Is it possible to install Windows 7 via USB on Lenovo Yoga Tablet 2-1050L Android?
_Dzikusss_ 11574 8
  • #1 17335248
    _Dzikusss_
    I would like to know if it is possible to install Windows 7 on an Android tablet using a booted USB flash drive?
    If so, is it the same way as on a computer or another?
    Thanks in advance
  • #2 17335343
    pawel1148
    Help: 56
    Rate: 232
    Probably not.
    Enter the tablet model, because many devices can be called a tablet.
    The first problem is that Windows 7 was unlikely to be used on tablets, then Microsoft was making a separate version for mobile devices, only 8 and 10 appeared on tablets.
    At the same time there was a variety of tablets on Intel Core, which turned into hybrid laptops, there was Windows 7.
    In general, tablets are unlikely to use Bios or UEFI prepared for Windows, so the installation will be rather a problem. In addition, you must have the appropriate version of Windows for the tablet. Windows 8 and 10 are supposed to be universal, but only seemingly. It will be easier if there is a clone on Windows, if this tablet has ARM, it's rather hard.
    In addition, if the tablet is ARM-enabled, you will not install windows 7 on it, even if you install a newer version, programs designed for x86 will not work, i.e. 90% of applications from outside the Microsoft store. If it is on an atom and has no more than 1GB of RAM, it's also bad.
    Sam, tempted by the vision of a tablet with Windows, I gave up searching for such an installation for the purchase of a Chinese with Windows 8.1 and I was severely disappointed, Android on an Atom with 1GB of RAM flashes like crazy, while I have an almost identical tablet with Windows 8.1 and I do not use it, which True, most windows programs will install and run there, but the speed of operation leaves much to be desired. Windows is simply 4x slower in my opinion. Apart from the operating time, because Android has been turned off for almost 2 months, Windows works much shorter (I honestly don't remember whether it's time in individual hours or dozens).
    The question is what equipment do you have, because if it is weak, it is a pity to bother.
  • #3 17335358
    _Dzikusss_
    My tablet is a lenovo yoga tablet 2-1050L with parameters:
    -CPU: Intel Atom Processor Z3745 (2M Cache, 4 cores, up to 1.86 GHz)
    -battery: 9600mAh (NOM)
    - built-in memory: 16GB
    - RAM memory: LP-DDR3 2GB
    - Current system: Android 5.0.1 Lolipop
    It seems to me that this is the most important information
    If I can install win 10 on it via a pendrive, it would suit me too, but would it be fine?
  • #4 17335889
    nutergsm
    Help: 1034
    Rate: 1665
    There is a movie on the yutube as they upload, but you can easily damage the tablet and then it is only suitable for disposal.
    Why do you need Windows on a tablet?
  • #5 17336154
    _Dzikusss_
    For the purpose of writing web programs and the like and for android systems it is not possible to download ,, notepad ++ ,, that is, but it is a notebook and for windows systems it is a special program for writing programs
    And since I have an order and at home it will not be possible to take a computer, anyway, because I have a pc
    nutergsm
    Help: 1034
    Rate: 1665
    It is better not to buy a tablet typically for this purpose than to combine it?
    Anyway, on android you will find applications in which you can program.
  • #7 17336184
    _Dzikusss_
    On the other hand, right, and do you have any command applications similar to notepad ++?
  • #9 17336256
    _Dzikusss_
    Thank you for your help
    The problem is solved, I close the topic
The discussion revolves around the feasibility of installing Windows 7 on a Lenovo Yoga Tablet 2-1050L, which features an Intel Atom Processor Z3745. Initial responses indicate that installing Windows 7 on an Android tablet is highly problematic due to compatibility issues with BIOS/UEFI and the architecture of the tablet (ARM vs. x86). Users suggest that Windows 8 or 10 might be more suitable for such devices. The author expresses a need for Windows to run specific programming applications like Notepad++, which are not available on Android. Alternatives for programming on Android are suggested, along with links to relevant applications. Ultimately, the author concludes that the problem is resolved without pursuing the Windows installation.
