[Solved] Audi A6 C6 (2008) 2.4 V6 Petrol MT: Fuse Box under Hood Amps & Placement - Need Scheme
Cipun1 53880 2
  • #1 17335291
    Cipun1
    Rate: 45
    I can not find a fuse scheme on the network in the box under the hood (cowl). It is not about which burnt, but what should the fuses of what amps be?
    During the car repair it happened that the fuses were removed (all) and I do not know how to put them into action.
    Auto is Audi A6 C6 year 2008 engine 2.4 V6 petrol, manual transmission
    I will add that I have broken several user instructions and all fuses are described outside this box.
    KMal
    Help: 340
    Rate: 1434
  • #3 17586406
    Cipun1
    Rate: 45
    I used the attached picture
