[Solved] Excel - Ctrl + C selects several cells, not one. how to eliminate it
pgsa 8181 3
  • Ctrl+c appears to trigger table selection instead of copy
    #1 17397891
    pgsa
    the case looks like this:
    1. When I press ctrl + c, instead of copying a given cell, the program selects a certain area of the table or the entire table
    2. If I press ctrl + c, and the cell I want to copy is at least one empty cell away from the table, ctrl + c does not work
    3. When I use the mouse, the "copy" function works and everything is fine
    4. ctrl + v works normally
    It looks like "ctrl + c" has lost its "copy" function
    Request: Help me get rid of this damn thing
    Works normally in World
    Thank you in advance
  • #3 17397981
    pgsa
    After starting Excel, I hit Ctrl + Shift and so far everything is back to normal
    Thanks
  • #4 17397982
    pgsa
    Thanks
    Ctrl + Shift solved the problem
