[Solved] Samsung UE48H6700: Issues with Ipla and Player.pl Not Loading or Causing TV Reboot
pawel84lbn 36186 6
  • Ipla and Player fail while other apps work
    #1 16703349
    pawel84lbn
    Rate: 13
    For some time I have a problem with Ipl and Player.
    Ipla does not want to turn on at all, only the loading bar appears, after which she returns to choosing the application after a long time.
    In the player, on the other hand, the same happens, except that after selecting the material to watch, the loading bar spins, after which the TV reboots.
    I would like to add that the other Youtube applications, etc. work without a hitch.
    I have no idea what may be the cause, maybe you've had a similar problem.
    Thanks in advance for all the info. :D
    leszekpo59
    Help: 151
    Rate: 263
    Welcome. Try it can change the internet delivery to TV. Instead of WI-FI connect with a cable (or vice versa). Greetings.
    KOCUREK1970
    Help: 3857
    Rate: 5481
    Sure, the application owners have changed something in them and a new version of the players on tv is needed.
    You will not do anything about it.
    It should (if available) upload the latest TV software.
    If you do not have one, you will not do anything about it.
    Sometimes it helps to reset the tv and reset SMART TV.
  • #4 16704979
    pawel84lbn
    Rate: 13
    Sure, Kocurek, you're right. The latest software is already uploaded to the TV. How do I go through the Web Browser to the Ipli website the same, it turns
    only the loading bar ...
    KOCUREK1970
    Help: 3857
    Rate: 5481
    This whole SMART TV is one big misfire and misunderstanding.
    How can anything work, like a tv producer (its software) has no power or power to work in creating and improving external applications.
    The only thing that can do is give you info (and that's not always, because the company will change something and the manufacturer does not even know anything about it): "from the day ..... ... ceases to operate our services / application on our products .... .. for reasons beyond our control. "
    Although there are also such flowers that everything works on tv from 2013 and earlier, between 2014 and 2016 nothing works, and from 2017 it will work again (of course only on new TV from 2017/2018) but until when it will work again ...?
    Two options to choose from:
    Wait for a new softa for this tv, or buy Android dongle tv and have what you need, and not always in the nerves and uncertainty, when I'm going to "drop out" again.
    Specjalista_CP
    Please, write to us if an error message has been displayed. If so, which one?
    Have you tried to restore factory settings?
    Give us the exact model of the device on which the problem occurs.
    Which Internet connection do you use (mobile, landline) and what speed?
  • #7 17150501
    pawel84lbn
    Rate: 13
    I connected the TV directly with the network cable and IPLA is spinning :-)
The discussion revolves around issues with the Ipla and Player.pl applications on the Samsung UE48H6700 TV, where Ipla fails to load and Player.pl causes the TV to reboot. Users suggest troubleshooting steps such as switching the internet connection from Wi-Fi to a wired connection, updating the TV's software, and resetting the SMART TV settings. Some users express frustration with the reliability of SMART TV applications, noting that older models may function better. The author confirms that connecting the TV directly with a network cable still results in Ipla not loading.
