Renault 1.9 dci F9K - tightening torques for cylinder head bolts
pp_pablo 47937 2
  • #1 17336295
    pp_pablo
    Help: 93
    Rate: 405
    Trafic 1.9dci F9K 101KM. 2004-2006rok.
    If anyone has data please.
    PS. If you find the moment data for operating the entire engine (shaft, cranks, accessories, etc.), it's even better ;)
    moto-kord
    Help: 137
    Rate: 505
    Here you are
    Replace the screws
    (Do not oil)
    Cylinder head (screws)
    (Only non-metallic seal)
    Stage 1 30 (Nm)
    Stage 2 100 ? 4 (°)
    Stage 3
    (Wait 3 minutes)
    Stage 4
    (Loosen screws 1 and 2)
    Stage 5 25 (Nm)
    Stage 6 213 ? 7 (°)
    Repeat steps 4, 5 and 6 for screws: 3-4, 5-6, 7-8, 9-10
    (Only metal cylinder head gasket)
    Replace the screws
    Stage 1 30 (Nm)
    Stage 2 30 (Nm)
    Stage 3 230 ? 6 (°)
    Connecting rod foot bearing cover
    (Threads slightly lubricated):
    Stage 1 20 (Nm)
    Stage 2 40 ? 6 (°)
    Main bearing cover
    (Threads slightly lubricated) 60 - 67 (Nm)
    Oil pan 15 (Nm)
    Engine oil drain plug 20 (Nm)
    Oil filter 20 (Nm)
    Injector 25 (Nm)
    Glow plugs 15 (Nm)
    Oxygen sensor 27 - 34 (Nm)
    Starter 44 (Nm)
    Alternator 50 (Nm)
    Valve cover 12 (Nm)
    Valve cover 10 (Nm)
    Camshaft bearing covers 30 (Nm)
    Crankshaft pulley
    Replace the screw
    Stage 1 20 (Nm)
    Stage 2 115 ? 15 (°)
    Timing belt tensioner pulley 50 (Nm)
    Flywheel 60 (Nm)
    Exhaust manifold 21 (Nm)
    Intake manifold 10 (Nm)
    Coolant pump 9 (Nm)
  • #3 17336375
    pp_pablo
    Help: 93
    Rate: 405
    Thank you very much.
