Improving T-Mobile LTE Speeds in Niegoszowice: Antenna Recommendations for Huawei B525s
KinchMike 6435 1
  • #1 17359470
    KinchMike
    Half a year ago I bought a T-Mobile Internet home offer - LTE, no GB restrictions. In the previous place of residence everything flashed, unfortunately it is very bad after moving - I pull out 5-10 mB / s. And sometimes five times less.
    I live in Niegoszowice near Krakow - if it matters. Which antenna (preferably the best) could I buy to:
    - best amplified the signal,
    - it was simple to connect to tmobile equipment.
    Thank you in advance!
    Michael
  • #2 17359592
    matek451
    Help: 4352
    Rate: 5808
    Test on B525 using HManager http://www.mediafire.com/file/79obbe81eufdt7t/Huawei_Manager_1.2_EN.apk/file, router outside. HManager will show the BTS CID and signal parameters from the BTS you are connecting to. Take a speed test. Two verified BTS Networks with LTE1800 are in Pisary and Zabierzów-Spokojna 4. They are clogged, sometimes 3G works better with UMTS2100HSPA + DC T-Mobile. are also on these BTSs. At 525 you can also force this band with HManager. check them out. The nearest BTS with LTE800 T-Mobile in Krzeszowice, you will also force this band in HManager and check. After the tests, the antenna selection but rather at 1800-2100MHz.
