After the reset, I can't log in to the Huawei B315 router as admin
tonienick 33129 6
  • #1 17383593
    tonienick
    As I wrote in the subject, I can't log in to the admin page at 192.168.8.1 to the Huawei B315 router.
    The problem is that in the instructions and on the Internet in various guides it is written that after resetting this router its password and login is "admin".
    There is no space to enter the login and when I enter the password I am shown a message that it is incorrect.
    I don't remember the password from before the reset, which is why I reset the router. If you know how to help me, I would be grateful. :wink:
    Below I send a screenshot from the administration panel.
  • #2 17383645
    jurtur
    Help: 26
    Rate: 81
    Check if you don't have Caps Lock pressed or another keyboard has not been turned on.
    The reset button was held long enough, of course.
  • #3 17383939
    tonienick
    It seems to me that the problem does not occur on the device from which I try to log in (because I tried both through the computer and through the browser on the phone and through the HiLink application to operate the router).
    In none of these attempts I did not have capslock pressed.
    I will add that I reset the router several times and the problem persists all the time.
  • #4 17384120
    jurtur
    Help: 26
    Rate: 81
    Check the IP address on the computer through which you connect to the router.
    Command line = cmd = ipconfig
  • #5 17411903
    szarik1404
    Help: 23
    Rate: 124
    Hi, if you haven't solved the problem, check the bottom of the router to see if there is a wpa key, if it is, enter the first six characters in the password field. If it doesn't work out, try the whole one.
    Hi, if you haven't solved the problem, check on the bottom of the router if there is a wpa key, if it is, enter the first six characters in the password field. If it doesn't work, try the whole one.
  • #6 17787699
    dan_01
    I dig a little but I have a similar problem. After resetting the Huawei B315s-22 router, I cannot log in to the panel. The panel works, I enter the password correctly (user admin, password from the bottom of the router), unfortunately I am still not logged in. When I try to go to any subpage of the panel, it crashes the login window, and after (supposedly) logging in, it goes to the main page of the panel and is still not logged in. If I insert a card where a pin is required, there is no way to enter this pin because there is still a login window. Has anyone ever encountered this condition and managed it? I used different computers and different browsers and unfortunately it didn't help ...
  • #7 17787754
    matek451
    Help: 4352
    Rate: 5808
    For B315 the panel is logged in and the password is admin, then the sticker is for the WiFi network on it.
The user is unable to log in to the admin panel of their Huawei B315 router at the IP address 192.168.8.1 after performing a reset. Despite following instructions that state the default login credentials are "admin" for both username and password, the user encounters an incorrect password message. They have attempted multiple resets and checked for issues such as Caps Lock being on, but the problem persists across different devices and browsers. Other users suggest checking the router's bottom for a WPA key, which may provide the correct password, and confirm that the login credentials are indeed "admin". One user reports a similar issue with the Huawei B315s-22 model, where they can enter the password but are still not logged in, indicating potential software or configuration issues.
