Audi A4 B8 Avant Quattro 2.0 TDI 177KM 2012: Checking Oil Level without Dipstick - Tips & Tricks
berserker1 69039 4
  • #1 18282771
    berserker1
    Rate: 47
    The car is Audi A4 B8 Avant Quattro 2.0 TDI 177KM 2012. How to check the oil level, because there is no dipstick here, only an option in the Car / Oil level computer, but it only goes there when the engine is running, i.e. how it can show the oil level well. Yesterday, while driving, when I entered the option, it did not show as if there was not enough oil. 500 kilometers ago I changed the oil - what takes a liter of oil for 500 km - some absurdity. It is also absurd that it shows how much oil is only while driving. I do not know whether to refill it because I bought a liter. I don't know, maybe I'm checking something wrong?
  • #2 18282791
    Dziarski Hank
    Help: 246
    Rate: 934
    berserker1 wrote:
    which is how it can show the oil level well
    Normally. You have a sensor in the bowl that accurately determines the oil level and calculates whether it is correct or not. In this case, the classic bayonet is no longer required.
    https://a4-klub.pl/topic/256526-bagnet-oleju/
  • #3 18283206
    berserker1
    Rate: 47
    It is not possible to check the level on this display with the engine turned off? If it does not show me anything between min and max, then the indicator above the clocks should not light up? Somewhere someone wrote about opening the hood, inserting the key and then it shows the real condition of the oil, but I tried and nothing - unless it's a different procedure or I'm doing something wrong?
  • #4 18283330
    Rafik4
    Help: 214
    Rate: 314
    You can check the oil level in the MMI on the ignition itself, the engine does not have to be running (although I always check while driving, allroad 2.0TDI from the same year). Turn off the engine after driving, wait a few minutes and you will see the condition of the oil on the ignition on. You can also connect the computer and there is the oil level in mm in the parameters, there is also a parameter that informs at what level the system will report that there is little oil. According to what you write, you have too little oil, add half a liter and you will see how much is still missing.
  • #5 18375204
    berserker1
    Rate: 47
    Gentlemen, so as not to assume a new topic, I wanted to ask if the battery in the audi a4 b8 discharges completely, then I normally connect the charger and charge it? Nothing in the computer there will be disrupted with such a discharge? Will I open the door with the key with a discharged battery and normally turn off the alarm?
