AUDI A5 - how to check the oil level in the automatic transmission?
qbamis87 29823 7
  • #1 17395129
    qbamis87
    Hello, I have an audi a5 2.0 TDI, with an automatic transmission. I would like to check the oil level in the box. Is it possible to check the oil level in the box at home, or via a computer.
  • #2 17395218
    rumot102
    Rate: 31
    Were you looking for an bayonet?
  • #3 17395281
    lukasz12345678910
    Level 30  
    Help: 173
    Rate: 489
    DSG chest? The oil level is checked from the bottom of the box.
  • #4 17395291
    qbamis87
    I didn't see the dipstick.
    How do you check the level below? You can provide more details.
    lukasz12345678910
    Level 30  
    Help: 173
    Rate: 489
    what chest dsg or multitronic? Generally, you start a car, you change the brakes one after another, holding 2-3 seconds, hook up a vaga, look in the parameters until the oil reaches 35-40 degrees. You unscrew the drain plug, oil should show up, as you turn it off and that's it. Anything does not show it is filled from the bottom with an oiler. The plug performs the function of checking, if you want to drain the oil, you must unscrew the pipe from the oil level from under the cork. The Internet is full of manuals and videos on youtube how to do it.
  • #6 17395372
    qbamis87
    Multitronik 2.0tdi. 150km. I don't remember the markings right now
  • #7 17395785
    romuald-f
    A/T specialist
    Help: 407
    Rate: 1551
    Cooled box, temperature should not exceed 35 - 40 degrees C. We start the engine, unscrew the cap (10mm Allen key) and check if oil leaks or not. If it does not leak, add hypolnica (with a large "syringe"). AUDI A5 - how to check the oil level in the automatic transmission?
  • #8 17397498
    qbamis87
    Thanks for the help, however, there was a lack of oil.
To check the oil level in the automatic transmission of an Audi A5 2.0 TDI, it is necessary to start the engine and allow the transmission to reach a temperature of 35-40 degrees Celsius. The oil level is checked from the bottom of the transmission box by unscrewing the drain plug. If oil leaks out, the level is adequate; if not, oil must be added using a syringe. The process may vary slightly depending on whether the vehicle has a DSG or Multitronic transmission. Detailed guides and videos are available online for further assistance.
