[Solved] How to connect the Alcatel IK40 Link Key sim router to Asus DLS-AC52U
KucykBoss 9036 9
Can I connect an Alcatel IK40V SIM router to an Asus DSL-AC52U as a second WAN connection, and do I need drivers for it to work?
No, this Alcatel model is not something you can make work on the Asus DSL-AC52U by installing drivers; support is determined by the router hardware/firmware, not user-installed drivers [#17392236][#17391129] Asus only lists specific compatible USB LTE modems, and the IK40V is not among them [#17391139] If the modem is not supported, the Asus will keep it disconnected on stock firmware [#17391129][#17392236] The practical fix suggested in the thread is to use a supported modem instead, such as the Huawei E3372 [#17391187]
  • #1 17391124
    KucykBoss
    Rate: 12
    Today I purchased the above-mentioned Asus DSL-AC52U router and Alcatel IK40V sim router. Using the capabilities of asus, and specifically DUAL WAN, I would like to combine it so that it flashes together in "Fail over" or "Load balance" mode. I have a subscription to a card with internet in the PLAY network and internet from Netia. I have been configuring it for two hours but nothing comes of it, the internet via the cable works but the second WAN (Alcatel modem) is still 'Disconnected'. I checked what 3 \ 4G LTE modems support ausus and there is an alcatel there, but not my model . Do I need some drivers to get this bang together?
    makosuu
    Help: 369
    Rate: 370
    Asus may not support the lousy Alcatel on OFW.
  • #3 17391139
    KucykBoss
    Rate: 12
    On the Asus website there is information that the compatible models and networks are as follows:
    Huawei E1750C Play
    Huawei E156G Play
    Huawei E1823 ERA
    Huawei E372 ERA
    Alcatel X221S ERA
    And the question is, is there a chance to upload some drivers or remake the hardware so that it goes bang>? I paid about PLN 200 from this Alcatel and it would be a pity for the money :P
  • #4 17391162
    matek451
    Help: 4342
    Rate: 5784
    This Alcatel is worth PLN 20, not PLN 200. You spent a lot of money on equipment that has no right to work.
  • #5 17391186
    KucykBoss
    Rate: 12
    In MediaMark some f ** s told me that it would be good -_- so what do you propose to buy so that it all had arms and legs?
    Moderated By jimasek:
    3.1.17. Do not send very basic questions, the answers to which can be found in the manual or publicly available sources. Do not take the attitude that I am due. Take care of the level of questions and discussions. Thank you.
  • #6 17391187
    makosuu
    Help: 369
    Rate: 370
    Alcatel is worth nothing, not PLN 200, you should buy Huawei E3372 for PLN 50-70, it would rather be compatible. And it is a bad idea to believe a guy whose job it is to sell and not advise.
  • #7 17391197
    KucykBoss
    Rate: 12
    I will add that this Alcatel has a built-in slot for a micro SD card and after inserting 16gb and connecting to Asus the router sees the memory and the name of Alcatel
    KOCUREK1970
    Help: 3844
    Rate: 5456
    matek451 wrote:
    What's your problem, go ahead and give that scrap.
    If purchased in person in a stationary store, the seller has the right not to accept this return.
    KucykBoss wrote:
    I checked what 3 \ 4G LTE modems ausus supports and there is some Alcatel, but not my model.
    And here it takes revenge that you first bought and then checked if Asus supports - wrong order.
    KucykBoss wrote:
    You need some drivers to get it bang together
    No drivers, even lunar ones, will do anything here - the device is recognized by hardware.
  • #10 17393132
    KucykBoss
    Rate: 12
    I bought a new modem from Huawei, to close
✨ The discussion revolves around connecting the Alcatel IK40 Link Key SIM router to the Asus DSL-AC52U router using the Dual WAN feature for failover or load balancing. The user is experiencing difficulties as the Alcatel modem remains disconnected despite the Asus router recognizing the wired connection. Responses indicate that the Alcatel model may not be supported by the Asus router, with suggestions to consider alternative modems, particularly from Huawei, which are known to be compatible. The user ultimately decides to purchase a Huawei modem after realizing the limitations of the Alcatel device.
