[Solved] Mazda 6 Rear Caliper Choices: NTY, Mapco, ABS vs Bosch - User Experiences Wanted
IBikeYou 53619 11
Should I buy a cheap rear left caliper for a Mazda 6 from brands like NTY, Mapco, or ABS, or is it better to choose a Bosch caliper or regenerate the original one?
It is better to regenerate the original rear caliper, or buy a used caliper and regenerate it, than to gamble on cheap unknown brands like NTY, Mapco, or ABS [#17329059][#17328942][#17329689] One user with 25 years of experience said these brands are basically unknown, and that cheap new rear calipers can fail quickly, even causing the handbrake to stick after six months [#17329189] Several replies say most caliper faults can be repaired because there are parts available, even original ones [#17329189] If you must buy new, one suggestion was to look at Lauber first, and only then TRW or Bosch [#17329059] The thread’s overall conclusion is to avoid the cheapest unknown brand calipers and go for regeneration or a better-quality replacement instead [#17329689][#17329334]
  • #1 17328395
    IBikeYou
    Rate: 9
    Hello to all forum members.
    I would like to ask you about the opinions of cheaper car parts. Namely, I have to buy the left rear caliper for mazda 6 and searching the allegro, you can mainly meet such brands as NTY, Mapco, or ABS. Did anyone have contact with any parts of these brands? Because in vainly I googled opinions about these product brands, and I would not like to spend over 600 zlotys at the Bosch clamp right away (although then it is known that it is for many years) only to ask if it is worth buying something from these brands for a bit less money
    cirrostrato
    Help: 286
    Rate: 958
    My serviceman comes from the assumption (I personally share) that shock absorbers, clamps, discs etc. ALWAYS exchange both sides, left and right, for identical NEVER DIFFERENT COMPANIES. I personally bought stimulants on the back eg in Warsaw on Kaczeńiec szrot of Japanese, nice and competent service, necessary trinkets free give.
  • #3 17328725
    jacek0503
    Help: 28
    Rate: 175
    From the turn, I buy air vents - of course, they look nice.
    ociz
    Help: 1379
    Rate: 3486
    Better regenerated original than crap made of rice.
  • #5 17328974
    jacek0503
    Help: 28
    Rate: 175
    Sure - remanufactured pads, regenerated engine oil, coolant, shock absorbers, brake discs, etc. Let's continue like that ......
    Decorated in factories for a "bowl of rice" - Sony, Samsung, Sharp, Lenovo, Bosh, etc. Buy remanufactured - original.
  • #6 17329005
    strucel
    Level 36  
    Help: 271
    Rate: 623
    After all, 90% of the "new" terminals are remanufactured, i.e. stimulants cleaned, repainted and replaced wearing parts.
  • #7 17329045
    jacek0503
    Help: 28
    Rate: 175
    Well, if he insisted, 90% of cars are also "remanufactured". Also, I forgot to add the most important - used tires. "Lord Nightshockey, not a little whipped." Once I bought it - after an hour from the foundation it broke - thank God for the back. As if from the front I would not write here. "Lord, look at it - a knot like a nówka" - probably also "regenerated"
    Eidems
    Help: 83
    Rate: 253
    First of all, you can not regenerate the clamp? This is the best option. You can buy a used clamp and then regenerate it. Then you can look for a new one, eg lauber (original part after regeneration), and at the end of trw / bosch.
    bandi21
    Level 30  
    Help: 126
    Rate: 655
    The brands you mentioned are virtually unknown.Mapco I used to have something but I do not know the rest. I am mechanized 25 years and I do not know these brands. I used to buy cheap new rear calipers for audi a6, after six months stood hand-held in one of them. Most clamp failures it can be repaired and there are parts to it. Even from the original.
    lukasz12345678910
    Level 30  
    Help: 173
    Rate: 489
    I used to assemble those terminals for Ford Mondeo, after a year. I also think that it's better to regenerate the original.
    Jackall
    Help: 77
    Rate: 396
    Exactly. You do it yourself, you know what you have. Only you need to know how to do it. For this I take all, fat PLN 50 for repairing one clamp. Plus a set of elastics and often pistons. But some are still too expensive, because for 100 they have a "new fit" from turnover.
  • #12 17329689
    IBikeYou
    Rate: 9
    So the conclusion arises alone. It is better to avoid cheaper unknown companies such as those I have mentioned because as it has been said many times: "you buy something cheaper, it will come out more expensive". Damper clamp for regeneration and if it can not be purchased I will buy a new one. Thanks to everyone for help :)
The discussion revolves around the choice of rear calipers for the Mazda 6, specifically comparing cheaper brands like NTY, Mapco, and ABS against the more expensive Bosch option. Forum members express skepticism about the reliability of lesser-known brands, suggesting that it may be more prudent to invest in remanufactured original parts or to regenerate existing calipers. Several participants emphasize the importance of using identical parts on both sides of the vehicle and share experiences indicating that cheaper options often lead to higher long-term costs due to failures. The consensus leans towards avoiding unknown brands and considering regeneration or purchasing reputable brands like Bosch or TRW for better reliability.
TL;DR: "90% of 'new' calipers are remanufactured." Rebuild your Mazda 6 OE rear caliper first; if buying, pick Lauber/TRW/Bosch to reduce risk. [Elektroda, strucel, post #17329005]
Why it matters: Mazda 6 owners weighing NTY/Mapco/ABS vs Bosch or a rebuild get clear, field-tested guidance to avoid early failures and overspending.
Which rear caliper should I choose for a Mazda 6: NTY, Mapco, ABS, or Bosch?
Start with rebuilding your original caliper. If you must buy, pick a remanufactured OE unit like Lauber. For new, prioritize TRW or Bosch. This sequence balances reliability, support, and cost. [Elektroda, Eidems, post #17329059]
Is it smarter to rebuild my original Mazda 6 rear caliper?
Yes. Experienced members favor rebuilding the OE unit first. "Better regenerated original than crap made of rice." You keep the OE casting and refresh the internals. This avoids unknown quality from the cheapest new parts. [Elektroda, ociz, post #17328942]
Are most “new” budget calipers actually remanufactured?
Often, yes. One expert reports 90% of “new” calipers are remanufactured. That means cleaning, repainting, and replacing wear parts. Check listings for OE core and replaced components. [Elektroda, strucel, post #17329005]
How much will a Mazda 6 rear caliper rebuild cost in Poland?
Plan around 50 PLN labor per caliper. Add a seal kit, and sometimes a new piston. DIY reduces labor if you have the skills and tools. [Elektroda, Jackall, post #17329543]
Will cheap calipers fail sooner? Any timelines to expect?
Reports show early failure risk. A cheap new rear caliper had a seized handbrake after about six months. This illustrates why many prefer rebuilds or reputable brands. [Elektroda, bandi21, post #17329189]
Should I replace rear calipers in pairs?
Yes. Mechanics advise replacing both sides with identical parts. This keeps braking behavior consistent across the axle. [Elektroda, cirrostrato, post #17328478]
What brands are recommended if I must buy instead of rebuild?
Choose a Lauber remanufactured OE caliper first. If buying new, pick TRW or Bosch. These options carry better trust than unknown budget labels. [Elektroda, Eidems, post #17329059]
Can I buy a used caliper and rebuild it reliably?
Yes. Buy a used caliper as a core and rebuild it with a kit. "This is the best option." It offers solid value while retaining OE design. [Elektroda, Eidems, post #17329059]
Quick how-to: How do I rebuild a sticking rear caliper?
    1. Remove the caliper, strip it, and carefully extract the piston.
    1. Clean the bore, fit new seals from a rebuild kit, and replace the piston if worn.
    1. Lubricate guide pins, reassemble, bleed, and confirm free parking-brake movement. [Elektroda, Jackall, post #17329543]
What’s a common failure with rear calipers that include a handbrake?
The parking-brake mechanism can seize. One budget caliper locked the handbrake after about six months. Rebuild the unit or replace it to restore proper operation. [Elektroda, bandi21, post #17329189]
Is Bosch worth the ~600 PLN price?
Owners reported Bosch around 600 PLN per side and expect long service “for many years.” Choose Bosch if you can’t rebuild or want a long-term fit-and-forget option. [Elektroda, IBikeYou, post #17328395]
Do Mapco, NTY, or ABS have user feedback here?
A 25-year mechanic called these brands virtually unknown. He used Mapco before but couldn’t attest to quality. Limited feedback suggests caution. [Elektroda, bandi21, post #17329189]
What parts should I expect to replace during a rebuild?
Budget for a seal kit and often a new piston. These are commonly replaced wear items during caliper repair. [Elektroda, Jackall, post #17329543]
How do I verify a genuine remanufactured OE caliper listing?
Look for an original housing that’s cleaned, repainted, and fitted with new wear parts. If unclear, ask the seller to confirm. [Elektroda, strucel, post #17329005]
