[Solved] Seeking Torque Specifications for Main Shaft & Connecting Rod Bolts in Renault 1.5 DCI 2008
gangster1 107413 5
  • #1 10828226
    gangster1
    Rate: 26
    Hello everyone, I need information as in the title, car from 2008, 1.5dc and 105km, I am mainly interested in main shaft and connecting rod alloys, but if there was a possibility for other bolts, I would be very grateful.
    thank you greetings
    zeimp
    Moderator on vacation ...
    Help: 548
    Rate: 2345
    As you did not specify a specific model, I am giving you engine data 1.5D dCi 2005-10 Engine code: K9K 732
    The cylinder head:
    Screw replacement: Yes
    Tightening: 25 Nm
    Tightening: 25 Nm
    Tightening: 270 ° ? 10 °
    Remaining engine tightening torques:
    Main bearing Replace bolts / nuts: Yes
    Main bearing 1st stage: 25 Nm
    Main bearing 2nd stage: 47 ° ? 6 °
    Connecting Rod Bearing Replace Bolts / Nuts: Yes
    Connecting rod bearing 1st stage: 20 Nm
    Connecting rod bearing 2nd stage: 45 ° ? 6 °
    Oil pump to engine block: 25 Nm
    Oil pan bolts: 14 Nm
    Oil drain plug: 20 Nm
    Clutch pressure plate to flywheel: 15Nm 6sp = 12Nm
    Center Crankshaft Pulley / Muffler Pulley Bolt:
    M12 = 60 Nm + 100 ? 10 °
    M14 = 120 Nm + 95 ? 15 ° - Use new screws!
    Camshaft pulley: 30Nm + 86 ? 6 °
    Camshaft bearing / camshaft housing: 11 Nm
    Engine head cover: 11 Nm
    Exhaust manifold to engine head: 26 Nm
    Coolant pump: 11 Nm
    Injection nozzle / yoke for cylinder head: 30 Nm
    Fuel injection union nut: 24 Nm
    Fuel injection / fuel pump pulley: 55 Nm
    Injection / fuel pump flange: 21 Nm
    Injection / fuel pump holder: 21 Nm
    Glow plugs: 15 Nm
    Crankshaft position sensor / RPM sensor: 10 Nm
    Camshaft position sensor: 8 Nm
    Engine oil pressure switch: 30 Nm
    Oil filter: 14 Nm
    Tightening torques - body:
    Front wheel hub: 280 Nm
    Rear wheel hub: 175 Nm
    Handlebar: 44 Nm
    Steering gear mounting: 105 Nm
    Tie rod outer joint: 37 Nm
    Front hub brake disc: 15 Nm
    Brake calliper to front brake calliper bracket: 32 Nm
    Front brake caliper / brake caliper holder: 105 Nm
    Rear hub brake disc: 15 Nm
    Brake calliper to rear brake calliper bracket: 36 Nm
    Rear brake caliper / brake caliper holder: 105 Nm
    Wheel nuts / bolts: 110 Nm (use copper assembly paste).
  • #3 10834858
    gangster1
    Rate: 26
    Thanks very much, that's what I meant, best regards and I get to work.
  • #4 16465097
    WesterPlatte75
    In the Reply to the topic, I did not find the tightening torque of the valve cover. Could you please pass? My model is 1.5dci 106KM 2006, thanks.
    I have one more question whether the valves in this model are subject to any adjustment because I have the impression that they are too loud when the engine warms up. I can add that 90% of the gasket under the valve cover needs to be replaced, can the noisy valves at higher temperatures be caused by a defective gasket?
  • #5 17171712
    Balu
    Help: 323
    Rate: 48
    I will slightly dig out the topic ... the brake disc to the hub at the rear, it does not tighten 15Nm ...
    1.5 dci integrated bearing, what torque to tighten the shield nut?
  • #6 20652320
    KINZYZR
    175 Nm
