The Huawei B315s-22 router does not work properly after a reset attempt
loducth0 17877 2
  • #1 16670306
    loducth0
    Hello!
    I have a Huawei B315s-22 router for over a year. Some time ago I already had a problem with it, just when it was disconnected from the power supply (due to a storm) after restarting only the power LED was on, the router was serviced and repaired (a new soft load was loaded), from what I read is that's common in this model. This time the problem looks a bit different. Initially, I reset it through the router page, but after that he did not want to connect to the internet, but he did not call for a pin, the LEDs lit as if it was already entered and indicated that there was a good range, but the site wrote that there is no coverage. I decided to portray it using the reset button (unfortunately I did not look at the instructions first and did it with the router turned off, as it was in my previous one). When I turned it on, only the power LED lit and once in a while it blinked at an irregular time, I waited a few moments and then held down the power button to turn it on and the power LED came on, a red LED indicating that you need to enter the pin or does not detect the sim card and the second and third LEDs indicating the range, the first one is off. I tried to reset it by instructions, restart it and still the same. I couldn't find a solution on the internet. Before I return it to the website, I would like to make sure that I cannot repair it myself, I would be grateful for any hints on how to restore it to working condition. The Huawei B315s-22 router does not work properly after a reset attempt
  • #3 16670332
    loducth0
    I just don't have any communication with him, via LAN, I forgot to write about it.
