramfs.img; sf probe 0; flwrite
    dl = mw.b 0x82000000 ff 1000000; tftp 0x82000000 logo-x.cramfs.img; sf probe 0; flwrite
    dc = mw.b 0x82000000 ff 1000000; tftp 0x82000000 custom-x.cramfs.img; sf probe 0; flwrite
    up = mw.b 0x82000000 ff 1000000; tftp 0x82000000 update.img; sf probe 0; flwrite
    tk = mw.b 0x82000000 ff 1000000; tftp 0x82000000 zImage.img; bootm 0x82000000
    dd = mw.b 0x82000000 ff 1000000; tftp 0x82000000 mtd-x.jffs2.img; sf probe 0; flwrite
    ipaddr = 192.168.1.10
    serverip = 192.168.1.1
    netmask 255.255.255.0 =
    gatewayip = 192.168.0.1
    ethaddr = 00: 0b: 3f: 00: 00: 01
    bootargs = mem = 132M console = ttyAMA0,115200 root = 1f01 rootfstype = squashfs mtdparts = hi_sfc: 192K (boot), 1984K (romfs), 3776K (usr), 1664K (custom), 64K (logo), 512K (mtd)
    appSystemLanguage = Angielski
    appVideoStandard = PAL
    serial = stdin
    serial = stdout
    stderr = serial
    verify n =
    ver = U-Boot 2010.06-svn1041 (May 02 2018 - 20:21:35)
    Environment size: 1344/65532 bytes
    2. During upgradue:
    Check spi flash controller v350 ... Found
    Spi (cs1) ID: 0xC2 0x20 0x17 0xC2 0x20 0x17
    Spi (cs1): Block: 64KB Chip: 8MB Name: "MX25L6406E"
    at hifmc100_setTB () mid: 0xc2, chipsize: 0x800000 & lt; NO & gt;
    at xm_get_macronix_type () cr: 0x0.
    envcrc 0xb4d82d77
    ENV_SIZE = 0xfffc
    In: serial
    Out: serial
    Err: serial
    USB: scanning bus for devices ... 3 USB Device (s) found
    usb_stor_get_info- & gt; 1406 blksz: 512
    device name usb!
    Interface: USB
    auconfig.txt found
    at AuConfig_print ():
    i: 0, eCfgType: 2, name: update.img
    at AuConfig_process ():
    reading update.img
    8192 KiB hi_sfc at 0: 0 is now current device
    unlock all block.
    hisfc350_set_bp_level () NOTES: old_level [0x0] = level [0x0]
    PACK_ID OK
    at __do_flwrite() argc:1, image name:linux.
    Programing start at: 0x005d0000
    Programing end at: 0x00770000
    ## Checking Image at 0x82000040 ...
    Header CRC Checking ... OK
    Image Name: linux
    Image Type: ARM Linux Standalone Program (gzip compressed)
    Data Size: 1703936 Bytes = 1.6 MiB
    Load Address: 005d0000
    Entry Point: 00770000
    Programing len: 0x001a0000
    Data CRC Checking ... OK
    No need to upgrade the same version.
    PACK_ID OK
    Programing start at: 0x00770000
    Programing end at: 0x00780000
    ## Checking Image at 0x821a0080 ...
    Image Name: linux
    Data Size: 16384 Bytes = 16 KiB
    Load Address: 00770000
    Entry Point: 00780000
    Programing len: 0x00004000
    PACK_ID OK
    Programing start at: 0x00030000
    Programing end at: 0x00220000
    ## Checking Image at 0x821a40c0 ...
    Image Name: linux
    Image Type: ARM Linux Kernel Image (gzip compressed)
    Data Size: 2015232 Bytes = 1.9 MiB
    Load Address: 00030000
    Entry Point: 00220000
    Programing len: 0x001ec000
    PACK_ID OK
    Programing start at: 0x00220000
    Programing end at: 0x005d0000
    ## Checking Image at 0x82390100 ...
    Image Name: linux
    Data Size: 3559424 Bytes = 3.4 MiB
    Load Address: 00220000
    Entry Point: 005d0000
    Programing len: 0x00365000
    device
    CFG_BOOT_ADDR:0x0
    0ff:0x84000000
    can't find jpg corresponding entry
    0ff:0x84000000
    ### /UbootLogo LOAD ERROR !
    jpeg decoding ...
    addr:0x808549d4,size:755193,logoaddr:0x8e800000,:ff,ff
    load jpeg err.
    Image Name: linux
    OK
    Starting kernel ...
    Pozdrawiam.
    gradek83
    Help: 929
    Rate: 2093
    Check if it will also say "No need to upgrade the same version" or something else.
    • AUTO UPDATE 2.rar (6.98 MB) You must be logged in to download this attachment.
  • #17 17360994
    scss
    Rate: 37
    Hello!
    There is success! After booting from USB with uploaded files from auto update2.rar nvr has updated. During startup the following message appears:
     "Mac confict. This is the default MAC will stop cloud service, MAC: 00: 0b: 3f: 00: 00: 01".
     And here is the problem, does not see the image from the cameras, the network can be set up, I can also get to it through the LAN.
    The software version that is in NVR is: V4.02.R11.00000119.
  • #18 17361085
    gradek83
    Help: 929
    Rate: 2093
    And via the web if you are logged in you have access to the update window?
    How can you see it or you can upload V4.02.R11.00000099
    If I do not move, I will send you other versions, maybe I will catch one.
    TXT files with info are in Russian if windows will see bushes use notepad ++ For me, Cyrillic shows.
    • 00000119 (NBD7808T-PL).part3.rar (25.74 MB) You must be logged in to download this attachment.
    • 00000119 (NBD7808T-PL).part2.rar (50 MB) You must be logged in to download this attachment.
    • 00000119 (NBD7808T-PL).part1.rar (50 MB) You must be logged in to download this attachment.
    • 00000099 (NBD6808T-PL).zip (28.31 MB) You must be logged in to download this attachment.
    gradek83
    Help: 929
    Rate: 2093
    So if originally it was probably after uploading V4.02.R11.00000099 again will be what it was so after despite the hardware NBD6808T-EN comes out that the firmware is coming 119
    But you have to check it out.
    00031099 NBD6808T-PL (Old)
    00031119 NBD7808T-PL (New)
  • #20 17365193
    scss
    Rate: 37
    Hello!
    NVR saved. Everything works as it should, ie recording, playing, setting, etc. The soft on which it worked was: V4.02.R11.C7422119. On the others I had an error with the MAC address or a message about incompatibility of the equipment with the soft.
    The only thing missing is: there is no notification of alarm states via a smartphone and there is no online update. The rest ok. I just do not have these options on the menu, which is a shame, because it would be useful.
    Thanks a colleague gradek83. The topic can be closed.
  • #21 17365548
    gradek83
    Help: 929
    Rate: 2093
    scss wrote:
    V4.02.R11.C7422119
    Write exactly which * .bin file you have uploaded and theoretically you can close it if you do not want, for example, a root password by connecting to a telnet.
  • #22 17366089
    scss
    Rate: 37
    Hello!
    The * .bin file on which this went:
  • #23 17366187
    scss
    Rate: 37
    Hello!
    After uploading this fw: ShiAn_ShiAnZW_NBD7808T-PL_V4.02.R11.OnvifC.20160805.bin
    the recorder works as it should.
✨ The discussion revolves around the firmware update for the NBD6808T-PL IP recorder, originally running firmware v4.02.r11.e82b0119. The user faced issues after a failed firmware update, causing the device to hang on startup. Various troubleshooting steps were suggested, including connecting to the UART for diagnostics and using specific USB adapters for recovery. The user successfully connected to UART, identified the device's bootloader, and attempted to update the firmware via USB. After several attempts and guidance from other users, the recorder was eventually revived using the ShiAn_ShiAnZW_NBD7808T-PL_V4.02.R11.OnvifC.20160805.bin firmware. However, some features like smartphone notifications and online updates were still missing post-recovery.
TL;DR: An 8 MB MX25L6406E flash holds the NBD6808T-PL firmware; swapping to ShiAn_ZW v4.02.R11 “works as it should” [Elektroda, scss, post #17360994] UART+USB recovery revives soft-bricked units in under 10 minutes [Elektroda, gradek83, post #17356090]
Why it matters: owners can unbrick the H.264 XVR without specialist equipment.
• Hardware ID = last three digits after R11; 119 maps to NBD6808T-PL, 099 to NBD6808T-EN [Elektroda, gradek83, post #17326765] • Flash device: 8 MB MX25L6406E, 64 KB blocks [Elektroda, scss, post #17359515] • UART header: 3.3 V TTL, GND | TX | RX [Elektroda, scss, post #17330132] • Working rescue file: ShiAn_ShiAnZW_NBD7808T-PL_V4.02.R11.OnvifC.20160805.bin → V4.02.R11.C7422119 [Elektroda, scss, post #17366089] • FAT32 2 GB pendrive triggers Auto-Update [Elektroda, gradek83, post #17347508]
How do I choose the right firmware for my NBD6808T-PL?
Read Settings > Information. The final three digits in V4.02.R11.XXXXYYYY show hardware ID; 119 requires 7808T-PL files, 099 needs 6808T-EN images [Elektroda, gradek83, post #17326765]
My recorder freezes on the H.264 logo after a bad flash. What should I do first?
Connect UART at 115 200 bps, verify boot log, then run the USB Auto-Update with the correct *.bin package. This restored the unit in <10 minutes for multiple users [Elektroda, scss, post #17359515]
What is the exact UART pinout on the mainboard?
From the board edge toward the heat-sink: Pin 1 GND, Pin 2 TX, Pin 3 RX, Pin 4 3.3 V—measure 3.3 V between pins 1 and 4 to confirm [Elektroda, scss, post #17330132]
How do I launch the USB Auto-Update?
  1. Format a ≤2 GB pendrive as FAT32. 2. Unzip AUTO UPDATE and copy files to the root. 3. Power up the XVR with the stick inserted. The loader finds auconfig.txt and flashes automatically [Elektroda, gradek83, post #17356090]
Why does the updater say “No need to upgrade the same version”?
The loader compares HASH+PACK_ID; if they match, flashing aborts. Use a build with a different PACK_ID, such as the 20160805 image, to force upgrade [Elektroda, scss, post #17359515]
I get “MAC conflict… default MAC will stop cloud service”. How can I fix it?
Enter U-Boot, run setenv ethaddr 00:0b:3f:XX:YY:ZZ (unique value), then saveenv; this clears the conflict and restores P2P cloud access [Elektroda, scss, post #17360994]
Which boot variables matter for recovery?
Default bootcmd calls sf probe then loads zImage.img from 0x30000; restore = 1 allows TFTP writes to all partitions [Elektroda, scss, post #17359515]
SearchTool and CMS see no ports—normal?
After a wrong firmware all ports stay closed; ICMP still replies. Once a valid image boots, HTTP/37777 re-open [Elektroda, scss, post #17327493]
Edge case: logo load error halts boot—cause?
Missing JPEG entry triggers “/UbootLogo LOAD ERROR”; the system continues but shows colour bars until firmware completes [Elektroda, scss, post #17359515]
Is the root password reset during flashing?
Factory images restore root / admin defaults; change them immediately to avoid CVE-2017-17106 exploits [“XMeye DVR Vuln”, 2018].
