[Solved] Connecting Soft Start to Scheppach HS 100s Saw: Assembly Guidance Needed
DanFal 35661 8
  • #1 17366662
    DanFal
    Rate: 24
    I bought a Scheppach HS 100s saw, I want to add a soft start to it, but I have a problem with the assembly. After searching similar threads, I'm not sure how to do it in my case, what to connect with what. In the picture I described the problem, I gave numbers for ease:
    1-2 - go from the plug of the device
    3-4 - go to the engine
    How to put it together so that it works properly? Please make it as simple as possible :)
    Connecting Soft Start to Scheppach HS 100s Saw: Assembly Guidance Needed Connecting Soft Start to Scheppach HS 100s Saw: Assembly Guidance Needed
  • #2 17366674
    Pedros050
    Help: 2471
    Rate: 3923
    We connect soft start like this.
  • #3 17366903
    DanFal
    Rate: 24
    I've seen that description, but unfortunately I'm still not quite sure what it's supposed to be like. I will be grateful for such a pathological instruction. I know I'm not the only one looking for it, I'm sure it will be useful for many people.
  • #4 17366910
    Pedros050
    Help: 2471
    Rate: 3923
    It's very simple. A and B are 230V power supply after the switch, and A and C connect the motor to a soft start after the switch that turns on the motor.
  • #5 17366960
    DanFal
    Rate: 24
    I made a small drawing to show how I understand it, but I will also describe it:
    - I pull out the connector 4 and give the blue wire instead of it from the soft start
    - disconnected connector 4 connect to the black wire
    - I divide the red one into two, I put one in place of connector 3 and connect the other with it
    I do everything on the outputs of the wires behind the switch that go to the engine.
    I do everything on connectors, so that it can be removed, e.g. under warranty.
    This is what it should look like?
  • #6 17369454
    Pedros050
    Help: 2471
    Rate: 3923
    There is a diagram on the housing: red and blue power supply, black and blue motor.
  • #7 17370490
    DanFal
    Rate: 24
    Did I really mess something up, or is it going to be fine as it is now? I apologize for the crudeness of my paintings :)
  • #8 17370675
    noel200
    Help: 36
    Rate: 815
    It will be ok. You connect blue to 4, to blue, connect red to the switch in place of 3, disconnect the brown wire going to the engine from the switch, and connect it to the black one from the soft start. And that's all.
  • #9 17371669
    DanFal
    Rate: 24
    Ok I will. Thanks for help ?
    Edit: Everything works I highly recommend.
✨ The discussion revolves around connecting a soft start to a Scheppach HS 100s saw. The user seeks assembly guidance, specifically how to connect the wires from the device plug to the motor via the soft start. Various responses provide detailed instructions, including diagrams and descriptions of wire connections. Key points include connecting the blue wire from the soft start to connector 4, the red wire to the switch in place of connector 3, and the brown wire from the switch to the black wire from the soft start. The user confirms successful implementation of the guidance provided.
