Philips Smart TV PUS8303 / 12 on Android with blocked content HBOGO
jam69 35034 4
  • HBOGO blocked by Philips Android TV policy
    #1 17479194
    jam69
    A few days ago I bought a LED TV Philips 55PUS8303 / 12 with Android. Technically, I do not have any serious reservations about this TV, but I was very surprised to block the HBOGO application in the Google Play Store. Actually, it is not blocked, but does not appear in the search engine on the TV, which eventually comes to one because it can not be installed.
    Online content from the hbogo site is also blocked from the browser level. So even after logging into the hbogo site, watching movies is impossible.
    It is not a matter of technical defect of a particular copy because during a telephone conversation with a Philips customer support employee I received information that I am not an isolated case and more and more customers complain about a similar problem. "This is company policy"
    It's a pity, because again, the company's policy is not going hand in hand with the client's good,
    Many translate the white centrally placed button on the TV plot with the NETBLIX word - but it gave me the opportunity to send it after the fact when the TV hung on the wall.
    Q: is there any way how to deal with the described problem - the more sharp I immediately answer that TV replacement is not an option! -
    once I have this TV and access to HBOGO I would like to take advantage of it.
  • #2 17479482
    Belialek
    Help: 19
    Rate: 124
    Install the KODI app - then you can easily find the HBO plugin (and hundreds of others) from its level.
  • #4 17484023
    Belialek
    Help: 19
    Rate: 124
    It's a bit of fun with it, but once you get it in the beginning, it's already downhill with other plugs :) Thus, you cut yourself off from the whims of the producer regarding the availability of plugins - it is easier to click on one button on the remote control than to launch the KODI, but something for something.
  • Factory reset temporarily restores HBO GO activation
    #5 19060848
    jurexu
    Rate: 14
    Hi!
    Have you coped or has someone else dealt with this problem?
    I just bought this TV and I also have a problem with activation. While I can install the application from Google Play (generally it is not visible from the level of the application from the TV, but if you have previously installed it on something else, you will find it in "my applications"), it cannot be activated - i.e. you cannot enter the code activation in the field intended for this because it is inactive. It helps to return to the factory settings and then you have to install and activate again - then no problem. The problem is that the TV loses activation after about 2 days and to be able to continue watching you have to return to the factory settings of the TV over and over again if you insist on watching HBO GO on a Philips with Android. Or maybe the problem is that my TV set "stays" in Germany and the client with German IP cannot watch HBO GO in Germany. I don't know anymore ...
