Hello, maybe someone from you car radio Vordon HT-869V2 and knows how to set APN for internet and wifii because there is such an option search for wifii and APN password I wanted to share the internet from my phone and I have no idea what to enter.
radio-samochodowe-vordon-ht-869v2-kamera-cofania-4smdpl_835076_2322904_350x350w50.jpg(18.6 KB)
You must be logged in to download this attachment.
I don't know, I don't know how to do it, I don't have it in my hand, I don't see its configuration options. However, I know what APN is and I know it's not for that. Does this radio have WiFi at all? Because it doesn't look ... The user manual will certainly help.
I found something like this may be useful to someone. 1.Connecting the radio:
black (GND) connect to -12V
yellow (BATT) connect to + 12V directly to the battery
red (ACC +) connect to + 12V through the ignition switch.
2. Button Backlight:
ILLUMI connector should be connected after + 12V dipped beam. Then it is not enough that the radio button backlight turns on, it can also switch day / night mode (display backlight)
3. Connecting the reversing camera
+ 12V after reversing light to the CAR BACK connector. And the signal cable from the camera should be connected to CCD AV-IN.
4. Watching video
If the message about the inability to watch video materials while driving is displayed, connect -12V after the handbrake control or to bypass the protection completely, short-circuit the ground to the BRAKE CONTROL connector.
5. Connecting the steering wheel control
Two KEY1 and KEY2 cables come out of the radio, additionally you have to lead the ground wire from the radio marked GND. The buttons are programmed from the radio level on the basis of appropriate resistance. If a separate cube comes out of the steering wheel, it is possible that the easiest way will be to buy, e.g. allegro, a ready adapter for steering from the steering wheel. Then the seller should ask about the connection scheme of such an adapter.
6. Updating maps on the radio
Update Instructions:
1. Delete everything on the memory card with the old navigation program.
Then after connecting the radio and pressing "Mobile connect" in the main menu
the device should be connected to the phone (accept the notification on the phone) and a QR code should be displayed for scanning with the phone (you need to download such a reader from GOOGLE PLAY if you do not have one on your phone). Under the QR code there is a link to download the software to the phone. The phone must therefore be connected to the internet. After installing the software, everything should work. We plug in the rear USB.
If there is a problem when setting the path to the AutoMapa EU.exe file (after switching from the map to other functions of the radio (FM radio, reversing camera etc.) and trying to return to navigation, the program freezes and only a black screen is displayed) The path should be set to a file wceAm.exe then AutoMapa works the same as other navigation programs.
10. Logo change
1. Please enter the settings (small gear under the clock).
2. Then go to the bottom and click "About device".
3. Then click on "Restore Settings ...".
4. Enter 3711.
5. Click Other (bottom left corner).
6. Click the down arrow.
7. For the Logo option, choose Enable.
8. Save the settings by clicking SAVE at the top of the screen.
9. Restart the radio.
10. The code to change the startup logo is 8888.
Create an account, log in here and be active on the forum — ads won't appear. Earn points for registering and replying.
The discussion revolves around configuring the APN and WiFi settings for the VORDON HT-869V2 car radio. Users clarify that APN settings are for GSM internet connections, not WiFi. There is uncertainty about whether the VORDON HT-869V2 has WiFi capabilities, as the user manual lacks relevant information. One user provides detailed wiring instructions for connecting the radio, including power connections and additional features like reversing camera integration and steering wheel control. The lack of WiFi functionality is a recurring theme, with suggestions to consult the user manual or online resources for further assistance. AI summary based on the discussion. May contain errors.
