Excel Date Format Alteration: Copying Cells and Retaining Original Format
drzarul 7413 3
  • #1 17995496
    drzarul
    I have a problem with excel, I need to copy the date from cells and insert it into another one, but excel automatically changes its format, I can't change it to the format that I need. an example is attached
    • przyklad.xlsx (7.95 KB) You must be logged in to download this attachment.
  • #2 17995502
    actin
    Help: 187
    Rate: 799
    Select the cells where you want to copy these dates then click Number Format-> Text. Now everything will be copied in the same format as it came from the original cell.
  • #3 17995510
    drzarul
    It works but only for newly entered dates. If I have already completed dates in cells, after changing them to text, it changes them to "text", that is, for example: "43445"
  • #4 17995862
    Maciej Gonet
    VBA, Excel specialist
    Help: 824
    Rate: 481
    It is not known what exactly you mean. You write about copying and in the example you have references to cells with dates, which is quite different. Excel uses different methods of writing the dates. If a date is identified as a date (number), its format is determined by the cell format. In your example, the system formatting is set, so what exactly is it for you - it is not known, because everyone who opens your file sees their own system format.
    The formula you used combines the contents of two date cells into one text. Unfortunately, this cannot be done in a universal way. If you reference a formatted cell in a text expression, the formatting disappears. They must be specified explicitly with the TEXT function. But this will be the formatting determined by a specific format code, and what is yours - we do not know. If you have dates with dots then you should use something like this:
    If you use a different date format, use your own format. However, the result will not match if you change the format in the source cells.
