Huawei B315 Router: Access Configuration Panel via Desktop LAN Connection - IP 192.168.8.1
dj crazy 9183 13
Why can I ping my Huawei B315 at 192.168.8.1 from a PC on Ethernet but not open its configuration page in any browser, while the same address works from a phone on Wi‑Fi?
If 192.168.8.1 replies to ping but the router page will not open, the thread’s best advice is to verify the URL as http://192.168.8.1, try several browsers, and temporarily disable antivirus/firewall to rule out local blocking [#16422326] [#16422455] [#16422467] If that still fails, test Safe Mode with Networking or an incognito/private window, because the problem may be in Windows or another application rather than the router itself [#16422902] It was also suggested to test from another system, such as a Linux Live CD, and to try other LAN ports on the router to isolate the fault [#16424949] [#16425438] Later testing showed that 192.168.1.1 works, but changing a router to 192.168.8.1 or 192.168.8.2 makes the page unreachable again, even though 192.168.1.2 works [#16428680] So the issue appears specific to access on the 192.168.8.x range in that setup, and the thread does not reach a final fix [#16428680]
  • #1 16422324
    dj crazy
    I have a problem with the huawei b315 router, it is connected to the desktop with a lan cable, the internet works, but I can not get to the configuration panel, I enter the standard address 192.168.8.1 and a message appears, the connection could not be established. It is strange because by entering the same address in the browser of the phone connected via Wi-Fi with the phone I have access to the configuration, and I cannot access the PC. I formatted the computer, the router is restored to factory settings, but it still does not work, after entering ipconfig on the command line, the default gateway is 192.168.8.1
    Ethernet adapter Ethernet:
    Connection-specific DNS Suffix . :
    Link-local IPv6 Address . . . . . : fe80::1d1d:458:7281:9a3%2
    IPv4 Address. . . . . . . . . . . : 192.168.8.100
    Subnet Mask . . . . . . . . . . . : 255.255.255.0
    Default Gateway . . . . . . . . . : 192.168.8.1
    Ethernet adapter Ethernet 2:
    Media State . . . . . . . . . . . : Media disconnected
    Tunnel adapter Teredo Tunneling Pseudo-Interface:
    IPv6 Address. . . . . . . . . . . : 2001:0:9d38:90d7:28c6:3bb8:3f57:f79b
    Link-local IPv6 Address . . . . . : fe80::28c6:3bb8:3f57:f79b%12
    Default Gateway . . . . . . . . . : ::
    jimasek
    Help: 3783
    Rate: 2681
    Have you checked on different browsers? You enter http://192.168.8.1
  • #3 16422433
    dj crazy
    Yes, on 3 different and the same message pops up.
    jimasek
    Help: 3783
    Rate: 2681
    ping 192.168.8.1 responding?
  • #5 16422465
    dj crazy
    I can't verify the result, I will paste what I have received.
    [code:1:79b88e50da]
    Pinging 192.168.8.1 with 32 bytes of data:
    Reply from 192.168.8.1: bytes=32 time
    jimasek
    Help: 3783
    Rate: 2681
    Do you have any anti-virus or firewall that could block access?
  • #7 16422469
    dj crazy
    Yes, I have kaspersky turned it off and restarted the computer, but then the same thing, the firewall and win 10 protection is also turned off.
    Added after 1 [hours] 57 [minutes]:
    Now the following message appears:
    Connection interrupted
    The connection to the server was reset while the page was loading.
  • #9 16422977
    dj crazy
    Unfortunately, but nothing helps in private or safe mode, I can't load the page.
  • #10 16424781
    jimasek
    Help: 3783
    Rate: 2681
    I have no more ideas. Maybe someone else will speak.
    simhak
    Help: 109
    Rate: 336
    Only with this router no LAN connection?
    Test on another system, another computer?
  • #12 16425311
    dj crazy
    I have a second router tp-link td-w8970 if I connect it with a lan cable from a pc, then I can normally get to the configuration page by entering http://192.168.1.1/
    I don't have another PC or laptop.
    simhak
    Help: 109
    Rate: 336
    Other system - linux Live CD?
    Other LAN ports on the router?
  • #14 16428680
    dj crazy
    Strange thing with all this, today I tried to configure a second router as an access point, tp-link rouer, when I connected it to the computer, the standard ip address 192.168.1.1 worked, I had access to the configuration, when I changed the ip to 192.168.8.2 configuration page does not work, I can't load the page. I have restored the tp-link to factory settings and again the address 192.168.8.1 works, but again the change resulted in the fact that the new address, i.e. 192.168.8.2, displays the message connection time exceeded or the connection could not be established. The third attempt was to change the ip tp-link to 192.68.1.2 after this change, everything works, I can configure the router on a new address, the problem starts when I change to ip which has 8 as the second to last digit, e.g. 192.168.8.1
    I checked myself as much as I could do anything, maybe someone will be able to tell me what is blocking access?
The user is experiencing issues accessing the configuration panel of a Huawei B315 router via a desktop LAN connection using the IP address 192.168.8.1, despite successful access through a Wi-Fi-connected phone. The user has confirmed that the router is connected and functioning, as indicated by a successful ping response. Troubleshooting steps included checking different browsers, disabling antivirus and firewall settings, and attempting access in safe mode and private browsing, all without success. The user also tested a second router (TP-Link TD-W8970) and found that it worked correctly with a different IP address. The issue seems to be specific to the Huawei router when using IP addresses in the 192.168.8.x range, leading to connection timeouts or inability to establish a connection.
