Beko RCNA365E30ZX fridge - when the door is closed, the fridge bubbles
koles75 19194 6
  • #1 17338508
    koles75
    I have such a problem that when I close the door of the fridge, it gurgls for a moment, that's how it is every time. :(
    However, when closing the freezer door, nothing like this happens.
    Did any of you have such a problem ??
  • #2 17338972
    Budrick
    Help: 22
    Rate: 102
    Hmmm depends on what it is bubbling .... But I've had cases that it was caused by transporting the clearance of the condensate drain pipe from the refrigerator evaporator.
  • #3 17339007
    koles75
    I am able to delete it myself or do I need to call the service?
  • #4 17339010
    kierbedz4
    Level 36  
    Help: 307
    Rate: 1008
    Clean the drain pipe which is mounted in the bottom of the refrigerator and its end is located in a plastic vessel built-in on the compressor aggregate. To unblock this hose you can use the cable from the tractor's operating hours or a section of the electric wire.
  • #5 17339045
    Budrick
    Help: 22
    Rate: 102
    The drain can be behind the panel
  • #6 17339428
    koles75
    Thanks, I'll check it out :)
    The wife also said that it has not been two years since the purchase, so the warranty should be
    So I have to look for a receipt, then I will call the service because I have to rummage myself
  • #7 17343478
    kierbedz4
    Level 36  
    Help: 307
    Rate: 1008
    Nobody tells you to bury in individual elements of the fridge. All you have to do is unblock this hose, which is the flow of water from the gutter through the hose to the tank located on the compressor housing. This activity is probably not covered by the warranty. Show off the amount the service will issue you with. This action does not take me more than about 5 minutes.
The discussion revolves around a Beko RCNA365E30ZX fridge that produces a gurgling sound when the door is closed, a phenomenon not observed with the freezer door. Users suggest that this bubbling may be due to a blockage in the condensate drain pipe connected to the refrigerator evaporator. Recommendations include cleaning the drain pipe, which can be accessed from the bottom of the fridge, and using tools like a cable or electric wire to unblock it. The original poster considers checking the drain and mentions the fridge is still under warranty, prompting a potential service call if self-repair proves difficult.
