[Solved] PHILIPS LED 32PFS5823 TV is kind of smart but where are the rest of the applicat
wertiko7 12009 6
  • #1 17378381
    wertiko7
    Rate: 98
    I bought the PHILIPS LED 32PFS5823 TV which they advertise as smart.
    I was sure that if smart, there would be applications like hbo go and showmax.
    But I can't find it or can't find it. There is netflix and you tube and I still care about hbo go.
    Do any of you know what applications are available on this tv.
  • #2 17378435
    mirex
    Help: 1950
    Rate: 1987
    Maybe they are available in the "Store"? ;)
  • #3 17378461
    wertiko7
    Rate: 98
    I type and show that I found nothing. In gallery apps.
  • #4 17514306
    wertiko7
    Rate: 98
    The system in this model is not Android but some Saphi.
    Maybe you know if it is possible to install this TV hbo go?
  • #5 17514607
    mirex
    Help: 1950
    Rate: 1987
    All in all an interesting thing.
    Saphi is Linux. Kodi too. ;)
    In your case, at least for now, there is probably no other way than to buy a TV box, install Kodi 18 and HBO plugin.
  • #6 17945581
    djadiw
    Rate: 20
    I managed to solve the problem or lime
  • #7 17945728
    wertiko7
    Rate: 98
    Lipa - I don't even know how to install hbo on tv.
✨ The discussion revolves around the PHILIPS LED 32PFS5823 TV, which is marketed as a smart TV. The user expresses frustration over the lack of popular applications like HBO Go and Showmax, noting that only Netflix and YouTube are available. Responses indicate that the TV operates on the Saphi OS, not Android, limiting app availability. Suggestions include checking the app store and considering the installation of a TV box with Kodi to access HBO Go through plugins, as there are currently no direct options for HBO Go on this model.
