[Solved] Lenovo Ideapad 320: Issues with System Restart and BIOS Access after Gaming Session
Ernst Stavro Blofeld 39735 6
  • #1 17360595
    Hello everyone,
    I have a problem with the Lenovo Ideapad 320 laptop. During the game, I received a message about the problem and the need to restart the system. The thing is, it does not start again. The Lenovo screen is shown, then he makes "wziuuu", as if he turned off and goes to "cheeking media". On YT advised to enter the BIOS and BOOT UEFI change to LEGACY. I did it but it did not help. The "cheeking media" message only changed for a longer period. Besides, everything is the same. What's worse, I can not enter the BIOS now. I press F2 and nothing happens. As once I had held the mentioned key for too long, the laptop made a loud squeak. What should I do in this situation? Please help. :(
    DespKaMRaT
    Rate: 13
    maybe it's trivial but does it detect your disk in a bios? check it on another pc. Maybe the RAM memory is failing? the reasons can be many. I would first check the simplest ones. If, however, you could enter the bios, then restore the original settings (probably the f6 key), you can also take out the bios battery for a minute.
    safbot1st
    Help: 2719
    Rate: 1585
    He wrote that he can not go in there.
    @Ernst Stavro Blofeld Detach the disk completely and see if it can be entered in the BIOS.
    You probably have a damaged hard disk ...
  • #4 17360744
    So yes: I was able to re-enter the BIOS thanks to the Novo button. You're right that it does not detect your hard drive. I tried to read the last working settings, but again - nothing has changed, maybe except the new message - "boot failed". I do not really know how to remove the BIOS battery (I am a complete layman in this matter), or how to disconnect the drive. As for the last one, I do not think it would give anything if it does not even detect it. But I can be wrong, you are the experts here. The laptop is still under warranty, I have it for several months, but to be honest, I do not want to wait two months until they return it to me dilapidated. What you hear about the Lenovo service can really scare you ... It would be great if I could do something on my own thanks to the knowledge of forum members. Do you have any tips or ideas?
    safbot1st
    Help: 2719
    Rate: 1585
    Do you have a laptop under warranty and you really want to "pick it" yourself? - Your decision.
    Improve HDD assembly:
  • #6 17360782
    I may not have picked - I was counting on myself that I would do without handicrafts that would affect this guarantee. xD Thanks for the video, I'll take a look right away.
  • #7 17419831
    The laptop has been repaired on the website.
The Lenovo Ideapad 320 user reported issues with system restart and BIOS access after a gaming session, encountering a "checking media" message and inability to boot. Initial troubleshooting included changing the boot mode from UEFI to Legacy, but this did not resolve the issue. The user later managed to access the BIOS using the Novo button, discovering that the hard drive was not detected. Suggestions from forum members included checking the hard drive and RAM, and considering the possibility of a damaged hard disk. The user expressed reluctance to perform repairs themselves due to warranty concerns and sought further advice on potential solutions.
