Hello. This description has a poor manual (in attachment). Remember that you can only see LOGO the first time you start it, or whenever you do not use memory support.
vordon-HT-869V2_pl.pdf(18.73 MB)
You must be logged in to download this attachment.
I have this manual, but absolutely nothing to expand the menu ... Neither words ... The menu always shows me the possibility of choosing a logo. The radio is rather well connected, because I've plugged the power supply from the ignition switch (red cable replaced with yellow) and remembers the radio settings, i.e. It remembers the phone, stations, wallpaper and sound settings. Do you mean writing about keeping the memory? Did I understand you well?
From your description does not show exactly how you have it connected, you only write about one cable, but in this topic it is not important, because if you have, for example, the memory settings of the sound memory is always powered. On this radio, for the logo to be displayed each time after switching on, both cables (red and yellow) must be disconnected. The station's memory will be saved, but for example, the sound setting is not.
You go into settings At the very bottom you have (About device) click At the top, next to the back arrow, you have to reset the settings. You provide the code 3711 And you are there. You'll probably have to program your radio stations again.
I will connect to the hidden menu: there is the FM sensitivity option (FM sensitivity). The value is set to 180. It is possible to correct - or +. What will the value change be for example +? Maybe someone has changed this value and what effect did it bring?
The discussion revolves around unlocking the hidden menu on the Vordon HT-869V2 radio. Users share their experiences and troubleshooting steps. One user mentions that the manual lacks information on expanding the menu, while another provides a step-by-step guide to access the hidden menu by navigating to the settings, selecting "About device," and entering the code 3711. There are also discussions about the radio's memory settings and the importance of connecting the power supply correctly to retain settings. Additionally, a user inquires about the FM sensitivity option available in the hidden menu and its potential effects when adjusted. AI summary based on the discussion. May contain errors.
