[Solved] Panasonic TX50CS630E: Can't log in to Ipla on TV, despite correct login info & updates
qwazarpl 4716 3
  • #1 17383148
    qwazarpl
    Help: 37
    Rate: 270
    Strange thing.
    I set up an account on Ipla and I can log in on any device, not on TV.
    I enter 100% correct login and password and it pops up that the entered data is incorrect.
    So I set up another account via the TV application, confirmed the link received in the email and I cannot log in to this account on TV.
    The device has the latest software for it.
    What may be the problem?
  • #2 17383455
    Wersetowaty
    Help: 10
    Rate: 37
    The problem may be in the application.
  • #3 17383765
    qwazarpl
    Help: 37
    Rate: 270
    Somewhere I read that the problem may be the disabled cookies option, but I checked in the menu and it is enabled.
    Reply from Ipla:
    We kindly inform you that currently the login option on Panasonic TVs is not possible. At the same time, we would like to inform you that our specialists are in constant contact with the TV manufacturer, working together to provide the above functionality. Until then, we encourage you to use IPLA with other devices.
  • #4 17384364
    qwazarpl
    Help: 37
    Rate: 270
    Reply from Ipla:
    Added after 6 [hours] 5 [minutes]:
